Focus RS mk1 4x4
04-02-2013, 09:35 PM
Focus RS mk1 4x4
04-02-2013, 09:38 PM
04-02-2013, 09:44 PM
04-02-2013, 10:59 PM
Look's a lovely car
who did the fab work ?
05-02-2013, 06:51 AM
A1 Rallysport, and Mk Motorsport did the hubs tca's comp struts etc
05-02-2013, 11:34 AM
Definitely some nice bits going into it
Front strut tops look very wide apart.
have you mocked it all up with 4x4 suspension?
Got good camber angles?
05-02-2013, 04:09 PM
Wow this is well smart.Some nice parts there.I take it your using cossie running gear.
05-02-2013, 04:19 PM
05-02-2013, 04:52 PM
Quote:
Originally Posted by
Very nice
Nice job good to see one done not useing a 4x4 floor
05-02-2013, 09:08 PM
05-02-2013, 09:11 PM
05-02-2013, 09:15 PM
05-02-2013, 09:19 PM
liking alot!!
05-02-2013, 09:24 PM
custom boost pipes
wiggins
off turbo
05-02-2013, 09:27 PM
how dos it set up with the strut tops were they are(front) then just intrested as its 4x4 ,looks good so far
05-02-2013, 09:28 PM
custom intercooler with air dam
05-02-2013, 09:31 PM
coming together nicely......
05-02-2013, 09:48 PM
dingla rs
Exactly what i was asking Andy
It does'nt look like the front suspension mounts have been moved in to replicate the sierra ones so the front shocks may be standing up to straight
every 4x4 focus ive seen has had the strut tops moved in to 40" centres from the focus setting of 42"
Shaun have you mocked the front suspension in?
Only trying to help and learn not picking faults
David
05-02-2013, 10:02 PM
competant bodger
that looks proper that mate, hope you get some top notch engine mounts on it tho pal as with all those solid hoses on some damage will be caused if it snaps a mount which is common with the 4x4's
looking forward to updates on this
06-02-2013, 01:30 PM
06-02-2013, 05:44 PM
Quality build
06-02-2013, 05:50 PM
Engine bay looks stunning
06-02-2013, 05:51 PM
Cracking build keep up the excellent work
06-02-2013, 05:54 PM
Anyone on here own a 5 door mk1 focus? If so please could you measure the depth (or if you like width) of you door sills? This being from under the rubber/sponge draft seal to the point where the bodywork drops down. On my 3 door mk1 it is 65mm and would just like to check if they are the same? Anyone who could do so would be doing me a massive favour.
Thanks guys.
06-02-2013, 07:27 PM
botters it looks like hes running vibertechincs mounts
06-02-2013, 08:11 PM
whizzisat114
David
06-02-2013, 08:13 PM
graham c
the engine was only in for mock up its back out now, not using those engine mounts
06-02-2013, 09:59 PM
shaun_focus4x4
Thanks Shaun that's cleared it up for me
Good luck with the build
David
14-05-2013, 07:14 AM
new stoppers
14-05-2013, 08:24 AM
14-05-2013, 08:28 AM
Love it! Can't wait to see more...
23-06-2013, 11:27 AM
and the rears
23-06-2013, 11:28 AM
will hopefully be done for ford fair
23-06-2013, 03:45 PM
They look great
Are you having separate handbrake calipers?
Or do these have that feature built in to them?
23-06-2013, 03:55 PM
will be running a hydraulic handbrake and will prob just use a hydraulic line lock
23-06-2013, 06:08 PM
Oh I thought you had to have a mechanical handbrake to pass an mot?
23-06-2013, 06:24 PM
That looks really nice that
23-06-2013, 06:50 PM
yeah I believe you do. that wont be hard to add on at a later date
not too fussed about having it on the road at the min, it'll be abit too harsh for the roads round here (pot hole central)
23-06-2013, 07:42 PM
23-06-2013, 08:50 PM
