| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
Thread Tools | Search this Thread | Display Modes |
#401 | ||||
#402 |
hi mate, been keeping an eye on your thread for a quite a while, very interesting read.. im building a similar spec car myself, which eventually ill get round to doing a buildthread for. just got a quick question for you, its a little random, but where the rear control blade mounts to the chassis, what have you used for bushing mateial? as from the picture it appears not to be polyurethane. my rear toe and upper links are rose jointed, and i think i will do the same with the spring seat. i am woried about rose jointing the control blade mount though, as i am thinking that there may need to be some compliance in this joint. unfortunately i cant seem to find anybody who has done anything other than poly bushes for rear suspension on the focus
#403 |
Borg Warner EFR Equipped!
![]() Trader Score: (0)
Location: In the unit, building a 450bhp Time Attack Focus!
Rep Power: 14 ![]() |
Marcus - i'm using Vibratechnics on the rear control blades. I'll let you know how they behave!
I'm trying to get the car up and running first on 'basic' handling upgrades and then can start to evolve and upgrade when back to back testing is possible. Rightio! Updates! Knocked up my oil return: ![]() And got it fitted: ![]() Then moved onto prepping the engine bay, first up was to wrap the selector cables in DEI gold and make a new heatshield out of Nimbus G2 for the power steering: ![]() Bits of spare nimbus make for very good blanking plates! ![]() Then it was on with brake line routing, mounting etc. ![]() Oil lines got P Clipped in too: ![]() Then time to fit a new slave cylinder in the gearbox: ![]() And then... This happened
__________________
Sierra Cosworth RS500 Time Attack Focus ST170 E46 330d Touring **Take a look at my Time Attack build!**
#404 |
looks impresive
__________________
9.7@143 mph http://www.youtube.com/watch?v=kF1Ep...endscreen&NR=1 http://www.youtube.com/watch?v=05tDJOa1VIM |
#405 |
wheyyy looks better in there now ! im assuming theres enough bonnet clearence for that inlet?
#406 |
Trader Score: (0)
Rep Power: 0 ![]() |
Cracking Will
#407 |
Cheers guys!
Yes, the bonnet does clear, only by a fingers width or so! I might yet have to fit bonnet raisers, but i'm trying to avoid it if I can
__________________
#408 |
Looking very neat will
__________________
Mondeo ST24... |
#409 |
cheers for that will, had a quick look on vibratechnics they appear not to sell them, so dropped them an email, waiting for a response. yours is looking the business, especially now you got the engine in. looking forward to mine being at that stage, little way off yet though
#410 |
Engine looks nice sitting in its home
#411 |
Just a quick update as i've been in uni all day...
Earlier in the thread I said I was planning to use hardlines for my wastegate reference pipes given the proximity to the manifold etc. So, tonight I got them done! ![]() ![]() Shot from the top to show that they don't come any further forward than existing stuff, so clearance from the rad shouldn't be an issue: ![]() With the air filter and things on to check clearances: ![]() Hopefully over the next 3 days i'll make some more noticeable progress!
__________________
#412 |
Looks brilliant..been following with interest from beginning, top quality
#413 |
wowsers!!!!
__________________
[CLICK TO SEE MY SAPH RESTO!! http://www.passionford.com/forum/viewtopic.php?t=240033 |
#414 |
With the external gates are you not supposed to use plumb both sides of the diaphragm? Or you just going to let them bleed the air until necesary?
__________________
Tim ![]() For all your braking and suspension needs ~ Contact NUTs RuS for any questions or enquirys. For all your stickers ~ Email stickerpaul@yahoo.co.uk |
#415 |
The only benefit of plumbing into the top of the gates is to counter the wastegate lifting early if the spring is weak. Mine are both sprung at 1 bar so shouldn't be an issue!
__________________
#416 |
are you bending your own hardlines, if so what are you using for a tool? Also are there any disadvanatages to using them?
#417 | |
Quote:
![]() Anyhoo, did a bit more today Got the slam panel back from the paintshop - there was NO WAY this was getting vinyl wrapped ![]() ![]() Got the breather system finished: ![]() Fitted the brand new power steering reservoir: ![]() Mocked up the cooler in the freshly painted front end: ![]() Made up and fitted all the new power steering lines: ![]() How everyone spends their friday nights right?
__________________
#418 |
McGarrity Motorsport
tasty are you planning on doing a late one?
#419 |
I've done 16 hours today lol. Time for a shower, some kip and back on it tomorrow! Missing the start of the Time Attack season has given me a big incentive now!
__________________
#420 |
Getting there son.
#421 |
Good days work then whens the next round? Did you not fancy taking a run to Cadwel for a snoop at the competition?
#422 |
I did want to go and have a mooch around the pit lane. A lot of good friends are running this year and it would have been nice to catch up, but, as the variable valve timing aspect of the engine is also my dissertation topic for uni, I can't really spare a day out at the moment. Hand in is 2 weeks away!
__________________
#423 |
Coming on really nicely!
#424 |
Beautiful!
I suspect the front tires will not last long Cheers
__________________
1968 Ford XL 514 cu in 1970 Porsche 911 3.4 50mm PMO carbs 1987 Escort RST clone |
#425 |
Cheers guys!
Pushing hard with it now - even though todays photos don't show a lot, there was a lot of final cleaning, thread checking and final fitting type stuff going on that wasn't really worthy of pictures! Got my new thermostat housing through from Ricky this morning, needed a little bit of fettling to get the coolant temp sensor in (can't see it in this picture): ![]() Got the remaining lines made up - just need to get some universal silicone hose bits and some joiners now to finish my top hose off: ![]() Getting more built up: ![]() All covered up with slam panel lol:
__________________
#426 |
Come on then Will, when is first turn of the key planned?
__________________
#427 |
Soon as it's ready! Hopefully by the end of the week
__________________
#428 |
Trader Score: (0)
Almost a shame to have that slam panel covering up all the goodies! Looks great Will
#429 |
Rep Power: 16 ![]() |
Now that is truly impressive! Nice one!
__________________
![]() Focus RS number 1215. |
#430 |
wow!
#431 |
looking perfect
#432 |
Wow, never seen an ic lake thaton a car, only on a truck r a bus, its huge! Its gonna be a sweet ride! Is this the b&w turbo? Searched it online for how it works, but it aint exactly clear, but, it must spool up really fast? Make a film when you startup, i want to hear the beast!
Timo |
#433 |
stage4 2wd cosworth
looks really good
__________________
cheeRs Rs_traynor ![]() 390bhp/391lbft stage4 2wd cosworth mapped by MSD. 300bhp supercharged focus built by torque of the devil. |
#434 |
Looking very good
#435 |
Looks excellent mate
#436 |
Chasing Radders
Trader Score: (1)
Rep Power: 44 ![]() |
That looks really impressive mate.That turbo is massiveeeeeeee.
__________________
#437 |
Do you have a picture of where the oil feed is coming from?
#438 |
Monte 087
Spot on that Will
__________________
#439 |
Lord of Longridge
Good work big man
__________________
Cheers, Andy ![]() 11.93 1/4 mile @ 116.9mph - Santa pod Lancashire RSOC Group Chairman |
#440 |
The RUST hunter!!
sweet, shouldnt be long now till its completed
__________________
Cheers, Nathan. My XR4X4 rally car restoration - http://passionford.com/forum/restora...7-12-11-a.html
| Display Modes | |
