teamSPB 2009 BMW 1 Series build - Ascendant, B2, Mosconi, Gladen
Old 22-11-2012, 10:19 AM
bassboy
bassboy's Avatar
Default teamSPB 2009 BMW 1 Series build - Ascendant, B2, Mosconi, Gladen
Got a 2009 BMW 118d to do an install in currently belonging to my good friend Sunny...his requirements were OEM integration to the stock BMW headunit, upgrade the component system in the car, add a pair of subs to enhance the low end response. Everything must look stock in the cabin, with a good looking boot build to show when at shows etc
The spec will be;
Mosconi 6to8 processor with OEM integration
Gladen Audio BMW 200 component kit - 3 way consisting of tweeters, midrange and under seat subs
Mosconi ONE 120.4 amplifier powering the components
2 x Ascendant Audio Chaos 10s in custom made ported box
B2 Audio Mono mkII 2200wrms amp
Let the build commence!
There were no tweeters present in the OEM sound system, so we had to order in BMW HK tweeter panels for the stock look
Gladen BMW 200 midrange speaker
Silk dome tweeter
Crossover
Heat shrinked connectors then insulation tapped over the wiring
Same with the other side...pic of the tweeter fitted
teamSPB
Old 22-11-2012, 11:25 AM
I enjoy your builds matey.Keep the pics coming.
Old 22-11-2012, 01:04 PM
dave_s2_rst
dave_s2_rst's Avatar
Hi mate,
How much do those components cost? I'm looking to change the set up in my e60 as it currently sounds poor, I've seen a few people go for the JL range, how would you rate these compared to them?
Old 23-11-2012, 10:08 PM
bassboy
bassboy's Avatar
Under seat subs
OEM Sub vs Gladen 8
Shallow subs!
OEM enclosure
I was going to sound deaden these sub they really are solid and have no resonance or flex...especially considering they are bolted directly onto the floor!
Sub in
Passenger side had plent of change attached to it lol
Gladen BMW wiring harness
This allows you to add an external amplifer without the need to modify cabling or cut anything!
Old 24-11-2012, 09:12 AM
That cable is a good idea isnt it.
Old 24-11-2012, 06:37 PM
fezzajsy
fezzajsy's Avatar
nice one
Old 26-11-2012, 10:40 AM
bassboy
bassboy's Avatar
Quick pic of the Ascendant Audio Chaos 10s in their new home...box is not complete yet..still waiting on a few bits to turn up
Old 26-11-2012, 11:17 AM
That box looks cool.
Old 28-11-2012, 07:04 PM
bassboy
bassboy's Avatar
Bass controller being ran into a cubby hole
Mosconi ONE 120.4
Unfortunately there isnt much space for the amps to sit unlike the E90s, so we had to put the amps on the top...which is no problem as the pretty panels will cover everything
Can just about make out the wiring loom
Levelling up the boot build
Old 29-11-2012, 10:25 AM
furry
DECODING JIBBA JABBA!!
furry's Avatar
does this gladen loom create the remote feed needed as well?
Old 29-11-2012, 10:43 AM
bassboy
bassboy's Avatar
The Mosconi 120.4 has high level inputs so will work off speaker level inputs...
In this setup, we are running the speaker cables directly into the Mosconi 6to8 processor which converts everything into low level (RCAs) and provides a remote output. I could have easily just ran the speaker cables directly into the 120.4 amp and it would have powered up and down with the stereo.
The thing I have noticed with all BMWs is that when you open the door, lights go on, etc etc, it actually sends a small signal into the speaker wires which turns the amps on, then off again a short while later...no biggy at all but it is something I have noticed with BMWs
Old 30-11-2012, 07:23 PM
bassboy
bassboy's Avatar
Close up of the Ascendant Audio Chaos 10s....BEASTLY subs!!
teamSPB
Old 30-11-2012, 09:25 PM
Very cool bass box that.Your well clever at doing these sound systems.
Old 30-11-2012, 09:36 PM
Tarren
Tarren's Avatar
Team STD for the win!
Loving your work fella!
Old 01-12-2012, 05:07 PM
bassboy
bassboy's Avatar
Perspex panel cut
Panels trimmed
teamSPB
Old 01-12-2012, 05:28 PM
Very nice as always
Old 04-03-2013, 01:41 PM
bassboy
bassboy's Avatar
Sunnys 1 Series came back in for some sound deadening work...
Added some LEDs for the amp
Old 04-03-2013, 08:24 PM
Looking good matey.
Old 04-03-2013, 08:38 PM
dave_s2_rst
nice, did you sell you focus rs?
Old 04-03-2013, 08:59 PM
Cossie Sean
big floppy donkey dick
Cossie Sean's Avatar
i got a lot of respect for 1 series` top work matey, always like your builds!
i was given a M123d to remap and fit coilovers/wheels for a company into their noise in sunderland when it was a few days old, and what a car!
white with carbon spoilers
went like a scolded cat after it was mapped but they chose a set of gay wheels as it was their demo car and wanted to attract attention/customers (later changed for propper looking ones)
linky:
http://enjoythedrive.co.uk/view-our-...r-bmw-123d.php
Old 05-03-2013, 09:27 AM
bassboy
bassboy's Avatar
Cheers for the comments guys, im currently looking into what I can do engine wise with this one....needs a bit more omph especially after being out in my CLS 320cdi!
Dave, yes the FRS sold a while back...got a lovely Merc CLS 2005 plate now...do I miss the Focus, not really! Ive driven the Merc more in the last 2 months, then I did in the Focus in 9 months!!
Sean that sounds lovely mate! Ill have a read of the link now pal!
AJC
08-10-2015 11:09 AM
Oranoco
12
02-10-2015 02:18 PM
Kiran1600E
11
02-10-2015 11:35 AM
dalmarshall
Ford Classics & Vintage
01-10-2015 06:46 PM
stevecfrst1
30-09-2015 05:18 AM
Quick Reply: teamSPB 2009 BMW 1 Series build - Ascendant, B2, Mosconi, Gladen
