supra diff into cossie beam
Old 10-11-2011, 07:45 PM
Turbosimpsons
Turbosimpsons's Avatar
Default supra diff into cossie beam
just had these dropped off, so i can fit a supra diff into my 6deg. cossie beam.
Old 10-11-2011, 08:13 PM
Mark V8
Mark V8's Avatar
That's the driveshafts sorted
How much work to fit the diff ?
Old 10-11-2011, 08:22 PM
scoooby slayer
scoooby slayer's Avatar
will be fit and forget mate for sure
Old 10-11-2011, 08:31 PM
busa bob
busa bob's Avatar
MMM interesting
Cant wait for update i was thinking of goin jag route myself but more options there is the better
Old 10-11-2011, 09:51 PM
Turbosimpsons
the advantage of going supra route is it will fit in a standard or 6deg beam with no mods to the beam at all. it's a straight bolt in job.
Old 10-11-2011, 09:56 PM
Turbosimpsons
it like most things when going a unconventional route it takes some work making the brackets and adapters. but i aint paying Ł3500 for a ford 9" diff (if you can get 1) and there isn't many other options.
Old 10-11-2011, 09:57 PM
Turbosimpsons
so i guess your diff is still holding out ok.
Old 10-11-2011, 10:45 PM
busa bob
busa bob's Avatar
So what do i need to ask for regarding diff? Any certain ratio? type? model?
And what shafts? also where do i get them spacers?
Rob
Old 11-11-2011, 06:03 AM
Ade500
Fixing Fords
Ade500's Avatar
I like the sound of this
Old 11-11-2011, 06:09 AM
COCHYN
COCHYN's Avatar
This is a mod I want to do next, don't trust my standard diff, regardless of how many low miles it has
Old 11-11-2011, 06:11 AM
This sounds interesting.Get some more pics took and do a step by step guide.
Old 11-11-2011, 06:40 AM
rs_traynor
stage4 2wd cosworth
rs_traynor's Avatar
im interested in this aswell, what is the diff out of turbo or non turbo supra or are they both the same?
Old 11-11-2011, 06:53 AM
scoooby slayer
yes mate admitadly havnt used the car since pod needs a few issues sorting but diff has taken some abuse no problem.
Old 11-11-2011, 07:18 AM
Gazzonator
Gary Krishna
Gazzonator's Avatar
Really?!! Even all the bolt holes line up and everything?
I might be well up for this!!
Old 11-11-2011, 07:52 AM
Karl 3dr
Karl 3dr's Avatar
Me too! Sounds too good to be true lol
Old 11-11-2011, 08:45 AM
focus 4x4
focus 4x4's Avatar
Hmmm very interesting
Old 11-11-2011, 08:50 AM
Phil2002
Phil2002's Avatar
very interesting get some more pics up please.
cheers,
Phil
Old 11-11-2011, 09:03 AM
Blades Rally Team
Blades Rally Team's Avatar
Default Supra Diff Conversion
Me to Very interested do you have a drawing for the drive shaft adaptors?
Old 11-11-2011, 09:05 AM
scoooby slayer
lol it wont be bolt in fit guys, what he means is it physically fits in the hole so its just adaptor plates needed.
Old 11-11-2011, 09:19 AM
Chip
*** Sierra RS Custard ***
Chip's Avatar
Presumably need an adaptor for the prop as well?
Would be great to see it documented in detail.
How much do the supra diffs go for? I assume they are LSD?
Old 11-11-2011, 09:52 AM
COCHYN
COCHYN's Avatar
They're quite cheap and pretty common diffs Chip, and I only looked at 2 breakers
If someone that's already made the kit up, like MK has a ready made conversion bracket for the diff to beam and the flanges for the shafts to diff, then most people will snap them up I bet.
I want one!
Old 11-11-2011, 12:32 PM
Phil2002
Phil2002's Avatar
https://passionford.com/forum/genera...erra-beam.html
Old 11-11-2011, 05:21 PM
Turbosimpsons
Im believe there is kit out there. Fraser has just bought 1.
Old 11-11-2011, 07:38 PM
ts.tm.jb.fingers
ts.tm.jb.fingers's Avatar
hello john,is that kit custom made,if so bet that was a lot off work for someone,a lot off hard work,top off the line kit from what ive heard,
Old 11-11-2011, 08:31 PM
Turbosimpsons
Yes all custom fit stuff. All proper made. Some top fabricators on the job.
gcfcos
59
06-10-2015 05:04 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
Iain Mac
30-09-2015 09:39 PM
cossie330
27-09-2015 04:13 PM
DavidK
27-09-2015 02:55 PM
Quick Reply: supra diff into cossie beam
