545 bhp Radiant Red Sapphire Cosworth
Old 22-05-2011, 08:09 PM
fraser9764
fraser9764's Avatar
Default 545 bhp Radiant Red Sapphire Cosworth
Ive had the car for nearly a year now so i suppose its about time i did a bit of a project thread
I picked the car up from Danny@Enhanced Performance towards the end of summer last year, the car looked a bit off a mess to be fair, but mechanically and body wise it was spot on, just needing a set of wheels and front brakes, a damn good polish, and the interior tidying up.
this was how she looked when i first went to view it.
i think one of the wheels was bent so Danny sorted out a set of lattice wheels to drive it home on, didnt take any pics as it looked poo
Before i had even picked the car up i had bought a set of 17x8 Comp Mo's off Shorty, and a set of Kuhmo Ku31's
I never really liked the wheels in white, mainly because i had to clean so often So i had them powdercoated in dark grey.
Also the front brakes were awfull, the discs were warped, the pistons were siezed to start with on one side, and it was just dangerous. So i Picked up a set of Fiat coupe turbo brembo calipers, New focus RS EBC plain discs and Mintex pads.
Made a set of brackets up using a piece of 5/8" thick alluminium, and bolted them all up, the brackets werent perfect and ended up with the caliper sat about 3mm too far out, although it worked perfectly so i left it.
Then the Girlfriend got us a Stunning new steering wheel for christmas to replace that awfull Momo one
At the same time i retrimmed my headlining and fitted my new leather interior, the original cloth seats were ok but the door cards were tatty.
I drove the car for a few months without really changing much, just sorting out little bits and bobs and getting bored with 300bhp
I had the car on a local hub dyno at a bit of a meet, it made 293bhp and about 320 ft/lb before the clutch let go would have probably just pipped 300bhp
So i dropped the gearbox, had the flywheel skimmed and fitted an AP 6 paddle, at the same time i picked up another set of new wheels off Martin@Reyland and had them powder coated. When i came to fit them it turned out my previous slight cock up with the caliper brackets meant the wheels wouldnt fit
i ended up having to remake the brackets and run 6mm spacers on the front to clear them making the front ET29. I put a set of 5mm spacers on the rear too to bring them to ET30.
First show for the car then, Modified Live at oulton park with Cheshire RSOC, Girlfriends brother Chris (slammedorion) gave the car a quick Mop and polish the night before
The car was running well, but using a bit too much for my liking, Valve stem Oil seals/guides i believe. i thought about rebuilding the top end but it would still be on a 90kish 205 block and 2wd pistons
So the other weekend, i headed up to aberdeen with my brother, in my mums little clio as it does over 50mpg, and picked this up
One of Yum's old engines Spec is:
Small turbo Escort 200 block
ARP long stud and nut kit
WRC 4 layer SS head gasket
Touring Car spares Gated sump
7.6-1 Comp Ratio
ARP big end bolts
ported & flowed Cyl Head
MA spec inlet Cam
Kent Vernier pullys
Double Valve springs
Small turbo Inlet manifold plenum and throttle body
Rochester 1000cc injectors
Turbo Technics T38 turbo
Made 466bhp a few years ago
So this weekend, after a couple of weeks collecting up parts, I got the new engine in.
Started off looking like this:
3 hours later:
Then gave the engine bay a soaking with TFR and a scrub with a paintbrush
Whipped the sump off to drill and tap for my Oil temperature gauge
Touring cars gated sump, very nice
spent a few hours swapping stuff over last night, and then this morning a mate popped round and gave us a lift:
Still not liking the yellow inlet I will get it up and running then spend a day sorting bits like that.
Hopefully this week i can get it all connected up, and then get it mapped and back on the road
Old 22-05-2011, 08:13 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
looking good best colour too
Old 22-05-2011, 08:17 PM
cossie.087
cossie.087's Avatar
nice work looks great love the wheels.
Old 22-05-2011, 08:44 PM
rst-g
ZETEC TURBO
rst-g's Avatar
Love Crystal blue Cossies , looks smart mate
Old 22-05-2011, 09:13 PM
fraser9764
fraser9764's Avatar
Cheers lads
Crystal blue wasnt my first choice to be perfectly honest, Magenta is still my favorite.
