moonstone 3 door tidy supra diff, zeitronix, rota gtr's
#164
sure is. well she went on the road last thursday.......on monday the turbo blew up apparently t34's dont like running 38psi. turbo was taken off & sent off to cr turbos on wenesday. got it back on saturday morning so shes back on the road now. still loads of jobs to do but its slowly getting there. its just nice to be able to drive it about. oh the welded diffs loads of fun but cant see the tyres lasting long (or my licence) so anyway, heres some pics
the breather tank only had 16mm inlets & i wanted 19mm so a mate of a mate milled some very nice pipes & someone else (the same guy that did alot of alloy fab work on rosies cossy mk3 escort) welded them on
painted & fitted
heat wrapped the manifold (badly)
also did the wiring & cables
this stuff wasnt anywhere near as goo as the stuff i used on the down pipe. you can actually grab the downpipe after giving it a good spanking & its only as hot as a cup of tea
rebuilt turbo
fibreglass rs500 front bumper. quality is pretty poor but at £80 delivered im not complaining. not nothing i cant put right. really cant wait to get it sorted, painted & fitted
ironx'd the car last week & was really impressed with the stuff (you could have filed your nails on the paint) today ive clayed both sides of the car & had a quick run over with the mop. still got the boot roof bonnet etc to do
taken a few pics in the sun this afternoon
my little baby
on the look out for burglars lol
also fitted the alpine out of my saff
ill order some of these sometime next week
http://www.ebay.co.uk/itm/8433-Car-B...14853956266991
painted & fitted
rebuilt turbo
my little baby
#168
fitted the door moulding today with some advice from brammer. there not originals but cheapo ebay ones. ive not got to worrie if i want to do any paint in the future. just rip them off, throw them away & replace with new ones
heres the 5m roll ready to cut
used some 2" angle as a straight edge
almost straight lol
i dont think it looks too bad for £30
almost straight lol
#169
Good of £30, don't think I would like the £265 of the other repo one. Hope bumper comes out ok the real ones are far to much money now. Glad I bought a new one a few years ago along with splitters when Brooklyn ford had them all remanufactured. They were looking into header tanks at the time as well but unfortunately it didn't come off.
#175
came very close to loosing the car today to fire. the fitting at the bottom of the fuel pressure regulator came undone & was pissing huge amounts of fuel all over the dizzy cant believe how luck i am that it didnt go. i wouldnt even want to imagine how it would feel to stand there helplessly & watch it burn!!! LUCKY ESCAPE
anyway, this week ive managed to get the fibreglass rs500 bumper painted. the quality of the bumper was poor, but i didnt expect to to be very good considdering that it only cost £80 delivered. nothing that couldnt be easly sorted. both sides of the bumper were made in to parts (probably to get it out of the mould easyer) & wernt lined up correctly & stuck out. i had to ass a couple of layers of fiberglass to the back to make it thicker so i could grind down the front to make it flush. it was then filled & sanded. i didnt have time to trial fit so went staright in with the paint. i could do with a little more tweeking then painting again but ill do that at a later date. it cost £80 for the bumper & £20 for some fiberglass so in all impretty happy.
i painted the back matt black then let it get covered in moonstone overspray. thought it would look better like this rather than white fiberglass
#177
cheers. dont know what his name is. hes the guy selling the white 3dr on ebay for 7.5k. the fit isnt great but the original 3dr bumper didnt fit that great. come to think of it its very rare i do see a cossy (saff or 3dr) with a good fitting front bumper
#178
Pick-up P100 Power!
Put you bumper irons as low as they will go to lift the bumper up to the grille and that should also give you straigh line on the arches too.
You should be proud! She looks stunning! If my P100 comes out half as good ill be over the moon(stone).
#179
i got the bumper 'new' secondhand on ebay. i believe its the one that normally retails for £120 delivered. as i said the quality is piss poor but as i only paid £80 deliverd its not a problem. the bumper irons are as low as they can go but i can elongate the holes with a grinder to get a little more lift. the gap between the bumper & wings is huge but that not difficult to fix with fibergalss. ill sort it at a later date when i have time
#181
#184
I know you have put a lot of effort into the bumper, but it unfortunately is a poor copy and spoils all the other work you have done to the car. I would refit original bumper and try to find a better repo bumper if you can, original would be best but to expensive now. Other than that the car is superb.
#190
If you can get some support inside it to keep it level and get it to lift at the front and meet the arches better then it will probably be ok, could you not get a standard sierra bumper and use the inner frame with this skin on it, should offer lots of support then.
#193
bit of an update. a couple of weeks ago i had a bit of an 'incident' involving the rear wheel and a kerb. the kerb won & resulted in a fucked wheel & a bent trailing arm/rear beam
whilst the car was off the road i decided to address the clutch problem as it was far to heavy making the car awfull to drive & also almost impossable for my pregnant wife to drive. it has a full ap paddle kit but lockie kindly donated a mint standard pressure plate to use with the ap paddle drive plate. its still a little heavy but much better. gonna try changing the cable & quadrent next.
the damage from the accident wasnt too bad & the car drove home but rather than having negative camber the wheel sat upright. i couldnt actually see what was bent (trailing arm or beam) so i decided replacing the lot. i had a pair of spare arms so modified these & scorced a new beam & sent the lot off to the powdercoaters. unfortunatlly the wheel was fooked. not only was the outside of the rim damaged but the inside also had a wobble, indicating that the spokes must have been slightly bent. there was no choice to bite the bullet an order a new wheel from revolution
the car was put back together yesterday and is fine now & still drives straight
not really sure what to do with the car at the moment. been thinking about selling it as i got a little one due in august so i doubt ill have any spare time to spend on the car for quite some time after that
anyway heres a few pics
the old mikalor clamps were crap so i got these off ebay. there nice & tight & seal really well
anyone know what the cars likely to be worth if i do decide to sell?
#198
i did head u bashed a kerb (urve spent to long in fwd cars ), atleast it wasnt anything major & was all bolt on stuff.
mines off for paint tomorrow!! so plenty to do when back on that.
if u see any cheap cossies about give me a txt as geting tempted again lol
