The shed Project
The shed Project
Hi everyone
Ok had this Mk1 escort sat up drive for over 7year's been used as a shed to store junk,hence shed project.
was going to put cossie engine in it ,but decided to put subaru ej20 in instead. the wrx's run 260-275bhp standard ,so i am on to a winner straght away and can be pushed to 340-350bhp on standard internals,but this is going to have a 2004 v7/8 sti engine witch will run low 400's on standard internals easly .
i am going to lock up c/diff and run it reawheeldrive .
plan is to keep it as close to Mk1 looks and handling as possible here's
what i have done sofar.
the Mk1
have cut out tunnel and replaced front floor pans
used mokeup ej20+g/box(thanks wayne) just caseing so much lighter for messing about with,
engine and g/box is in car had to cut out front inner wing's and widend and box chassi ,made engine cradle to hold engine witch is only tacked at moment needs a lot more work yet.
also started on makeing exaust header's also only tacked
removed gearbox tunnel support welded in mount for subaru gear linkage
started on gearbox mount today and finished
in car
also started to mockup gearbox tunnel will try to finish this week
the Mk1
in car
Updates? Be interesting to see a scooby powered one. Knew of a N/A wankel mk2 it just didn't sound right. Keep up the good work
ok thanks everyone for your intrest
here's update decided to finish crossmember and engine cradle
also moved engine back a inch to try and get bit more space at
front for radiator ,very tight up there.
found another crossmember in the shed better condition than the other rusty thing.
cut off escort engine mounts and made plates to weld over hole and
stiffen up crossmember
welded up
then welded engine cradle
put crossmember back on car and lined up and tacked engine cradle to crossmember,
then removed again and welded up hole thing to gether ,sprayed to stop rust for now.
and fixed back on escort
welded up
This is going to be such fun.
Nice classic car, and throaty sound too.
Oh and loads of power.
Keep up good work matey
thank's again for all your interest here's another update,
ok got the subaru gear linkage and shoreted it 100mm,
so the gearstick isen't sat where the handbrake is,subaru linkage has 2x bar's one fixes to the side of gearbox to steady gearstick the other fixes to gear selector on gearbox so shorten both by 100mm,
the rear gearlinkage mount i made before was a f**king wast of time,propshaft hits on it ,
so have made a new one that sit's higher up on the tunnel.
made and shaped new bit of tunnel to go round gearstick and welded in the hole tunnel
to car
also made a propshaft out of the subaru prop and escort prop ,will get it ballanced later
still got to make mount's to hold the split prop mount up, get pic's tomorrow
to car
but will be fitting bubble arche's with deep rim's offset out more
and will be useing compression strut's no ant-rollbar
Top work mate, its nice to you see realy hard work done! you got skills, as some just take the easy route and just use the floor-pan and running gear, to me the ANT'' skills! thats cheating...
top work mate, your a realy builder..
Is there much rot in the shell? Looks like it was pretty neglected! Would love to find an old MK1/2 like that to play with!
I must say, I'd sooner see it with an old skool NA engine in it, but fair play, it should go well, and that engine should keep the centre of gravity well down!
thats why impreza's handle so well with the flat-4 engine low centre of gravity and very light all alloy,still own 2x impreza's ,love them.
but Mk1 escort alway's been my first love have owned over 38 of them
here's little update,
haven't done much this week did airfield day on friday in scoob abington had nice little race with very nice escort Cosworth running 450/460bhp,
was getting high temp's on idle turned out to be stuck thermostate ,spent all weekend getting it ready for rallyday this saturday have 2x sessions at castle coomb.
so done couple of hour's on escort today,made two prop split mounts,
and sat them were they will be but had no time to weld them.
here's couple of my Type RA at abington friday
in sinbin blackflaged
here's little update done lot more work to escort but not aken any pic's will soon but here's some pic's of my New car i got tonight well chuffed
exhaust manifold not hitting but very close rs2000 bean sat for 3 years in a garage not worked on,got some very good bits on it going to pull it all apart and start again
ok here's some more pic's managed to quite bit of work to the shed this week
finished inside of car for now anyway .welded in impreza seat crossmembers now impreza seat's bolt straight in on subaru runners
fabricated new inner wings with holes to remove sparkplugs from under wing's with alloy cover's
finished mokingup/tacking up tubular headers and
started to fit cossey intercooler and radiator very tight impreza rad is way to high just hope cossey rad will cool it ok.
the water pipes are in wrong place for impreza engine so probably buy
alloy rad and get pipes moved a rewelded unless can find some think else,
cossey intercooler will limit me to 300bhp ok for now
