My Westfield Cosworth
Old 13-04-2016, 08:38 PM
  #161
costina
Live long and prosper!!
costina's Avatar
Originally Posted by jontysafe
Yes I've seen that but that's 360lb/ft with a car that weighs at the VERY least 1300kgs and with 4 people and a bit of luggage could be nearly 3 times the weight of my car. Yes the clutches have torque ratings but surely the weight must affect this as well?
I will call him again tomorrow and have another chat.
Its your call, just be sure.
Also make sure the flywheel is machined when fitting new clutch..
Old 29-04-2016, 09:53 AM
  #162
jontysafe
jontysafe's Avatar
Nice work from Nortech Performance.
Old 29-04-2016, 12:24 PM
  #163
costina
costina's Avatar
Nice any of the manifold.?
Cooler and rad next then??
Old 29-04-2016, 02:19 PM
  #164
jontysafe
jontysafe's Avatar
I will take some pics when I get it, that pic was taken before Nortech took everything back off the car for its journey back down south.
Absolutely, roll cage rad mount, intercooler build up and mount, oil cooler mount, dry sump tank etc...
Old 29-04-2016, 02:20 PM
  #165
jontysafe
jontysafe's Avatar
I need to start pressing a certain engine builder as well!
Old 29-04-2016, 03:13 PM
  #166
costina
costina's Avatar
No rush on bits mate.
Old 29-04-2016, 04:21 PM
  #167
Caddyshack
Caddyshack's Avatar
I think you are probably right and it is easy to change the clutch if you need to. I suspect you will spin the wheels before it slips
I think my car is probably 250kg more than yours and in second gear in 2wd mode the wheels spin whenever it passes 3500 rpm on a dry road, I have 195s
Old 29-04-2016, 05:08 PM
  #168
costina
costina's Avatar
Toby, if you cannot put the power down without spinning, all that power is pointless surely.?
Old 29-04-2016, 05:25 PM
  #169
jontysafe
jontysafe's Avatar
It's not a racing car looking for the last 10ths on a lap it's a fun car.
No way could I give mine the beans in second or third come to think of it!
There is that sweet spot you sometimes hit though between slip and traction that catapults you down the road like its chips night at home!
  #170
Caddyshack
Caddyshack's Avatar
Correct, but I have a little switch marked 4wd and as soon as I hit it I get an active centre diff that is ecu controlled, the skyline box sends power to the front and it JUST about handles the power although I did get all 4 wheels spinning / scrabbling for grip the othe day. You can watch the pressure gauge swing from zero to 200psi as it locks up the centre diff.
I have a quaife diff in the front as well.
I think Jonty is going to need the stickiest tyres he can find with that power, mine is 500lbft and 469 bhp (soon to be 530)
I will be improving my tyres soon and I also have some comps in 8inch to try, plus the 6 degree beam will also help I think.
Old 29-04-2016, 05:26 PM
  #171
jontysafe
jontysafe's Avatar
Thanks mate
Old 29-04-2016, 06:12 PM
  #172
costina
costina's Avatar
Sticky with spikes too.
Hopefully might get a go out in Jon's but i will prob scream like a girl
Old 29-04-2016, 06:17 PM
  #173
Caddyshack
Caddyshack's Avatar
Me too, I had a 7 with 220bhp an zetec on bodies and it was very quick, I cannot imagine what another 275bhp would do to it, mine made small torque, this one will be 3 times that or more
Old 29-04-2016, 07:17 PM
  #174
jontysafe
jontysafe's Avatar
I think my traction control will get a bit of a work out!! Probably won't switch it on much though to be frank. Boost control will probably be my right foot as well with boost to throttle position maybe another axis as well.
Paul you'll be the first out in it!!
Old 29-04-2016, 08:21 PM
  #175
costina
costina's Avatar
Thanks.
Was at Simpson race exhausts on monday as we had a car there.
Mate their work is really impressive Matt and his guys do magic with exhausts.
Thought my job was cool until i see what they do.
Old 29-04-2016, 09:44 PM
  #176
jontysafe
jontysafe's Avatar
Thanks.
They are the best, all internally gas purged. Second to none !
Old 29-04-2016, 09:50 PM
  #177
costina
costina's Avatar
Yeah had a chat with Matt and the guys. You could call it art.
Give me a shout if and when you need a hand fitting engine etc.
