BMW 325tds engine into a sierra hatch... will it fit?
deisel deviant
just starting a new project with me mate seamus to fit a bmw 325tds engine into my sierra, which used to be powered along by a far slower oil burner (1.8td).
so far engine and box are out of the sierra and the bmw has arrived ready to be stripped tomorrow, need to do some welding to the sierra first before anything else happens ( typical old ford :P ) but after the fun begins, il put some pictures up tomorrow after some more work has been done, gonna try and keep everything documented on here so i can look back in a few years and remember the "fun" we both had
deisel deviant
essentially smudge i wanted to stick to a diesel, and other than transit engines or something poor out of a scorpio i decided i wanted something german and 6 cylinder, and a week later along came a 325tds at a price i couldnt refuse, considering it was only 100 quid more than the standard engine for my car anyway! the engine turns out is a minter, with a manual box and only 115k miles from new, and was literally 5 miles down the road from where i live, should be 180bhp roughly when done and around 240ftlb of tourque
BMW used to ONLY use blocks that had done atleast 100k for their racing engines since they thought that IF it was to develop a fault it would've by now... If it is good enough for them
deisel deviant
ive already bought a bmw sean, 300 quid with only 110k miles on the clock! sounds mint n all, il be posting some pics up later on the progress, stripping the beamer today and maybe some welding on the sierra
(MercinarymechanicS)
sounds a great project, lots of tyre smokin fun, a freind of my dads (a hill billy) has a bentley mulsanne with a merc 3.0 td in with matching auto box 1000% better i say!, manual make it more interesting imo
3dr Cosworth owner
140 bhp these 325 tds engine and can easy get them upto 170 ish. be quite lively id say in and old sierra. Look forward to seeing it progress
deisel deviant
right status update for the day, with pictures coming later
started off by stripping the front off the bmw, saw a thread on retro rides saying he hammered the front end off, to begin with i was a bit miffed by this, until it came to removing the bumper etc, now i completely understand, unless you have the fingers of a small child you have no hope getting to any of the important nuts and bolts ( out comes the angle grinder). just getting to a point were we could start to see the front of the engine took nearly 5 hours, this did include removing the intercooler, oil cooler, radiator and the power steering fluid cooler so wasnt the end of the world. also stripped the aircon system out, which wasnt anywhere near as hard as i thought it was going to be GOOD THING. also removed the power steering pump and the fuel filter and its housing, along with all the rubbish stupid plastic that bmw attaches to nearly everything it can. also did some more measuring and by the looks of things the engine and box should go into the sierra quite easily, its going to be snug though, and it will mean removing the front of the car just to change the alternator belt, so its getting changed before it goes in. gearbox mount aswell is only about 3cm out and its adjustable on the sierra so it should fit quite nicely. il keep you posted on further developments and il upload the pics in a bit, if you have any questions please feel free to ask
big floppy donkey dick
sorry but there are forum rules you need to adhear to.........
Pics or it didnt happen!!!!!!
please
i used to put "propper" tuning boxes on these and the torque was just stupid, you will love it!
please
deisel deviant
the sierra with engine out
the hole
the flocked dash and cossie leather thats just visible
arse end of the bmw
engine bay before work starts
bumper off, lotsa yanking and pulling and hammers involved
sorry i was wrong, just shy of 115k miles
now with air con rad removed and slam panel cut off, wasnt that much hassle with a grinder
ally comes up quite nice with a bit of a scrub
now with rad, intercooler and oil cooler off
the beginning of a huge headache (loom)
air con pump and rad removed, along with the power steering pump being loosened off the engine
any idea what this is??
fuel filter and housing removed
the wiring slowly starts to creep out of the plastic.. :/
i hope these pictures work haha
deisel deviant
wes, nope havent measured the box yet and im fairly sure it is bigger, but should just wedge in maybe with some slight modification to the bulk head, maybe move the heater matrix slightly to accomadate it, also forgot to mention that we removed the viscous fan to allow for some more room and are going to run the twin electric fans from the sierra as they are smaller, and good idea wes, sounds like a plan, il take a picture of that when its done.
deisel deviant
are the pictures working wes? and yeah should do, hoping with a good chip to see around 170ish bhp reliably without messing with the turbo and fuel pump setups
deisel deviant
i give up, whats the secret then?
until i work it out, heres a link to my photobucket library
http://s1295.beta.photobucket.com/user/jiminal/library/
deisel deviant
i honestly cannot get it to bring up anything at all, laptop im using at the mo is nearly dead and slower than the sierra in its current fettle! il try again tomorrow with some more images, hopefully with the engine out of the bmw and dummy mounted in the sierra wish us luck
competant bodger
my daily is a m reg 525 tds its barrels of fun and goes sideways easily , should be even more fun in a sierra. its a long old engine though might be a squeeze to get it in
i think that block with the wires going in is an earth block does it not just bolt to the body and earth all the wires out?
Received 1,042 Likes
Some thing different.
Here is the link to the old cortina.
This looks minted
http://www.permanent-solutions.co.uk/
This looks minted
deisel deviant
yeah botters it is quite long but it should just fit between the slam panel and the bulkhead, and hopefully we can mount the bigmetal water pipe below the height of the slam so it should gain us about 2 cm extra, weve already got rid of about 4cm just by removing the viscous fan and the bottom pulley which used to run the airconditioning pump, only worry is the size of the bellhousing and if it will clear the bulkhead.
and yeah there was 2 of those funny little blocks but theyre rubber, so didnt occur to us for them to be earch blocks, il do some investigating today when we start playing with the loom
wesskitzo
Bud take a look at this tread on here bmw 525i turbo into a 3dr
https://passionford.com/forum/restor...b25-turbo.html
is the diesel pump cable operated?
if not,search up a 324/524 pump for ease of installation.
can ditch pretty much every thing except the starter and glowplugs/relay
deisel deviant
the engine is out! along with about 10kgs of wires but its out, then spends the afternoon putting it in the sierra, which was successful, going to figure out mounts tomorrow and try and make a gearbox mount up, also had to cut the heater matrix so that the cylinder head and the intake manifold would fit in. im putting the pictures up online now, but i still cant work out how to link them to here so if seans about and doesnt mind helping out again? engine is now in sitting on the engine mount mounts. will have to make some new mounts up on extention plates.
