Help 1.8 zetec mk2 fiesta wiring
Old 11-07-2011, 02:53 PM
andyxr2zetec
andyxr2zetec's Avatar
Default Help 1.8 zetec mk2 fiesta wiring
hi all i have a 1989 mk2 fiesta with a 1.8 zetec fitted. I have a set of honda cbr900 bike carbs on the way with an inlet manifold aswel.. Im on an EXTREMELY tight budget and i just want to get the engine running. I have got an ecu and wiring loom from a 2.0 zetec mondeo and a 1.8 zetec escort loom and ecu could i use them in any way? I really have no experience with wiring whatsoever as i am just restoring my 1st car and i am 15 years old. Any help would be hugely appreciated and thanks so much in advance.
Old 15-07-2011, 07:57 PM
andyxr2zetec
Please help guys i seriously need it!
Old 15-07-2011, 08:28 PM
vectrac20tsri
vectrac20tsri's Avatar
http://xrtwo.speedcentral.co.uk/view...049dba2e46263c
use the engine side of the zetec loom and join it into the car loom use the 1.8 ecu as will be right for the engine
Old 17-07-2011, 09:52 PM
andyxr2zetec
Thats great thank you very much i reali appreciate it but would it not be completely different for the bike carbs?
Old 17-07-2011, 10:11 PM
rapidonion
rapidonion's Avatar
no it wont!
if you are going to run the bike carbs instead of injection as stated then the above method will not work. what you will need is an esc modual and the loom to suit you will find these on late 90 spec mk4 escorts and there is a similar system used on early mk5 escorts which will also work, these are designed to drive a standard ford coilpack via an eidis modual you basicly need to find a late mk4 or early mk5 escort in the scrappy that has a coilpack but also runs a carb then take the lot eidis and the esc with the vac line going to it.
if i can find a link to one ill post it up so you know what to look for, no more than a tenner in the scrappy and no ecu's to arse about with
Old 17-07-2011, 10:18 PM
rapidonion
rapidonion's Avatar
this is what you will need but you could do with the loom as well to make it easyer
http://cgi.ebay.co.uk/ford-escort-fi...item3f0a4779f9
Old 18-07-2011, 01:58 PM
andyxr2zetec
Originally Posted by rapidonion
no it wont!
Thats great thanks very much. So i need an esc module with vac line and the loom and edis from mk4 or early mk5 escort on carbs is that right? And is that all i need?
Old 18-07-2011, 04:54 PM
rapidonion
rapidonion's Avatar
as far as providing a spark goes yeh
theres a little supressor on the wing as well for the tacho (if you use mk5) if you go for the mk5 stuff it'll be slightly easyer for you to wire up as its a seperate engine loom were as the mk4 one will have to be split from the main car loom. either way theres only a couple of wires to get it running, pm me if you have any probs
Old 20-07-2011, 11:47 AM
andyxr2zetec
Thats brilliant thank you so much
Old 20-07-2011, 01:07 PM
andyxr2zetec
Im just wondering now what to do as regards a fuel pump?? i have got an alloy racing fuel tank with 2 litre mondeo pump fitted will that do or will i need a fuel pump from the same bike i have the carbs from? A Honda cbr900 pump?
Porplus12
10-09-2015 07:20 PM
Dubs44
21-08-2015 02:42 PM
coozer
Ford Focus Range
15-08-2015 10:26 PM
gingerturbo
11-08-2015 09:44 PM
turbobill
01-08-2015 08:55 PM
Quick Reply: Help 1.8 zetec mk2 fiesta wiring
