PassionFord
Register Forgot Password?
Register Photos KBase Gold & Trader Accounts FAQ Search Today's Posts Mark Forums Read GarageVendors
Search
Welcome to PassionFord
submit to reddit
Old 11-07-2011, 02:53 PM   #1
andyxr2zetec
Trader Score: (0)
andyxr2zetec is an unknown quantity at this point
Default Help 1.8 zetec mk2 fiesta wiring
hi all i have a 1989 mk2 fiesta with a 1.8 zetec fitted. I have a set of honda cbr900 bike carbs on the way with an inlet manifold aswel.. Im on an EXTREMELY tight budget and i just want to get the engine running. I have got an ecu and wiring loom from a 2.0 zetec mondeo and a 1.8 zetec escort loom and ecu could i use them in any way? I really have no experience with wiring whatsoever as i am just restoring my 1st car and i am 15 years old. Any help would be hugely appreciated and thanks so much in advance.
andyxr2zetec is offline   Reply With Quote
Old 15-07-2011, 07:57 PM   #2
andyxr2zetec
Trader Score: (0)
Please help guys i seriously need it!
Old 15-07-2011, 08:28 PM   #3
vectrac20tsri
Trader Score: (0)
vectrac20tsri is an unknown quantity at this point
http://xrtwo.speedcentral.co.uk/view...049dba2e46263c
use the engine side of the zetec loom and join it into the car loom use the 1.8 ecu as will be right for the engine
vectrac20tsri is offline   Reply With Quote
Old 17-07-2011, 09:52 PM   #4
andyxr2zetec
Trader Score: (0)
Thats great thank you very much i reali appreciate it but would it not be completely different for the bike carbs?
Old 17-07-2011, 10:11 PM   #5
rapidonion
rapidonion's Avatar
Trader Score: (0)
rapidonion is an unknown quantity at this point
Send a message via ICQ to rapidonion Send a message via AIM to rapidonion Send a message via MSN to rapidonion Send a message via Yahoo to rapidonion
no it wont!
if you are going to run the bike carbs instead of injection as stated then the above method will not work. what you will need is an esc modual and the loom to suit you will find these on late 90 spec mk4 escorts and there is a similar system used on early mk5 escorts which will also work, these are designed to drive a standard ford coilpack via an eidis modual you basicly need to find a late mk4 or early mk5 escort in the scrappy that has a coilpack but also runs a carb then take the lot eidis and the esc with the vac line going to it.
if i can find a link to one ill post it up so you know what to look for, no more than a tenner in the scrappy and no ecu's to arse about with
__________________
viva le' orion
rapidonion is offline   Reply With Quote
Old 17-07-2011, 10:18 PM   #6
rapidonion
rapidonion's Avatar
Trader Score: (0)
this is what you will need but you could do with the loom as well to make it easyer
http://cgi.ebay.co.uk/ford-escort-fi...item3f0a4779f9
__________________
viva le' orion
Old 18-07-2011, 01:58 PM   #7
andyxr2zetec
Trader Score: (0)
Quote:
Originally Posted by rapidonion View Post
no it wont!
Thats great thanks very much. So i need an esc module with vac line and the loom and edis from mk4 or early mk5 escort on carbs is that right? And is that all i need?
Old 18-07-2011, 04:54 PM   #8
rapidonion
rapidonion's Avatar
Trader Score: (0)
as far as providing a spark goes yeh
theres a little supressor on the wing as well for the tacho (if you use mk5) if you go for the mk5 stuff it'll be slightly easyer for you to wire up as its a seperate engine loom were as the mk4 one will have to be split from the main car loom. either way theres only a couple of wires to get it running, pm me if you have any probs
__________________
viva le' orion
Old 20-07-2011, 11:47 AM   #9
andyxr2zetec
Trader Score: (0)
Thats brilliant thank you so much
Old 20-07-2011, 01:07 PM   #10
andyxr2zetec
Trader Score: (0)
Im just wondering now what to do as regards a fuel pump?? i have got an alloy racing fuel tank with 2 litre mondeo pump fitted will that do or will i need a fuel pump from the same bike i have the carbs from? A Honda cbr900 pump?
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
