Time Attack ST170 - Few new pics 24/06
Old 29-04-2012, 02:51 PM
  #401
fordrallycar
fordrallycar's Avatar
Great work fella
Old 02-05-2012, 02:27 PM
  #402
Marcus-young
Marcus-young's Avatar
hi mate, been keeping an eye on your thread for a quite a while, very interesting read.. im building a similar spec car myself, which eventually ill get round to doing a buildthread for. just got a quick question for you, its a little random, but where the rear control blade mounts to the chassis, what have you used for bushing mateial? as from the picture it appears not to be polyurethane. my rear toe and upper links are rose jointed, and i think i will do the same with the spring seat. i am woried about rose jointing the control blade mount though, as i am thinking that there may need to be some compliance in this joint. unfortunately i cant seem to find anybody who has done anything other than poly bushes for rear suspension on the focus
Old 02-05-2012, 09:49 PM
  #403
Big Will_
Borg Warner EFR Equipped!
Big Will_'s Avatar
Location: In the unit, building a 450bhp Time Attack Focus!
Marcus - i'm using Vibratechnics on the rear control blades. I'll let you know how they behave!
I'm trying to get the car up and running first on 'basic' handling upgrades and then can start to evolve and upgrade when back to back testing is possible.
Rightio! Updates!
Knocked up my oil return:
And got it fitted:
Then moved onto prepping the engine bay, first up was to wrap the selector cables in DEI gold and make a new heatshield out of Nimbus G2 for the power steering:
Bits of spare nimbus make for very good blanking plates!
Then it was on with brake line routing, mounting etc.
Oil lines got P Clipped in too:
Then time to fit a new slave cylinder in the gearbox:
And then...
This happened
Old 02-05-2012, 11:18 PM
  #404
turnover
turnover's Avatar
looks impresive
Old 03-05-2012, 09:03 AM
  #405
lanfire
lanfire's Avatar
wheyyy looks better in there now ! im assuming theres enough bonnet clearence for that inlet?
Old 03-05-2012, 09:04 AM
  #406
COCHYN
COCHYN's Avatar
Cracking Will
Old 03-05-2012, 10:58 AM
  #407
Big Will_
Big Will_'s Avatar
Cheers guys!
Yes, the bonnet does clear, only by a fingers width or so!
I might yet have to fit bonnet raisers, but i'm trying to avoid it if I can
Old 03-05-2012, 02:11 PM
  #408
cjwood555
cjwood555's Avatar
Looking very neat will
Old 03-05-2012, 02:20 PM
  #409
Marcus-young
cheers for that will, had a quick look on vibratechnics they appear not to sell them, so dropped them an email, waiting for a response. yours is looking the business, especially now you got the engine in. looking forward to mine being at that stage, little way off yet though
Old 03-05-2012, 07:44 PM
  #410
LIMITLESS
LIMITLESS's Avatar
Engine looks nice sitting in its home
Old 03-05-2012, 09:23 PM
  #411
Big Will_
Big Will_'s Avatar
Just a quick update as i've been in uni all day...
Earlier in the thread I said I was planning to use hardlines for my wastegate reference pipes given the proximity to the manifold etc.
So, tonight I got them done!
Shot from the top to show that they don't come any further forward than existing stuff, so clearance from the rad shouldn't be an issue:
With the air filter and things on to check clearances:
Hopefully over the next 3 days i'll make some more noticeable progress!
Old 03-05-2012, 09:49 PM
  #412
Gary_Hurn
Gary_Hurn's Avatar
Looks brilliant..been following with interest from beginning, top quality
Old 03-05-2012, 10:20 PM
  #413
NEEDFORSPEED
NEEDFORSPEED's Avatar
wowsers!!!!
Old 04-05-2012, 10:08 AM
  #414
TimC
TimC's Avatar
With the external gates are you not supposed to use plumb both sides of the diaphragm? Or you just going to let them bleed the air until necesary?
Old 04-05-2012, 01:15 PM
  #415
Big Will_
Big Will_'s Avatar
The only benefit of plumbing into the top of the gates is to counter the wastegate lifting early if the spring is weak. Mine are both sprung at 1 bar so shouldn't be an issue!
Old 04-05-2012, 03:05 PM
  #416
thielt1
thielt1's Avatar
are you bending your own hardlines, if so what are you using for a tool? Also are there any disadvanatages to using them?