Old 30-04-2016, 06:54 AM
  #178
Caddyshack
Caddyshack's Avatar
Nor tech made mine and it was purged too. I had a little mod done locally and the welder couldn't believe the quality
Old 01-05-2016, 06:35 AM
  #179
jontysafe
jontysafe's Avatar
I'm looking forward to seeing mine in the flesh. Been away in Finland all week.
Old 03-05-2016, 02:39 PM
  #180
20/20 vision
20/20 vision's Avatar
Location: it's not where you are, it's where you've been and where you hope to be
its not clear from the picture above, what type of ex manifold have you got?
Old 03-05-2016, 03:11 PM
  #181
jontysafe
jontysafe's Avatar
It's a Nortech custom twin scroll.
Will take some pics tonight
Old 03-05-2016, 06:46 PM
  #182
jontysafe
jontysafe's Avatar
Fantastic quality as Toby said. James at Nortech is a nice guy as well.
Old 03-05-2016, 07:15 PM
  #183
Caddyshack
Caddyshack's Avatar
They look good enough to just keep in your lounge don't they. It was a shame to cover mine in zircotec
Old 03-05-2016, 07:38 PM
  #184
jontysafe
jontysafe's Avatar
They do! Not sure the Mrs would agree! Not going to do zircotec on manifold but may wrap down pipe.
Old 04-05-2016, 07:11 PM
  #185
jontysafe
jontysafe's Avatar
More Nortech pron!!
Old 04-05-2016, 07:39 PM
  #186
Caddyshack
Caddyshack's Avatar
Looks great, if you put some auto,sol on the end silencer and polish it up they come up lovely.
Then seal it with a light wipe of car wax
Old 06-05-2016, 04:55 PM
  #187
R4N SS
R4N SS's Avatar
Thanks.
based in middlegreen in slough, down the road from my folks
Old 07-05-2016, 08:14 PM
  #188
20/20 vision
Default another YB efr7163 powered 7
some pics of my efr7163 YB dax
Mark Shead kindly lent me one of his manifolds to try for size but it wouldn't fit. the dax is wider than a westy and the engine is set over toward the inlet about 40mm as well so im not sure how you got your manifold in?
had problems with the manifold hitting the right side upper chassis rail, touching the alternator and also the steering column. in addition, in meant that the turbo was too high and touched the bonnet so eventually bought a twin scroll jobbie from Norway and cut off the t3 flange and welded on a t4.
no capping the boost here, its 4wd with CR semi straight cut box and 4.4 diff
Attached Thumbnails My Westfield Cosworth-img_2138.jpg   My Westfield Cosworth-img_2142.jpg
Old 08-05-2016, 08:29 AM
  #189
20/20 vision
Default manifold differences
looking at your manifold pictures again and the one Mark lent me I see they are different (originally i thought Mark's manifolds were Nortech).
here's a picture of Marks when i tried to fit it. the turbo sits further away from the head on his and the primary from #1 is longer. i can see how yours will fit in your westy now! superb quality aren't they with the collector made from a billet
Old 08-05-2016, 09:12 AM
  #190
jontysafe
jontysafe's Avatar
Yes all custom made by Nortech to fit. It's the second one they've done as Lee has gone this direction as well.
Is yours up and running?
Old 08-05-2016, 11:42 PM
  #191
20/20 vision
yes - been the doing the general running around using the the autotune function of the ecu to get most of the mapping done and its going to rolling road on Tuesday to sort timing on boost etc. however, the engine that's in it currently has done 30k miles, is a little tired and i think the gasket is on the way out but i aint got time to complete the new spec one, fit it and run it in prior to a scottish tour in 2 weeks time.
the current engine spec is very low comp with cams which ISTR are BD12ish and was live mapped at msd 15 years ago. i want to learn more about mapping so looking forward to RR session. new engine spec is BD16/15, 8:1cr, ported head etc and then it will go back to rolling road for on-boost timing etc
Old 08-05-2016, 11:48 PM
  #192
20/20 vision
does the nortec manifold require a bonnet bulge to clear the turbo ?
Old 09-05-2016, 10:27 AM
  #193
jontysafe
jontysafe's Avatar
It will do yes although I probably won`t do that, it`s just the top of the compressor housing and it`s only 1". I will do a sneaky cut out. Also the actuator bracket will also need a wee nip out of the bonnet as well.
