would st170 brake discs fit my 1.8cvh sapphire
Old 26-08-2011, 03:27 PM
barrychambers30
barrychambers30's Avatar
Default would st170 brake discs fit my 1.8cvh sapphire
as topic says will st170 300mm discs fit my 1.8cvh sapphire with mondeo mk3 calipers with the holes opened up a bit
Old 26-08-2011, 04:09 PM
grunter
grunter's Avatar
You will need to make a bracket to mount the calipers as the offset is different. I'm fitting mk1 focus rs discs to my sapph with standard 2wd calipers
Old 26-08-2011, 04:22 PM
barrychambers30
i was told i just need to open the holes up on the mondeo mk calipers to 17mm bolt holes cause there 16mm is ur a standard saph or cossie
Old 26-08-2011, 04:28 PM
dojj
Resident Wrestling Legend
dojj's Avatar
everything bolts up, you just need to open up the holes in the hubs to 12mm from the 10mm they currently are
for the best resluts, use one of these
Old 26-08-2011, 04:35 PM
barrychambers30
cheers bud got your message on sierra owners
Old 26-08-2011, 06:39 PM
grunter
grunter's Avatar
I stand corrected then I apologise I was just going on what I've had to do on mine
jason_nike
18-08-2019 10:53 AM
Gaz 88
Ford Focus RS Parts for Sale.
29
10-05-2017 12:31 PM
Dr. Ickxs
15-08-2015 11:34 AM
track.focus'd
12-08-2015 05:53 PM
10-08-2015 12:08 PM
Quick Reply: would st170 brake discs fit my 1.8cvh sapphire
