My Mark One Escort Build
Old 02-01-2012, 08:49 PM
  #41
dave cos4x4
dave cos4x4's Avatar
excellent work you are doing.
Old 02-01-2012, 09:21 PM
  #42
graham c
graham c's Avatar
some work gone into that
Old 06-01-2012, 01:49 PM
  #43
Ginn L
Ginn L's Avatar
Cheers for the positive comments.
Haven't really got much done since I last posted, been a bit held up whilst waiting for more parts to turn up.
However I picked up my Cossie Engine on Wednesday, can't wait to fit it Here are some pics..
It had a Harvey Gibbs rebuild only 5 months ago, and hasn't even been run since.
The rebuild included, Forged Pistons, Main & Big End Bearings, Block Bore, Block Skim, Head Skim, New Plugs, Uprated Pump, WRC Head Gasket, New Gaskets/Seals, Crank Polish, Ported Head etc.
And it was already on a 200 Block, Long Studded, Siemens 83lb Injectors, Uprated Lifters, Kent Verniers, AP Racing Organic Clutch, and the GT3071R. Was running a L8 MSD management. As you can see, it's currently on a 4WD sump, but I have a 2WD one which will be changed very soon.
I've got a few plans for the Engine, need to get a few bits painted, polished & anodized first, Refurb the Cam cover. I may also fit a Hart plenum, and possibly a External Wastegate if required. I'll see how it goes.
My only concern at the mo, it wether the 2WD manifold is going to run too close to the inner wing. It will have a heat shield anyways, but I don't want to burn my paint. I'm sure we'll figure it out though.
Old 07-01-2012, 05:16 PM
  #44
Ginn L
Ginn L's Avatar
Got a few hours done on the car today, began welding the new top rail to the near side inner wing. Cut the pan supports off for the time being, since they need a few repairs.
That's most of the inner wing welded. We then welded up most the holes, since they're not necessary. And made a gusset for strengthening.
As you see, we made a lip which continued off the chassis rail, to make it look neater. Looks much better compared to the old bodged ones..
And this is the inner wing now..
Next job is repairing the pan supports and welding them back together, and then the drip rail. I'll get some pics up in the week.
Old 07-01-2012, 05:29 PM
  #45
Looks great
Old 07-01-2012, 05:55 PM
  #46
whizzisat114
whizzisat114's Avatar
Great work
Old 14-01-2012, 08:51 PM
  #47
Ginn L
Ginn L's Avatar
We've cracked on with the car a fair bit in the past week, it's really starting to make progress now. The rest of the panels arrived Tuesday..
Really pleased with the Mexico wings, their much better than I was expecting. However the front inner panel was pretty shite though. The slam panel doesn't line up with the Rad Supports like it should, so just going to order a new one next week. It was still handy to line up the inner wings though.
We first made a flitch panel for the nearside front wing.
Got the wing on, which surprisingly fit really well, but the flitch panel had to be lowered slightly.
Cut the off side inner wing off.
Lined up the new one.
The bodged up area on the inner wing was removed, but now as you can see the top plate doesn't quite come down quite far enough to marry up with the inner wing, so that will need to have a piece welded in. Luckily it's only a few mm.
Also managed to get the near side quarter in Reface today. Really pleased with how it's came out. We've put a more defined edge in the swage line as well as the arch. Which is different but still subtle. It's still not perfect, but it's almost there.
Next job is replacing both A-Posts and getting the inner wing welded on. We've welded up the front offside footwell as well today, but it's not quite finished. I'll get the pictures up Monday or something.
Old 14-01-2012, 09:44 PM
  #48
COLEYST200
COLEYST200's Avatar
Im in love very nice work
Old 14-01-2012, 10:27 PM
  #49
BON_300
BON_300's Avatar
cool keep it up m8
Old 14-01-2012, 10:58 PM
  #50
fezzajsy
fezzajsy's Avatar
looking good
Old 15-01-2012, 07:44 AM
  #51
graham c
graham c's Avatar
still loads to do but looking good their
Old 15-01-2012, 10:33 AM
  #52
Ginn L
Ginn L's Avatar
Cheers for the positive comments, much appreciated!
There's certainly a lot to do still, but most the welding is done. Just need to finish the front end. Make a roll cage, make a rear bulkhead, rear crossmember etc. I need to get a new dash for it as well. Once it's in paint it should all come together pretty quickly.
Old 15-01-2012, 12:07 PM
  #53
gavrwdfiesta
gavrwdfiesta's Avatar
loving this, i was following an audi the other day with the same name on it, then i clicked rah its a prestige build!!!! derrrrrrrrrr, love a mk 1 with that lump aintcha gunna nd wide rears ???
Old 15-01-2012, 12:27 PM
  #54
Ginn L
Ginn L's Avatar
Oh yeah that's my TT. I've got a Mk4 Golf show car you may seen about as well, in Bentley Alpine Green on BBS Super RS's. It's got a similar plate too.
And the rear arches have been extended but their still standard, so will hopefully run about 7.5 on the rear, and 7 on the front. Will see when I've got my axle fitted.
Old 15-01-2012, 03:07 PM
  #55
gavrwdfiesta
sweet
Old 15-01-2012, 04:03 PM
  #56
777johnny
777johnny's Avatar
very nice
Old 15-01-2012, 04:26 PM
  #57
Daveysaff
Skint Passionford User
Daveysaff's Avatar
Fantastic work so far!!
Old 18-01-2012, 08:11 AM
  #58
Ginn L
Ginn L's Avatar
Cheers for the comments. Got one offside A Pillar replaced last night.
Cut out the outer skin and welded the cut the new one in, the original was beyond rotten.
