Oil return Line Fitting pg. 2
#41
Flywheel installed with ARP bolts.
235mm clutch (Centerforce Dual friction) original application was a 1988 SHO Taurus with a 3.0l Yamaha V6 220 hp. Supposed to have 90% more torque capacity than the factory Ford 235mm clutch for the SHO V6.
MTX-3 5 speed gearbox
#44
looks a good project mate, be nice to see pics of the car. and if thats a standard rst headgasget it wont last 5 minutes. you need a felpro that will take more power.
#48
Wye Valley Hardcore
I'd be interested in a cam cover if you can get hold of one, Perry.
#49
i stand corrected 10 years ago when i had my rsturbo everyone banged on bout felpro being the bollocks. i brought a felpro gasget listed for rst.... bastards done me lol
#50
The Felpro gaskets are terrible for the small bore 1.6 or 1.9 engines.
The RST gasket is very well engineered - take a close look at one and compare it to the
Felpoo gasket.
#51
I will see if I can find another cam cover.
They look great with the matching efi inlet manifold.
They are very tall, and will not work with the RST inlet manifolds.
A side feed manifold would work I suspect.
#52
Wye Valley Hardcore
I also have a bulge bonnet so shouldn't have any problems.
#53
North American standard Escorts 1986 models.
The GT version had side body moldings and plastic front and rear bumpers.
GT version 1989
GT version 1989
#54
Small Update
Engine management wiring underway.
Fitted the RC Injectors 550cc low impedance.
Also fitted the billet adjustable fuel pressure regulator.
#55
Roller rocker installation - finally
After some re-machining (shortening by 3 mm) the rocker arm pedestals (were incorrectly machined by manufacturer) the rocker arms are ready for installation.
Next I must finish the engine management wiring. (sooo cold out in my garage)
#57
I have a Ferriday built 1800 cvh with a FRST EFi head and the block is defo taller than a 1600, about 10mm if i remember rightly. It's a pitty the 1800 never got that popular over here as if built right in turbo form there amazing, Pitty i can't get roller rockers for it though :-(
P.S.Nice build so far
Ginger
#61
The wiring is almost completed - waiting a fuel pump install and the wideband O2 sensor.
To answer an earlier post - yes I am using the factory 1.9 starter.
Red_bull
09-08-2015 08:34 AM
hazbaz1984
Ford Focus (All Models)
30-07-2015 05:15 PM
