3DR Cosworth Added a "my Sierra Cosworth Story" Video
Old 17-08-2013, 07:33 PM
  #121
tonyRS
tonyRS's Avatar
it looks like the seat bolster is the problem with the centre console sitting over mate, but i have to say that car looks stunning and the trim has transformed it 100%
Old 17-08-2013, 09:03 PM
  #122
I went to Danty to get some cloth and there was none left.Someone had bought the lot.The woman who deals with all the fabric said they arnt getting anymore in aaahhhhh.Back to square one.
Old 18-08-2013, 07:03 AM
  #123
BRAMMER
BRAMMER's Avatar
Very nice looking, interior looks a million times better
Old 08-11-2013, 06:06 PM
  #124
adam151082
adam151082's Avatar
Ok been a while but ive decided to strip the underside, not going for a blinged up underside its just purely preventative maintenance, bare metal to remove and rust from getting worse, and powder coat the rusty bits
Jacked it up and put it on axel stands, removed the wheels and bumpers
Its not toooo bad atm, this is inside the front wheel arch where they rot
Still the front arch
Looks like sombodys had a go a long time ago
Old 08-11-2013, 06:09 PM
  #125
BRAMMER
BRAMMER's Avatar
Make sure you get in behind that sealer under the front arches as the water gets trapped, well worth doing and yours doesn't look too bad at all
Old 08-11-2013, 06:12 PM
  #126
adam151082
adam151082's Avatar
Cheers m8, ill do that, but the only water my car see's is the stuff that hits the garage window
Old 18-11-2013, 05:48 PM
  #127
adam151082
adam151082's Avatar
Can any help? The long bolt that holds the diff on seem to be stuck tight, ive removed the bolt off the end but its just not budging, is the somthing im missing?
Also I ordered a light to work on the car off ebay and it arived damaged so I contacted the seller and they sent another two out for some reason, so 3 lights for Ł20, canny score
Also one of the axle coming out, everyone seems to upload these so I thought I may as well
And a perk of work is we have a sand blaster so I tested it on a hub, I did take it to bits I just loosly put it back together here
Old 18-11-2013, 08:45 PM
  #128
3 lights for 20 quid.. bargain.
Old 19-11-2013, 07:43 PM
  #129
adam151082
adam151082's Avatar
Bought some new spray paint and im going to use it under the car insted of red oxide primer, seems to get awsome reviews and it drys over 90% zinc. Heres a little test sample
Im going to spray it black after as im trying to avoid powder coating
Old 21-11-2013, 07:51 PM
  #130
adam151082
adam151082's Avatar
Ok so im not gona do this for every part but I thought id show the rear brake guards off, I thought they where shot but I still took them to work to sand blast them the zinc sprayed them.
Has anyone ever tryed painting car parts as I dont fancy powder coating.
Never going to make it on a concorse car but thats not what im after.
Old 22-11-2013, 03:58 PM
  #131
adam151082
adam151082's Avatar
Ok so ive been in the garage for a couple of hours tonite, removed the power steering rack as it leaks and uses more fluid than petrol
Also started on the rear arch, I had hoped to have it all bear metal by christmas but jeeez this stuff it tough to remove, wire wheel just seems to move the seam sealer about
80% done
Also found this
Ill leave it till last incase anything else pops up
Also my dusty pants,
Can any tell me how to remove this conector on the end of the fuel line?
Old 22-11-2013, 04:40 PM
  #132
cozzy jeff
cozzy jeff's Avatar
Adam there is a proper two pronged tool to remove the plastic pipe but im sure I just used two terminal screwdrivers pushed up inside, another pair of hands might help.
Old 22-11-2013, 05:47 PM
  #133
adam151082
adam151082's Avatar
Cheers Jeff, ill give it a go. Did you get any welding done on yours?
Old 22-11-2013, 06:08 PM
  #134
gingerturbo
The annoying ginger guy
gingerturbo's Avatar
Yeh I got some fuel pliers (neilson) make them
Your making good progress
Old 28-11-2013, 09:07 PM
  #135
adam151082
adam151082's Avatar
Ok so this has got me puzzled, why has sombody fitted a different rear Anti Roll Bar(ARB)? im asuming this isnt standard 3door.
It looks like there can be 2 fixings for the ARB the original then these extra one that have been welded on
Standard and a blurry picture of the other ones
Looks like this has been added, im sure its not standard
Old 29-11-2013, 07:43 AM
  #136
adam151082
adam151082's Avatar
Done abit digging and it turns out to be a Escort Cosworth anti roll bar, apparently its a good mod and as this one looks like someones done a good job I may as well keep it
https://passionford.com/forum/ford-s...-mounting.html
might see if I can find a 22mm and see whats best between to 16mm and 22mmm
Old 08-12-2013, 10:30 AM
  #137
adam151082
adam151082's Avatar
Not much of a update on the car, still removing underseal, and still need to findout how that fuel line unconnects.
