Rally Sierra xr4x4 R.I.P 25/09/15
#123
Reet, update time. The drivers side floor pan is close to nearly being welded up. The drivers side transmittion tunnel is now solid. I have a small patch AGAIN on the passenger side. I just need to make a patch for where the drivers floor is half way. I also welded all the tiny holes up. I'm just gonna drill less for the onboard fuel and brake lines.
I can get pics if wanted.
Comments welcome
Comments welcome
#124
Yes we want pics!
#128
Do you do the welding yourself? Thats not bad at all!
#129
Yes all welding is done by me. It's useful having a car that's this rotten as by the end of it I shall be pretty good at welding And having a clean piece of metal helps, as I found out today. By the way, the floor is nearly welded up. Will update tonight
#132
Fair play to you! Think it its good that you can weld when you want to take up rallying.
#133
My dad made it for me. It is a basic triangle frame, with various supports, and a drum brake system, so I can put the brake on in any position I want, and it can be set up for any car.
#140
Hi Nathan,
Reading through your thread. I give you a pat on the back. You'r very brave to take on work like this. It's like the car has some major rust cancer and you just taking it away. Well done mate.
Good luck on your resto. You've got skills.
#141
Hello The car does seem to have mega tin worm, but it's solid where other sierras aren't. The front wings are near dam perfect, but the rear quarters, rear drivers arch and rear panel are crumbling away. And thankyou for the kind words, means a lot
#142
Just a wee update. Renovated some parts. Sand blasted them, cleaned em up, primed them, then painted them.
Brake and clutch pedal
Starter motor
all the brake discs
other stuff
pics now
Starter motor
all the brake discs
other stuff
pics now
#154
Very cool! You got access to a pit? I'm jelous? Do you have your own sand blaster or are the parts sent away or something?
Top work Nath
Top work Nath
#156
Very cool (x2). Its coming on great with you.
#158
Hi Nathan,
Found your Thread from my Photo thrwad of Fullbeck, great work going on here pal! keep it up, makes me want to get back in the garage and start my project off again
I see your not a million miles from me either! let me know about any road rallys mate!
Add me on FB if your on there, Im James John Brunton.
CheeRS James
CheeRS James
#159
Hi James, yeah, I was reading your Saff project this morning, can't wait to see it in paint! The cage is awesome And yeah, I'm doing the Mercian in Hull later this year, Results team, so doing some marshalling too. Always a great event. Added you on Facebook by the way.
#160
Any updates Nath?
