ford sierra 2.0CL Restoration
Old 01-10-2011, 12:20 AM
eli3
eli3's Avatar
Default ford sierra 2.0CL Restoration
Hello
My name is Eli, I'm from Israel
I own a Ford Sierra 2.0
Year 1988
Pinto engine carburetor pierburg 2E 205
TRANSMISSION TYPE-9
Hence continue the pictures:
new air filter
new fuel filter
New water pump
For some reason the previous owners decided to pull the thermostat
New thermostat ->
Rear bumper replacement
old oil
New oil filter
Old exhaust
New exhaust
New plugs and Leads
I canceled the mechanical fan and I changed it to an electric fan
new fan to radiator
(Originally conditioner condenser fan)
Radiator cleaning was carried out using high pressure water (not photographed)
Previous bumper was a Scorpio
New front MK3 bumper
I have a question for people here Ford Specialists
Original paint my valve cover is the color shown above:
There is a chance this engine has a cylinder head of Pinto 2.0I? [Injection cylinder head]
I think so because the engine was not original to this car, and because I saw that Pinto carburetor with a black valve cover and Pinto injection valve cover came with this color.
Am I right?
Fix some electrical problems behind the dashboard
Air-conditioning, lighting, buttons, etc. ..
Now everything works
A good friend brought me a valve cover of Pinto 1.6
I buffed it and I painted it well off the heat
Hope to wear it soon
fiberglass pod gauge:
Japanese "finishes" Recent
test
:smash:
shocks:
(Right: New
Left: Old)
Thank you saw until now
This is for now
I do not have much time to work on the car so I work slowly
All that I had in 5 months.
Hope to finish with the "alignment line" quickly so I could start with the improvements
Hope to get more ..
eli
Old 01-10-2011, 04:30 AM
Nice project.I thought there was something od about the original front bumper.
Keep up the good work.
Old 01-10-2011, 11:23 AM
eli3
eli3's Avatar
Yes, he was a Ford Scorpio, I think the MK1 ..
Anyone know anything about valve cover?
Thanks Glenn
Old 02-10-2011, 09:21 AM
R4N SS
R4N SS's Avatar
It looks fairly solid.
One way to check if it's an injection head is to look at the inlet ports, they should be pear shaped and non injection ports are rounder
Old 02-10-2011, 11:10 AM
eli3
eli3's Avatar
Yes I know that the best way to see it as ports of the head and I also know exactly how the injection ports, but I ask before I break the intake manifold if there was any way to check
If this injection head, I put the injection. If I replace my carburetor carburetor seems to WEBER 30 \ 34 or to WEBER 32 \ 36 [depends on the manifold I'll]
Old 04-10-2011, 05:47 AM
eli3
eli3's Avatar
Well,
Rectified today SUNROOF ..
And after repairs and assembly turns out he also stepped back and not just go up;
Before:
After:
Until next time
eli
Old 27-10-2011, 08:27 PM
eli3
eli3's Avatar
and I put it
Water tank was cracked
I found a water tank of the Ford Sierra 1.8 CVH [on the left hand] I set it to the right hand :
Hope to get more ..
eli
Old 27-10-2011, 08:35 PM
Zetecfiesta
Zetecfiesta's Avatar
looking good! very handy with the header tank!
Old 09-12-2011, 11:51 AM
eli3
eli3's Avatar
Hello everyone
Some updates:
Gasket's:
Inlet manifold
Inlet manifold-carburetor
Exhaust manifold
Exhaust manifold-downpipe
Valve cover
oil :
steam seal Camshaft
steam seal Valves
And some color
Breaking down:
Breaking down the follower to remove the valve steam seal
the old valve steam seal
Put a rope into the cylinder, to support the valves from below
and new inside
inlet manifold
I knew: injection head
Exhaust manifold
steam seal Camshaft
new inside
gasket downpipe
left: old
Right: new
After:
gasket manifold-carburetor
Exhaust manifold in paint
timing cover in paint
[I was not]
Replace the power steering gear, in standard steering gear
up: power steering gear
down: standard steering gear
the coupling no cells [short]
up: power steering
Very soon I will pictures of the assembly
eli
Old 09-12-2011, 02:34 PM
Kam B
Kam B's Avatar
must resist......
Old 09-12-2011, 04:13 PM
eli3
eli3's Avatar
resist?
why?
Old 10-12-2011, 02:21 PM
eli3
eli3's Avatar
Like I said:
After assembly, [do not take smoke, works well]
and video:
http://www.youtube.com/watch?v=8w9ga...ature=youtu.be
Old 10-12-2011, 03:10 PM
thebronze
Blag Master
thebronze's Avatar
Nice work...
3doorcozmess
31-08-2015 05:15 PM
tomiii
12
18-08-2015 08:40 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
pegaz
12-08-2015 07:30 AM
09-08-2015 07:03 PM
Quick Reply: ford sierra 2.0CL Restoration
