Mk2escort grp4 cosworth conversion paul&si
27-03-2014, 07:06 PM
3-door moonstone
Quote:
Originally Posted by
cutch
nice job mate. love the wheels my mate has them on his mk1
Cheers fela should look good when there on and it finished
04-04-2014, 06:51 PM
3-door moonstone
Got the centre console mocked up tonight there are two side pieces to go on and the stereos just for mockup but you get the idea
18-04-2014, 06:52 AM
3-door moonstone
Mocked one side up with the side piece fitted not too bad few tweaks and should be spot on
18-06-2014, 08:14 PM
3-door moonstone
18-06-2014, 08:52 PM
Great wheels good taste lol looking good
20-06-2014, 08:08 PM
3-door moonstone
24-06-2014, 08:10 AM
3-door moonstone
10-08-2014, 05:20 PM
3-door moonstone
Been back on the wheels today polishing the rims here's one before and after not coming up too bad
20-08-2014, 05:53 PM
3-door moonstone
25-08-2014, 03:34 PM
3-door moonstone
Got tyres on the wheels put a front one on poor pics will get better ones tomorrow
25-08-2014, 04:40 PM
The only way is dagenham
That is THE best looking wide arched escort i've seen.
along with the red one from turnover.
25-08-2014, 05:14 PM
3-door moonstone
Cheers fela it's starting to come together now where chuffed with it
25-08-2014, 05:18 PM
siscossie
Cool stuff. I dont normaly like arched escort's my fav escort is the mk2 harrier in white but you made it work. Its fooking lovely mate.
07-09-2014, 05:06 PM
3-door moonstone
W pulled the car out today weather been good and all and for the first time had all the wheels on, need a clean but you get the idear
07-09-2014, 06:52 PM
07-09-2014, 07:33 PM
Wow, another amazing car mate
13-09-2014, 05:38 PM
3-door moonstone
Well got the front brakes sorted brembo front calipers Daimler front discs new braided flexy pipes and made our own lines
25-09-2014, 07:41 PM
3-door moonstone
Today's task was to get the cross member out and trim the back edge and reweld it, was a bit too close to the sump for are liking but first had to support engine with the crane
The bit that needs trimming
And trimmed
We then welded it up read trot painting, will get pics of that tomorrow
05-10-2014, 09:11 AM
3-door moonstone
Come along way so far
05-10-2014, 10:40 PM
Looking good,that's a very nice shade of red
27-10-2014, 07:07 PM
3-door moonstone
Little update changed the front springs from 12" to 10.5" and fitted a new anti roll bar twin am one
Fitted the flywheel and hopefully the new clutch 6 paddle will be in tomorrow
29-10-2014, 06:40 PM
3-door moonstone
Got the new clutch fitted tonight should be up to the job
And the new roll bar and the crossmember assembled ready to fit, just giving the gearbox a clean then all in hopefully tomorrow
3-door moonstone
02-11-2014, 04:19 PM
3-door moonstone
Today we got the gearbox on the engine and lifted back into place and the new roll bar fitted, just got the struts to refit and the front end is nearly done
09-11-2014, 05:23 PM
3-door moonstone
Tonight we got the struts refitted with the shorter springs, and all the roll twin cam roll bar on
The stainless brake hoses fitted and copper to the calipers done
25-01-2015, 06:20 PM
3-door moonstone
Quick rack painted and new poly bushes and new rod ends should get them fitted tomorrow
26-01-2015, 10:24 AM
Location: in the workshop rebuilding my car for many years now
15-03-2015, 10:55 AM
3-door moonstone
The rack roll bar and new front springs fitted and sat back on its front wheels
Sits a lot better now
15-03-2015, 12:38 PM
WOW!!! totally stunning mate i had the cossack mk model on my mantle for years its great to see it replicated and being yb totally awesome kudos!!
16-03-2015, 09:03 AM
3-door moonstone
16-03-2015, 10:56 AM
Live long and prosper!!
Did you use the pug brembos as they have the same bolt spacing?
16-03-2015, 05:20 PM
3-door moonstone
16-03-2015, 06:52 PM
16-03-2015, 07:41 PM
What an awesome project. You've done an amazing job so far mate!!
17-03-2015, 06:44 PM
3-door moonstone
Cheers felas just getting back into it had a bit of time off as had a few issues with my 3dr
Started on the brake lines today made first one up then we braided it looks neater I think just a test fit
The discs are off a Daimler 300mm if I remember correctly
29-03-2015, 05:48 PM
3-door moonstone
29-03-2015, 07:33 PM
What blue engine paint did you use?
30-03-2015, 02:57 PM
3-door moonstone
costina
Think it was car plan engine laquar bud
30-03-2015, 03:55 PM
Nice and neat brake pipes them.
03-04-2015, 04:25 PM
3-door moonstone
Started to clip the brake pipes Dow today and started fastening the car loom into place
Extended the wires for oil pressure sensor got to do alternator wires tomorrow