Old 18-01-2012, 09:13 AM
  #59
BON_300
BON_300's Avatar
Old 18-01-2012, 09:25 AM
  #60
Sengaaaa
Sengaaaa's Avatar
wow!! amazing work there fella
Old 18-01-2012, 10:13 AM
  #61
Fraggle...
On a tangent
Fraggle...'s Avatar
awesome to see a motor being restored/paneled up so thouroughly
Old 18-01-2012, 12:32 PM
  #62
Ginn L
Ginn L's Avatar
Cheers people
Got another repair done for under the flitch panel, have made it the same shape as the other side, how they are originally.
Will hopefully do the near side A Pillar tonight, I'll upload the pics later if I get time.
Old 19-01-2012, 01:20 PM
  #63
Ginn L
Ginn L's Avatar
Made the off side flitch panel last night.
Both sides are still free floating for the time being, to allow for adjustment with the wings. But the majority of it is welded.
Old 21-01-2012, 09:08 PM
  #64
Ginn L
Ginn L's Avatar
Repaired the offside footwell last week, only just uploaded the pictures.
Got the main shape of it, but may still need a little bit of beating about, but its basically there.
An we made a larger exhaust hole in the back panel, with a custom lip, which has came out really well. I'm going to run a full 3" pipe, so we didn't make it too big, just about right.
Then got the back panel all complete and the nearside rear quarter, and got them both in Reface.
The car is really getting well on the way now. Most people I speak to, think its a bit ambitious hoping to get it complete for May. But we think it's do-able
Old 21-01-2012, 10:16 PM
  #65
turnover
turnover's Avatar
looking good mate,should go well with that engine in,just make sure your axle is strong enough
Old 21-01-2012, 10:27 PM
  #66
Ginn L
Ginn L's Avatar
Cheers mate, I've always loved your old Mk2. That's some serious car!
And yeah I was planning on running an Atlas with Quaife Shafts and a Gripper LSD. From what I've heard that should take the power.
I'm not too sure yet though, a couple of people suggested using a Mustang or an Explorer axle. Only downside is that their massive, heavy and ugly.
Old 21-01-2012, 10:37 PM
  #67
Mark V8
Mark V8's Avatar
Brilliant job so far
Out of interest, did you get the blasting done at the lorry place in Thorpe le Soken ?
Looks like far less work than burning out electric drills with wire wheels!
Old 21-01-2012, 10:48 PM
  #68
Ginn L
Ginn L's Avatar
Cheers Mark. And no I got it done at a place in Witham called South East Galvanizers, their just off the A12 next to Essex Turbo's. We get all our customers cars done there, they do a thorough job. None of the car's panels get blasted obviously.
The place your thinking of is Simon Morris's, just opposite the station. That's only up the road from me. However they only really do commercials and HGV's.
But yeah, a sandblast or acid dip is a must do for any full restoration. Quite surprising to see whats hidden underneath the paint and filler. This actually looked like an ok shell before it was blasted
Old 21-01-2012, 11:15 PM
  #69
whizzisat114
Love the subtle touches like the arches and the exhaust clearence in the back panel
gonna be one special car when finished
i hope i enjoy looking around this as much as the saxon
Old 21-01-2012, 11:27 PM
  #70
Ginn L
Ginn L's Avatar
Thank you mate, their not really too noticeable which is kinda what I like about them. Quite a few people wouldn't notice the difference in the arches without comparing it to a standard car.
An haha hopefully you will, I'll do my best
Old 21-01-2012, 11:45 PM
  #71
whizzisat114
Cannot praise the work your Dad did on the saxon absolutely top shelf fabrication
inspiring fabrication
glad he's involved with this project
Old 22-01-2012, 01:05 AM
  #72
Ginn L
Ginn L's Avatar
Yeah the fabrication on the Saxon was definitely quite involved, obviously a lot more than this.
An I'm glad he is, because the car wouldn't hold together very well with my fabrication/welding skills
Old 22-01-2012, 09:18 AM
  #73
graham c
graham c's Avatar
you,ll be surprised wots under paint
Old 22-01-2012, 10:11 AM
  #74
M K
M K's Avatar
outstanding effort, love it
Old 22-01-2012, 09:38 PM
  #75
turnover
turnover's Avatar
atlas should be ok just depends on how much grip you have,you could put an 8inch in, fit and forget and alot cheaper
Old 22-01-2012, 11:14 PM
  #76
Ginn L
Ginn L's Avatar
Cheers mate, much appreciated. Your JWRC build is looking the bollocks, will be good to see it when complete!
Ok great cheers, I have considered an 8", only thing that puts me off is the size and look of it. They're just ugly. I'll have to decide soon though what to do.
Old 23-01-2012, 08:10 AM
  #77
BON_300
BON_300's Avatar
Old 24-01-2012, 07:09 PM
  #78
chap foose
chap foose's Avatar
Very nice Ginn junior.
Great work again Colin,one of the top car builders/restorers in the country imo,atb Chapfoose
Old 24-01-2012, 08:43 PM
  #79
Looking great
Old 30-01-2012, 08:13 PM
  #80
Ginn L
Ginn L's Avatar
Cheers Foose an Dave/Stu!
Got a bit more done at the weekend.
Off side Gusset welded in.
Near side A post done, the outer skin was cut out first of course.
Then started on making the rear bulkhead/fire wall. Will have to be made in 5-6 pieces, but we began making the sides. Used slightly thicker steel to prevent distortion when welding the main pieces together.
Both sides have been made and welded in now, I'll get the pictures up in the week.
Quick Reply: My Mark One Escort Build