Old 09-05-2016, 10:29 AM
  #194
jontysafe
jontysafe's Avatar
Scottish tour sounds fun, fingers crossed it stays dry for you! What boost will you be running on new engine? What ecu you using?
Old 09-05-2016, 01:26 PM
  #195
20/20 vision
done lots of scottish tours and never had a week without rain at some point!
actually there's two scottish tours and the new engine should be in for the second one.
i bought a 7163 rather than a 7064 because the 7064 is bigger and i would then have needed a bonnet bulge whereas the 7163 fits in with 15mm clearance of the bonnet on this manifold. the actuator also clears the chassis rail by 15mm too. it was a monumental struggle to get everything in there as steering shaft, front drive shaft, alternator, chassis rails and engine mount all wanted to fight for space.
the ecu is MS3pro which is the commercially built latest megasquirt. it has proper connectors etc and is a world away from 'traditional megasquirt'. cost is Ł1100 inc 8ft harness and i couldn't find anything comparable in terms of cost, I/O options and ease of use. the software calculates a base map when you tell it engine size, injectors, map sensor etc and the car ran ok without doing anything. then drove around for 30 mins using the autotune function (uses ego feedback) which fine tunes and id say that part of the map is nearly done. i set the timing really retarded on boost and tried it up to 120 kpa last night and it was good. still a few things to set up such as the turbo speed sensor etc.
the other reason for getting ms3pro is that it has a unique feature which i haven't seen on any other ecu at any cost (i sound like a salesmen for it!) and that is the shadowdash software. the rs232 output from the ecu connects to a bluetooth transmitter which sends all ecu functions to an android device. you can create any dashboard style / gauge layout etc you like and have that as your dashboard.
dont know what boost it will run - as much as possible! as with all tuned 7's, heat management is a major issue so im interested to see details of your rear rad system. ive never had an IAT problem as its got a very large air/water intercooler but the rad for that sits in front of the engine rad which restricts cooling buts in generally fine for road use although if its been thrashed the fan struggles to bring the temp done. there's not much headroom in the engine cooling system.
also, the 7163 as you know requires water cooling of the bearing housing and ive run lines from the intercooler water system for that which appears to be adding considerable heat to the water in the intercooler system. will know more after the RR tomorrow.
any pictures of your rear radiator?
Old 09-05-2016, 08:22 PM
  #196
jontysafe
jontysafe's Avatar
I had thought about adding the turbo water cooling to my charge cool circuit. Do you know what your intake temps are?
No pics yet as it's still being engineered. Going to be interesting to sort out the pipe runs.
Good luck on the rolling road, be very interested to hear results.
Old 09-05-2016, 09:32 PM
  #197
20/20 vision
ive not previously measured intake air temps as no logging gear but once put a digital thermometer device into the charge cooler water tank and gave it a good run and the max intercooler water temp recorded was during a long period of idle due to heat soak and no air going through the charge cooler rad. when it was live mapped at msd years ago they said that intake temps 'were fine'.
its mostly a road car and there is about 10 litres of water in the system with a 14" x 14" rad and a davies craig pump so i reckon the capacity is fine for its intended use, probably different on a track. the new ecu has lots of logging facility so i may get to know more soon.
the first logging ive done shows that the lowest IAT recorded (after warm up) is around 30c (ambient =15c) and reached a max of 41c at some points but there was no boost and the logs suggest that this is due to heat soak in the manifold. i think that IAT figures are un-reliable when there is low air volume going into the engine.
i'm hoping to learn more at the rolling road. certainly, the data logs give a lot of insight into whats going on and i now want to add temp sensors on the intercooler water as well. this data logging may become a new hobby!
Old 10-05-2016, 09:49 AM
  #198
jontysafe
jontysafe's Avatar
Default Fab work
Some very good work from Tylah Motorsport! Really please with the rad mounts.
Old 10-05-2016, 09:52 AM
  #199
jontysafe
jontysafe's Avatar
Intercooler end tank design and fab. We are going 2.25" inlet and outlet.
Old 10-05-2016, 09:53 AM
  #200
jontysafe
jontysafe's Avatar
Deano at Tylah is going to fab up a duct on front of cooler so that all the air coming into the nose one HAS to go through intercooler.
Quick Reply: My Westfield Cosworth
