ZVH to Zetec
ZVH to Zetec
Was asked to put some pics up, so will do the latest rebuild of the Engine etc. Engine is completed so this is historic
Donor Engine
ST170 Inlet Manifold to be ported
ST170 Injector Rail to be ported with Subaru P1 850cc Injectors
What no engine
New Fuel pump and lines required as old pump and lines are too small
Donor Engine
What no engine
Some more Pics:
Inlet Manifold with injector plate ported
New -10 Fuel line with a -8 Return, bit of a size increase from a -6
New Fuel pump with -10 feed line
Rocker Cover given a coat of paint
Pressure Regulator and gauge for fuel rail
Old and New clutch plates, its going to be heavy, so
Hydraulic Clutch Pedal in the making, idea off Performance ford
Hydraulic Clutch
16V Head
16V Head showing the valves and ported inlet ports
16V Head with RS Turbo Exhaust manifold and edge of Kent Fast road cams box
View of the forged pistons
There is an interference on the manifold to strutbace, some modification required to the strut brace
From underneath
Paul at AJK Motors is really getting it done, reckons we may have a base map tomorrow and a test fire
Mark Shead on Right playing with map after run, temps too high. ACTS of 65 degrees
Sadness, put it back on the truck
Adjustable backend arms, though I loose the rear anti roll bar connection and not sure of the setup
Quick sketch to describe what i'm asking
PS its coilovers so springs are not in way, and this is for adjustable rears. I found the answer on Passion Ford
Track Day 25/08/2011. Not a good day the baffled sump blew oil all over the font offside wheel causing heart stopping moment when braking down from 120 to 30 and thinking I wasnt going to make the corner but plough on.
Just arrived in the post, a cd with some photos from the day
Album Link <<<
Album Link <<<
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
