cosworth 2wd rebuild
hi to everyone im in the process of rebuilding my 2wd cosworth engine, im using a later 200 block but have come across a problem with the oil cooler modine, i have the original 2wd cooler but didnt want to use this one in case of metal particles contaminating the oil system, i purchased a good replacement but its a 4wd item so has a wider body so the retaining bolt is now too short, the 4wd coolers are mounted to a remote housing unlike the 2wd that mounts straight to the block so would a 4wd bolt fit? or how could i get around this problem? or is it just a case of finding another 2wd oil cooler? many thanks to all and good luck in whatever your doing to your fast ford
09-10-2015 07:38 PM
FlashRS
13
31-08-2015 06:02 PM