Old 22-05-2011, 11:35 PM
RSMK4TURBO
RSMK4TURBO's Avatar
Very nice mate looking great.
Old 23-05-2011, 12:30 AM
ram
Has a large member
ram's Avatar
Looks great mate. gonna be a beast
Old 23-05-2011, 07:07 AM
AJC
AJC's Avatar
Bang tidy
Old 23-05-2011, 07:41 AM
Turbosimpsons
Turbosimpsons's Avatar
looking well. should have a few more ponies.
Old 23-05-2011, 07:47 AM
JamesH
JamesH's Avatar
Looks lovely, you've improved on it no end since getting it
What turbo is it mate?
Old 23-05-2011, 09:14 AM
slammedorion
slammedorion's Avatar
Hope I'm not behind it when that rear diff explodes lol. Its certainly changed for the better over a year.
Keep up the good work.
Old 23-05-2011, 07:29 PM
Turbosimpsons
my 7" rear diff is still holding on and mine made 468 on hub dyno.
Old 23-05-2011, 07:42 PM
ajamesc
ajamesc's Avatar
You must have a guardian angel lol i smashed my standard 7.5 inch diff to bits with 350 bhp and the same ish torque then fitted a gripper tunned the car to 500 bhp with the same ish torque and took all the teeth off the crown wheel and pinion! and no i dont drive like a twat also took the gear box out with 350 too!
Old 23-05-2011, 07:44 PM
fraser9764
fraser9764's Avatar
Cheers for the replies put my new loom in tonight but not taken any pics as i left my phone in my overalls in work
Turbo Technics T38
Cheers i think i will have to pick up a good standard diff! Mine wont stand a chance
But mine is fooked now lol, whines like mad and clattering and banging
Meant to ask you actually, when you took us out in your saph did it have the 6 degree rear beem fitted? or was that for the escort?
Old 28-05-2011, 09:25 AM
fraser9764
fraser9764's Avatar
Been busy this week, new engine is not too far off running now, still got to stick some jubilees on the breather system, connect amal valve and MAP sensor, sort some alternator belts as my new ones are too long, connect up the loom, rewire fans and pump and change the pump. should have it all done by monday
Old 28-05-2011, 10:45 AM
Turbosimpsons
Turbo Technics T38
i had a 6deg beam fitted when i took you out in it. thats why it didn't suffer to much with wheel spin. my escort has a square beam and mag arms on it. i might sell the beam and mag arms and build myself another 6deg beam for it. what power you hoping for?
Old 28-05-2011, 11:22 AM
Garethw1986
Garethw1986's Avatar
stunning car this look mint
Old 28-05-2011, 05:44 PM
fraser9764
fraser9764's Avatar
Might have do discuss beams some time then
Well it made 466bhp when it was in YUM, and its a very similar spec to cossie4i's car, ill be happy with anything over 450.
cheers matey
Got a bit more done today, new loom all plugged in now, had to extend and reroute both the CTS sensors and ACT sensor cabling to suit the small turbo head and manifold.
sorted the alty belts too, someone was being a bit dim last time they looked at it
fan rewire and put some fluids in tomorrow
Old 28-05-2011, 05:56 PM
timster
timster's Avatar
Looking good fella
Old 28-05-2011, 09:19 PM
Turbosimpsons
[quote=fraser9764;5480045]Might have do discuss beams some time then
no probs. soon put another together.
Old 28-05-2011, 11:26 PM
Nice car mate i like the mods you have done to it.Keep up the good work.It looks like a clean shell.
Old 29-05-2011, 02:06 PM
Sticky.
Sticky.'s Avatar
Toughy's old engine.
Nice work mate.
Old 29-05-2011, 08:52 PM
fraser9764
fraser9764's Avatar
Nice one
Cheers Glenn
Nice work mate.
Yep thats the one! Thanks.
had another few hours on it this afternoon after the F1, Engine bay is pretty much finished now, just got to put fluids in.
Just got to swap and rewire the pump tomorrow.