Just wanted to mention some essential equipment for the job
Number one is taking the car to bits, I bet this has saved may rounded bolts and skinned knuckles
Number two, removing the underseal causes alot of dust, dirt, smoke and noise. So PPE
Old 08-12-2013, 11:02 AM
  #138
Sonic Boom
Sonic Boom's Avatar
I did exactly the same to my 3 Door mate so I could fit a Escos 22mm rear ARB, looks like they have done it the same as me by cutting the mountings off a sapp shell and welding them on if done properly once it's undesealed and painted it looks factory.
Rich
Old 18-12-2013, 09:23 PM
  #139
adam151082
adam151082's Avatar
Could someone please photoshop these wheels a couple of different colors, silver, gray, black etc
Old 07-01-2014, 05:28 PM
  #140
adam151082
adam151082's Avatar
Ok so things slowed down abit over christmas but i still done some bits on the car but ill wait till theres some half decent pictures took, i got all the underseal off and cut a couple of rusty bits out and after failing to find someone i trust to come to the house and do some welding i went and bought my very own MIG
And my first attempt on a scrap bit pannel
Ive ordered a auto dimming welding mask to make the job abit easyer and ill then have two hands free
Old 07-01-2014, 05:43 PM
  #141
adam151082
adam151082's Avatar
Ooh, ive also got all the underseal off, im just prepping for primer using Bilt Hamber Electrox
Old 07-01-2014, 06:41 PM
  #142
I wish I could weld. I hope you have fun with the welder.
Old 07-01-2014, 10:49 PM
  #143
LaserSierra
LaserSierra's Avatar
hello
Do you still have the rear seat made of leather? In that case, is it for sale?
Old 08-01-2014, 08:58 AM
  #144
adam151082
adam151082's Avatar
Originally Posted by LaserSierra
hello
Sold m8, sorry
Old 08-01-2014, 04:40 PM
  #145
LaserSierra
okej, thanks
Old 13-01-2014, 06:04 PM
  #146
adam151082
adam151082's Avatar
Well i though id bite the bullet and try my welding on the car as i was sick of practicing, heres my first patch i made up and welded in, im chuffed with how it turned out. I just need to find something to get on to grind the welds flat.
Also just had a bill thats double i was expecting of Bara Motorsport.
Old 24-04-2014, 07:03 PM
  #147
adam151082
adam151082's Avatar
Ok so its been a few month but ive bought another project so thats taken up alot of time.
https://passionford.com/forum/restor...e-project.html
But after alot of time on my back ive managed to get the underside in color, no where near concours but im happy with it.
Guess the build up begins, i dowt it will be out this year though seen as i have a motorbike
Old 24-04-2014, 07:57 PM
  #148
little bram
little bram's Avatar
looks really good mate top job
Old 24-04-2014, 09:48 PM
  #149
binks101
binks101's Avatar
Nice work there mate
Old 26-07-2014, 11:49 PM
  #150
adam151082
adam151082's Avatar
Bit of a long and slow update. Had some bits zinc plated.
Ive fitted the petrol tank and this is the only photo ive got, with my RGV250
Old 27-07-2014, 08:21 AM
  #151
siscossie
3-door moonstone
siscossie's Avatar
Looks really good coming on well
Old 27-07-2014, 09:32 AM
  #152
its been a while lol.I hope you haven't run into too much trouble.
Old 27-07-2014, 03:38 PM
  #153
adam151082
adam151082's Avatar
No Glenn just ran out of motervation at the moment, more interested in motorbikes 😜
Old 28-07-2014, 11:16 AM
  #154
adam151082
adam151082's Avatar
Getting there
Old 28-07-2014, 04:50 PM
  #155
Is it gonna be a concourse car? Its mint matey.
Old 28-07-2014, 10:03 PM
  #156
adam151082
adam151082's Avatar
No where near concourse m8, theres alot of stuff going back on the way they came off. Its more of a remove the rust before it gets worse excercise
Old 27-11-2014, 07:49 PM
  #157
adam151082
adam151082's Avatar
Ok so its been a while and works been abit slow on the old Sierra.
Some of the bits ive been blasting and painting
Old Vs New
And the main reason things where slow over the summer
Old 27-11-2014, 08:25 PM
  #158
cozzy jeff
cozzy jeff's Avatar
Nice work mate
Old 29-11-2014, 08:41 AM
  #159
COLEYST200
COLEYST200's Avatar
Looking very nice mate
Old 29-11-2014, 09:59 AM
  #160
adam151082
adam151082's Avatar
Nice work mate
Thanks guys.
Quick Reply: 3DR Cosworth Added a "my Sierra Cosworth Story" Video
