4x4 sapphire cosworth rebuild
Old 05-07-2011, 08:10 PM
bruiser5050
bruiser5050's Avatar
Default 4x4 sapphire cosworth rebuild
hello everyone
here are my current pics of J819 W00 , i have owned the car for about 9 yrs and the time has arrived for a full on resto , car is basically solid but starting to get a bit scabby around the edges.
more pics to follow
on a seperate subject i run my own fabrication and powdercoating business , so if anyone wants any brackets making or parts blasting and powdercoating please pm me .
www.pctengineering.co.uk
facebook - pct engineering
thanks , Mat
Old 11-07-2011, 08:11 PM
bruiser5050
Default Update 1
spent some of the weekend getting the dashboard out and the bumper and headlights ,
found quite a bit of corrosion around the heater , will deal with that once the car is completely stripped.
also started disconecting hoses on the engine , found a little bit of black oil in the tubo inlet , not sure if that means theirs a turbo problem or not?
had a good look around the front cross member and all seems well , no corrosion at all
next week end ill tackle the rest of the engine ancillaries ready for engine removal
Old 11-07-2011, 08:14 PM
gavt123
gavt123's Avatar
top work mate another one getting the treatment it deserves
Old 12-08-2011, 10:05 PM
bruiser5050
Default update 2
been well busy at work for the past few weeks but got 2 weeks off now , so today got stuck in with engine removal
first of radiator and intercooler removal
then removed header tank and powersteering resevoir
then i took off exhaust and inlet manifolds to give me bit more room to get at gearbox bolts etc
exhaust manifold removed
inlet removed
, spent the rest of the day removing powersteering pipework , alternator , and other bracketery as well as clutch cable and speedo cable.
need about an hour or so in the morning undo gearbox bolts and engine mounts then should be ready for the big lift lol
SmudgerByName
52
28-07-2016 06:14 PM
lukeeboy149
22-08-2015 04:29 PM
155lee
14
22-08-2015 12:15 PM
cossynut2
19-08-2015 11:29 AM
yawiejon
10-08-2015 08:12 PM
Quick Reply: 4x4 sapphire cosworth rebuild