Moved my amal valve to the inner wing and extended the wiring, never liked it stuck to the slam panel with the wiring draped accross, much tidier
Old 03-06-2011, 08:02 PM
fraser9764
fraser9764's Avatar
Finally got her fired up this morning
Runs really nicely, very pleased, not even a noise from the lifters and the engines not been run since 2006 i think.
Tony@turbosystems sorted a base map out for us last night,
Started off by pulling the dizzy out and spinning the oil pump drive for a few minutes with a drill to get some oil round the engine, oil pressure looked good.
Popped a new dizzy and rotor arm on and the leads from my old engine as im waiting for new leads from R&B motorsport to suit the small turbo cam cover and dizzy, spun her over without the coil connected, then plugged her in and nothing
plenty of fuel, but no spark
after an hour of head scratching i realised some muppet had connected up the earth to the coil rewire loom not the live, swapped this round, and she fired straight up
i then spent the rest of the day trying to sort the banjo sealing washers on my 044 pump think ive got it sorted now.
Need a to sort a PF09 throttle position sensor, get that fitted and get it booked in for live mapping oh and re-do my half moon seals on the cam cover as its leaking already
Old 03-06-2011, 09:14 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
You MUST paint that inlet a different colour lol
Steve
Old 03-06-2011, 09:50 PM
I bet you were well sick lol.At least its all sorted now.I like where you have put your amal valve.
Old 03-06-2011, 09:58 PM
fraser9764
fraser9764's Avatar
Steve
Yep Gonna just take it back to ally i think, or nice boring black.
I Might do it tomorrow actually, dont know what to do with myself now, been flat out on this for two weeks and all i can do now is get a jubilee clip and tidy up the battery cables
Old 03-06-2011, 10:01 PM
fraser9764
fraser9764's Avatar
Yep i was pretty dissapointed with myself to be honest i had wired it up about 3 weeks ago on the old loom and it was perfect, and yet i still managed to cock it up
The amal valve is far better over on the inner wing, well worth the effort of pulling the wiring back through the loom and extending it a bit. looked lost stuck in the middle of nowhere before.
Old 04-06-2011, 12:45 PM
malcs-escort-cos
malcs-escort-cos's Avatar
nice cossie mate.makes me want another lol
Old 04-06-2011, 05:03 PM
Turbosimpsons
you can put your eec4 throttle body on whilst your inlet is off.
Old 06-06-2011, 09:16 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Did you do it then ?
Steve
Old 06-06-2011, 09:23 PM
fraser9764
fraser9764's Avatar
nope, spent the day fiddling with my mums citroen 2cv instead will do it soon.
Trying to resist the urge to order a carbon heat sheild, plug lead cover and cambelt cover at the mo someone sell me a standard cambelt cover quick
New TPS will hopefully be here tomorrow or wednesday, then ill see if Tony can do owt before the weekend, want to get out and use it
Steve, have you got a copy of you graph to hand? interested to see how it compares to the old graph for my engine?
Old 06-06-2011, 09:29 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Not sure how accurate it is lol
Steve
Old 06-06-2011, 09:31 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
I can't find the graph with the Spec-R intercooler, but it was smoother than the airtec one but about the same power
Steve
Old 06-06-2011, 09:45 PM
fraser9764
fraser9764's Avatar
hmmm interesting, yours seems to be about 250 rpm earlier coming on song, and starts to tail off at the top, where mine is still rising/leveling out.
i expected it to be the other way round as it was run on a 4wd exhaust manifold in YUM looking at old pictures, from what ive read the 4wd manifold should help spool up but restrict top end power
Old 06-06-2011, 09:46 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
The graph reads about 500rpm low
Steve
Old 06-06-2011, 09:49 PM
fraser9764
fraser9764's Avatar
Steve
that would probably explain it then lol.
Old 06-06-2011, 09:52 PM
Turbosimpsons
why you posting oh this thread steve? his car hasn't got a ab07 cam in it.
Old 06-06-2011, 10:01 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Maybe not, but it does have a TT T38
Steve
Old 07-06-2011, 06:36 PM
lockhead
lockhead's Avatar
Nice car, but the front bumper looks like it needs sorting(gap between front wing and bump). And why the change of head? thought the older type were better than the new ones?
good luck!
Quick Reply: 545 bhp Radiant Red Sapphire Cosworth