Old 04-05-2012, 10:41 PM
  #417
Big Will_
Big Will_'s Avatar
Originally Posted by Mark RS
1st class work there
Yes, made my own hardlines. Tooling wise, I used a handheld forming tool, cost about Ł40 from memory, does 3 different size tubes up to 180 degrees. Also, there's a special flaring and deburring tool, that was a bit pricier, about Ł120 I think. And the hardline tube isn't cheap either
Anyhoo, did a bit more today
Got the slam panel back from the paintshop - there was NO WAY this was getting vinyl wrapped
Got the breather system finished:
Fitted the brand new power steering reservoir:
Mocked up the cooler in the freshly painted front end:
Made up and fitted all the new power steering lines:
How everyone spends their friday nights right?
Old 04-05-2012, 10:45 PM
  #418
NoRubNoDub
McGarrity Motorsport
NoRubNoDub's Avatar
tasty are you planning on doing a late one?
Old 04-05-2012, 10:50 PM
  #419
Big Will_
Big Will_'s Avatar
I've done 16 hours today lol. Time for a shower, some kip and back on it tomorrow! Missing the start of the Time Attack season has given me a big incentive now!
Old 04-05-2012, 11:01 PM
  #420
Sticky.
Sticky.'s Avatar
Getting there son.
Old 04-05-2012, 11:13 PM
  #421
NoRubNoDub
NoRubNoDub's Avatar
Good days work then whens the next round? Did you not fancy taking a run to Cadwel for a snoop at the competition?
Old 04-05-2012, 11:43 PM
  #422
Big Will_
Big Will_'s Avatar
I did want to go and have a mooch around the pit lane. A lot of good friends are running this year and it would have been nice to catch up, but, as the variable valve timing aspect of the engine is also my dissertation topic for uni, I can't really spare a day out at the moment. Hand in is 2 weeks away!
Old 05-05-2012, 02:15 PM
  #423
gjh
gjh's Avatar
Coming on really nicely!
Old 05-05-2012, 02:18 PM
  #424
Canada1
Canada1's Avatar
Beautiful!
I suspect the front tires will not last long
Old 05-05-2012, 10:51 PM
  #425
Big Will_
Big Will_'s Avatar
Cheers guys!
Pushing hard with it now - even though todays photos don't show a lot, there was a lot of final cleaning, thread checking and final fitting type stuff going on that wasn't really worthy of pictures!
Got my new thermostat housing through from Ricky this morning, needed a little bit of fettling to get the coolant temp sensor in (can't see it in this picture):
Got the remaining lines made up - just need to get some universal silicone hose bits and some joiners now to finish my top hose off:
Getting more built up:
All covered up with slam panel lol:
Old 06-05-2012, 07:58 AM
  #426
TimC
TimC's Avatar
Come on then Will, when is first turn of the key planned?
Old 06-05-2012, 08:49 AM
  #427
Big Will_
Big Will_'s Avatar
Soon as it's ready! Hopefully by the end of the week
Old 06-05-2012, 09:04 AM
  #428
COCHYN
COCHYN's Avatar
Almost a shame to have that slam panel covering up all the goodies! Looks great Will
Old 06-05-2012, 09:21 AM
  #429
pee vee
pee vee's Avatar
Now that is truly impressive! Nice one!
Old 06-05-2012, 09:56 AM
  #430
Vic
Vic's Avatar
wow!
Old 06-05-2012, 10:03 AM
  #431
fezzajsy
fezzajsy's Avatar
looking perfect
Old 06-05-2012, 11:47 AM
  #432
TimoXr4i
TimoXr4i's Avatar
Wow, never seen an ic lake thaton a car, only on a truck r a bus, its huge! Its gonna be a sweet ride! Is this the b&w turbo? Searched it online for how it works, but it aint exactly clear, but, it must spool up really fast? Make a film when you startup, i want to hear the beast!
Timo
Old 06-05-2012, 11:50 AM
  #433
rs_traynor
stage4 2wd cosworth
rs_traynor's Avatar
looks really good
Old 06-05-2012, 12:52 PM
  #434
LIMITLESS
LIMITLESS's Avatar
Looking very good
Old 06-05-2012, 03:06 PM
  #435
Gary_Hurn
Gary_Hurn's Avatar
Looks excellent mate
Old 07-05-2012, 08:58 PM
  #436
That looks really impressive mate.That turbo is massiveeeeeeee.
Old 07-05-2012, 09:03 PM
  #437
rhinopower
rhinopower's Avatar
Do you have a picture of where the oil feed is coming from?
Old 07-05-2012, 09:06 PM
  #438
paul16v
Monte 087
paul16v's Avatar
Spot on that Will
Old 07-05-2012, 09:20 PM
  #439
AJC
AJC's Avatar
Good work big man
Old 07-05-2012, 09:24 PM
  #440
SMILER258
SMILER258's Avatar
sweet, shouldnt be long now till its completed
Quick Reply: Time Attack ST170 - Few new pics 24/06
