| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
Thread Tools | Search this Thread | Display Modes |
#81 | ||||
Trader Score: (0)
Location: brum/shropshire drives:- frst / escort cossie
Rep Power: 11 ![]() |
#82 | |
Lukesville
Quote:
![]() I know of a Pace tank that due to a blockage in the breather built up enough pressure in the tank that it spilt in half (by the clamp) and filled/sprayed the footwell and cockpit up with rather hot oil. Hence why I went for the tank that bolts together.
__________________
Built @ JKM Performance - NEW SPEC 508 bhp ![]() thetrolley - Fastest FWD Topspeed - 183.99mph 11.74 @ 129.15mph |
#83 | |
1st to 200 without NOS
Quote:
#84 | |
Lukesville
Quote:
The only way round it is to box it in with a firewall set up to give some extra form of safety.
__________________
#85 |
Trader Score: (0)
sorry luca i misquoted i wanted to include the post from jonny , to assist your comment... incidently i have to agree the sump tanks are big and hidious but function over looks the serve a purpose i did see yours mid work hen i picked mine up rod coming together.
#86 |
Happily retired
The tanks arrived
its big. Can i pull it on a trailer or fit it on the roof .It looks very tight to fit in the boot if i keep the spare wheel, but ive not spent time on a solution yet. May need to change the tank breather system fittings as they are the problem. Maybe a space saver wheel who knows. I would prefer to cut it in half so it fits neatly but Mark was not keen on that |
#87 |
Capt Chaos
come on Rod pics please
__________________
500+BHP 4X4 ZAKSPEED ESCORT GROUP 5 FULL RESTO, SOON TO LOOK LIKE THIS,, ![]() ![]() TAKE A LOOK AT MY GROUP 5 ZAKSPEED ESCORT REPLICA RESTORATION Clicky |
#88 |
Happily retired
#89 |
formerly beefy-rst-2
hope alls well old timer !!
glad to see the car is still progressing , i hope 1 day i get a run out in it lol
__________________
![]() founder of the parmo apprcieation scoceity ... SUPPORTER OF RONNIE AMIS !!-team airtec/gs automotive !!! Quote: Originally Posted by Will @ M Developments Honestly, a roller T4 like wennys would suit your needs perfectly. If it did blowjobs and made parmos you'd need nothing else in life
#90 |
Happily retired
#91 |
Trader Score: (0)
is it a pace one rod? Could you not get a custom one made not quite as tall!? surely they could have done it to spec? Remember if you wanted a AH one i can normally swing a discount and sure they can turn one round quick if your stuck..
click me heres there typical one just over 1'' shorter than yours... Last edited by adamski frst; 25-08-2011 at 01:22 AM. |
#92 |
If you have the tank above but want it shorter ( that's what I use to run in the boot) then you need a Marcos tank it holds the same amount of oil but is 3 to 4 inches shorter
#93 |
Happily retired
Mark is way to busy to start on this for several weeks so i thought i would start on the boot layout. Went to Marks & measured up the boot envelope then drew it on Autocad. Modeled the parts & decided on a layout.
The spare wheel had to be moved & a boss will be welded on the boot floor to secure & ive purchased a wheel cover to keep it neat. A plate will cover half the spare wheel well to take the Nitrous bottle. The Oil tank & catch tank will fit in the well. The Nitrogen bottle does not have to be moved often so it will fit behind the bracing above the battery as shown & out of sight with the seat back up. The trim & carpet will be kept & the well either trimmed or painted black. Everything will be black same as underbonnet. ![]() PS. Ive not spoken to Mark yet to see if this is OK. |
#94 |
Aren't you supposed to run the oil tank as close to the oil pump as possible with as shorter peice of feed pipe as possible?
At least thats what I was told by Neil (who used to be one of the directors of Pace) But hey what do I know |
#95 | |
Happily retired
Quote:
. Lots of experts on this |
#96 |
I guess Neil at Pace didn't know what he was taking about then
#97 |
Trader Score: (0)
Rep Power: 0 ![]() |
Take the spare wheel out Rod, no point having it seeing as though most run's you will do in future will most likely have Mark in another car/van as support with tools and parts?
Nice to see you've continued the momentum and wanting to continue developing the car. |
#98 |
You are meant to have the tank as close to the engine as pos but if your piping is right then it won't hurt being in the boot , and I can assure you Neil p who was at pace does know his stuff and considering he highly recommended by the big company names speaks for it's self,
#99 |
Chasing Radders
Trader Score: (1)
Rep Power: 45 ![]() |
Yeh just take the wheel out.You will be in the AA/RAC wont you.If you get a flat tyre/punture just get them to sort it.
