moonstone 3 door tidy supra diff, zeitronix, rota gtr's
#132
done some more
before
after
painted fuel lines
got a weleded diff off j1mbo, should meake life interesting lol
changed the .48 exhaust housing for a .63
new speedo cable
welded a skid plate to the centre box
mikalor clamps for the exhaust
new turbo oil feed
had a stainless pipe made from the pump to the filter
new power steering pipe
fuel feed & return pipes. there is a pressure gauge to go in the feed pipe, once the pressure has been checked & adjusted if need be, it will be removed & blanked
swirl pot painted
prop painted
before
after
painted fuel lines
new speedo cable
new turbo oil feed
swirl pot painted
prop painted
#137
spent most of today working on the 3dr
fittings on the fuel pressure regulator to take the braided hose
braided hose fitted to the hard lines
the threads were gone for the prop centre bearing so they were drilled, tapped & helicoiled
braided powersteering hose fitted
swirl pot fitted
taken the front braked off the saff, the diskes were going rusty so i thougt the 3dr could clean them up untill the saff goes back on the road (if it ever does)
swirl pot fitted
#146
i was originally going to use the rl7's on the 3dr but the offset isnt really that good & they dont clear the front shocks. the cam cover is really easy to do. just mask up the silver & letters & paint in wrinkle black then brush paint the letters after. if you really want, send me your cam cover & ill do it for you
#147
added some extra cut outs to the air box
cv joints cleaned & painted, rady for re assembly
a mate, tony, made me this. its for the oil return on the breather. it will return the oil under the oil level in the sump to stop it trying to breath up it
braided hose for the breather
got some new plugs for the injectors & new pins to replace any damaged ones
finally this is how the bay is now looking. ive painted the windscreen washer bottle as i didnt like it looking mankey
#155
Rear cv joint
Hi mate fantastic work,how did you get your rear driveshafts plated on outside only i didnt realize it could be done that way was it easy to sort.......
#158
as of the weekend the cossy now runs & drives. i was happy that it started pretty much on the key. there's still loads of small jobs that need doing but ill be taxing it at the end of the month. anyway heres some pics.
made a fan loom
fitted the rs500 lip with tiger seal
ive also bought a fiberglass rs500 front bumper so im looking forward to getting that & getting it painted & fitted
made a fan loom
