Series 1 RS Turbo soon to be track prepared. Update So close to paint now
Old 19-11-2014, 02:26 PM
  #121
Gadget
Spanner monkey
Gadget's Avatar
Lol, now they are
Old 22-11-2014, 10:15 AM
  #122
crazycage
crazycage's Avatar
Top work mate
Old 22-11-2014, 04:42 PM
  #123
Brian
Brian's Avatar
Looking good
Brian
Old 22-11-2014, 09:51 PM
  #124
cossirob
cossirob's Avatar
Who done the wiring loom? I need to do it to my mk3.
Old 23-11-2014, 10:20 AM
  #125
jessie_rs
jessie_rs's Avatar
Gadget himself is wiring the car
Old 23-11-2014, 03:57 PM
  #126
cossirob
cossirob's Avatar
Is he just putting wire braid over your original loom with the original fuse box and re running it or has he built a complete new loom?
Old 23-11-2014, 09:31 PM
  #127
Gadget
Spanner monkey
Gadget's Avatar
It's the original loom with all the unwanted / unused parts removed, then the extra bits added as needed.
Old 24-11-2014, 07:59 AM
  #128
cossirob
cossirob's Avatar
Hmmm interesting lol. Do you do this just for yourself and friends or would you do it for other people/ customer's (me) lol.
Old 24-11-2014, 11:07 AM
  #129
M K
M K's Avatar
All looking good mate
1 concern though is where you have cut your intercooler to modify the pipes!!!!
I did this exact same thing to the grs cooler on my xr2 turbo
I cleaned out all the swarf after but did not realise some had got into the core that I didn't get out and it cost me a 15mile old engine and a 3k repair bill!!! Basilcally the swarf had got into the core during the initial cutting out of the old pipes, I cleaned out all I could see but didn't realise there was swarf I could not see, when the new engine was put in the car and mapped with a bit of boost it blew the swarf out the cooler, into the inlet manifold and then into the head, ruining a valve seat, snapping the valve which fooked the head and the piston and the block! expensive lesson learnt.
So be aware! there is no way when you cut the original pipe out that you can stop swarf getting into that core and it may cost you BIG TIME like it did me!
Old 25-11-2014, 08:36 AM
  #130
crazycage
crazycage's Avatar
That's why I aways make new end tanks mark ,that way I can clean the core out cost me my first engine too
Old 25-11-2014, 04:13 PM
  #131
homer j
homer j's Avatar
[QUOTE=jessie_rs;6537934]
just wondering mate but what inlet is that you have fitted? not seen a zetec inlet like that before.
regards
Tom
Old 17-12-2014, 11:58 AM
  #132
jessie_rs
jessie_rs's Avatar
its an american inlet.
Old 17-12-2014, 01:34 PM
  #133
Focosmitch's Avatar
Any updates timmy?
Old 17-12-2014, 09:48 PM
  #134
jessie_rs
jessie_rs's Avatar
Yes Ive got lots of pics to upload. Its nearly ready for paint just havent had the time to do it
Old 18-12-2014, 03:57 PM
  #135
jessie_rs
jessie_rs's Avatar
Brake lines run
Battery box mounted
Old 18-12-2014, 03:58 PM
  #136
jessie_rs
jessie_rs's Avatar
Painted underside now also after all the fab work. Full underfloor, arches and turrets have been painted.
Old 18-12-2014, 04:18 PM
  #137
jessie_rs
jessie_rs's Avatar
Pedal box was a nightmare. Floor mounted didn't fit at all with me being 6ft 4. That was ditched for a cockpit mounted universal pedal box which needed a lot of work to fit. It need custom strengthening plates and then cut outs for clearances also! A real nightmare!
Old 18-12-2014, 04:20 PM
  #138
jessie_rs
jessie_rs's Avatar
Strengthening plate for the gear surround
Old 18-12-2014, 04:22 PM
  #139
jessie_rs
jessie_rs's Avatar
Reservoirs mounted
Old 18-12-2014, 04:45 PM
  #140
jessie_rs
jessie_rs's Avatar
To add to the never ending list of problems the turbo doesn't clear anything. The down pipe doesn't clear the gearbox. Easiest solution is to have a Gary crazy cage exhaust manifold made along with a custom down pipe.