__________________
#100 |
I agree with keeping the spare wheel; why wouldn't you? It's a road car so if there's room for it then keep it.
Who wants to wait for the AA to come out?!
__________________
1968 Mk2 Cortina - Zetec turbo - 329bhp at 14psi so far...
#101 |
UNAUTHORISED DEVELOPMENTS
What is the nitrogen bottle for?
__________________
FRIDGE MEN DO IT IN THE COLD http://passionford.com/forum/restora...k-car-wrc.html Mk1 sierra track car http://passionford.com/forum/restora...ort-gti-r.html Mk1 escort gti-r |
#102 |
Happily retired
#103 |
Happily retired
#104 | |
Quote:
__________________
#105 |
How many litre`s does it hold Rod?
#106 |
Happily retired
#107 |
Happily retired
Although Mark is too busy to start on mine for a couple of weeks ive been trying to get things moving along.
Pete was too busy to supply me with a tank but its going down to him to have fixing lugs welded on & then painted Black. Have bought a catch tank also in Black. Will be picking up the metal plate later in the week to fix to boot floor to hold the Nitrous bottle & ive ordered a weld on lug & fixing bolt to hold the spare wheel in its new position a Cover will be bought on ebay later this week if i have the time. Still have a remote filter to order but will get Mark to Spec that. |
#108 |
Resident Wrestling Legend
could you not drop the nitrous bottle further down into the spare wheel well to free up some space?
or is it too long? it may even fit under the bracing
__________________
![]() Winner: Best Thread on Passionford 2007 How to Quickshift an MT75 Box don't forget i'm dyslexic peeps PassionFord on FaceBook |
#109 | |
Happily retired
Quote:
Its way to big for that & it akso needs to be quickly remove (has pins not bolts) so must be away from bracing. The Nitrogen bottle can be pumped up in situ so will be out of sight behind the bracing. |
#110 |
Rod of you want anything modelling up in 3d let me know, I can get it drawn up ans sent to you in any cad format you wish so you will be able to spin the model around and get a true feel for who things will be laid out.
Just an idea should you wish to have some 3d drawings/models |
#111 | |
Happily retired
Quote:
Cheers Rod |
#112 |
Happily retired
Ordered about 15 bits from ebay & still waiting for 4
. Catch tank has been modified to Marks orders & the Tank is now at Spec-r. Still waiting for the metal plate so cant make anymore progress today. Im away in Derby this weekend so another week has gone by. Think it will be November before its complete .
#113 |
Rod, will you be rienforcing the boot well for bolting down the oil tank?
#114 |
Happily retired
#115 |
Happily retired
Not done much in the last 10 days in fact bugger all
. Bought some fittings today & on Wednesday/Thursday will pick up the tank from Pete after its been painted. The catch tank is finished as well so some progress. Not sure of Schedule from now on in but slow comes to mind. Need to know pipe lengths next fairly accurately because they are expensive at circa £40 metre. Catch 22 cos i need the engine back in to do that & im not sure when that will be .
#116 |
![]() Trader Score: (0)
Rep Power: 16 ![]() |
Do you reckon Ade will do 200 before you do again, Rod??? Or is it not that slow on progress.
__________________
![]() Focus RS number 1215. Last edited by pee vee; 20-09-2011 at 05:31 PM. |
#117 | |
Happily retired
Quote:
We intend having a bash on the same day at some point but it wont be 2011 im sure. Ade has personal reasons why he cant progress his car at this time & ive simply lost the motivation. However having not pestered Mark for 2 weeks im going across on Monday to measure the pipe lines so they can be purchased. Still not got my Tank yet but Pete was picking it up this morning so will collect tomorrow. Mark told me this morning he has 2 more engines to complete before my Dry Sump gets started so still another 2 weeks i guess. Fortunately im old enough not to worry about delays ive many other things to do with my life. It is still my intention to have a last bash at the Topspeed record & I would like to drive myself, but its not so important as it was say a year ago but still on the agenda at this point. |
#118 |
Happily retired
#119 |
Zee Germans are coming
considering this is the fastest saphire cosworth people take there time sorting it
its a driving advert for some company's should be put on top priority unless rod aint bothered when its all done lol
__________________
dump valves are for gays and the confused Iam now fordless. ![]()
#120 | |
Happily retired
Quote:
![]() ![]() ![]() ![]() hope Mark reads that.Mark has a tuning business to run & lots of customers waiting. I dont get to customer hop at MAD im afraid hes way to busy. However you are correct im not a youngster & not worried how long this takes. Also remember most of the preparation work & detail has always been done by myself & ive not the time nor is a priority for me to spend all my time on it. It will get finished but not sure of the decade |
| Display Modes | |