Old 18-12-2014, 07:23 PM
  #141
frsjon
frsjon's Avatar
awesome work ive been hunting for one of those rocker covers but no luck lol
what turbo are you using mate? im in need of a cossie down pipe if thats what you were going to use
Old 21-12-2014, 05:54 PM
  #142
jessie_rs
jessie_rs's Avatar
A gt30. Its a custom downpipe. And now a new one being made also.
Old 22-12-2014, 07:46 PM
  #143
MrCapriScort
Old Fords Never Die
MrCapriScort's Avatar
How have i missed this before, what a mint build.
Old 22-12-2014, 10:44 PM
  #144
Focosmitch's Avatar
Because he slacks with the updates, thats why!!
Old 23-12-2014, 10:46 PM
  #145
jessie_rs
jessie_rs's Avatar
Haha! Its too time consuming to upload then post pics I cant find the time
Old 24-12-2014, 10:52 AM
  #146
This is turning into a serious track car.
Old 28-12-2014, 05:05 PM
  #147
jessie_rs
jessie_rs's Avatar
Exhaust Manifold being made by crazycage. His welding really is something else!
Old 28-12-2014, 05:17 PM
  #148
jessie_rs
jessie_rs's Avatar
All clearance problems sorted and new downpipe means everything clears the new focus rs box.
Old 28-12-2014, 05:34 PM
  #149
jessie_rs
jessie_rs's Avatar
Twins worked his magic on the dash.
One uncracked dash:
And Twins fantastic work:
Cut outs for the cage
And twins being twins seeing that I had bumper the rear bumper into the wall straightened it out for me. Topman for that! One less job for the bodyshop to do!
Old 28-12-2014, 05:49 PM
  #150
Focosmitch's Avatar
Loving the dash mate!!
Whos flocking it?
Old 28-12-2014, 07:26 PM
  #151
gup
gup's Avatar
What paint did you use for the underneath dude
Old 28-12-2014, 07:54 PM
  #152
Gadget
Spanner monkey
Gadget's Avatar
The floor was given 2 coats of U-POL Gravity tex plus stone chip protector in white, then covered in white Hammerite smooth! The arches have had one coat of hammerite and will have a second in a few days.
Dash is going to Central blast.
jessie_rs (28-12-2014)
Old 28-12-2014, 09:43 PM
  #153
steve.rst
steve.rst's Avatar
Hi, love all the work being put into this car, I like the idea of putting a perspex sunroof in, is that a kit you have bought?, if not what thickness perspex have you used, as i would like to change my rusty glass sunroof
steve
Old 28-12-2014, 10:05 PM
  #154
jessie_rs
jessie_rs's Avatar
Hi Steve,
No it was something I had made. The sunroof was mint and didn't needed changing but a track car with a sunroof didn't seem right and I didn't fancy a roof swap!
Old 01-01-2015, 07:50 PM
  #155
steve.rst
steve.rst's Avatar
Hi Jessie, thanks, i suppose i could get something made up locally, do you know what thickness the perspex is.
steve
Old 01-01-2015, 08:36 PM
  #156
fezzajsy
fezzajsy's Avatar
very nice
Old 03-01-2015, 06:07 PM
  #157
jessie_rs
jessie_rs's Avatar
steve
I can't remember off the top of my head. I'll have to double check
Old 05-01-2015, 03:59 PM
  #158
jessie_rs
jessie_rs's Avatar
Heater system finished
Old 05-01-2015, 04:21 PM
  #159
jessie_rs
jessie_rs's Avatar
ECU cover made and mounted.
Size:  111.7 KBName:  2014-12-31172717_zpsac9024d7.jpg
Old 05-01-2015, 04:24 PM
  #160
jessie_rs
jessie_rs's Avatar
Dash sent off for flocking and centre console along with ecu holder sent off to be powder coated.
Quick Reply: Series 1 RS Turbo soon to be track prepared. Update So close to paint now
