BMW M3 diff into a Sierra Cosworth
hi, after breaking the original Ford diff about 3 times, I decided it was time for something more stronger and as a bloke I know already fitted one and was seeing how good it was I decided to go that way as well. This is a BMW E36 M3 diff which is a 8.5 inch a much stronger than the ford one. Incredibly so, it's similar to the ford diff and even the shafts match just need a spacer on the left shaft and you have two choices for the prop shaft (1) or cut the BMW prop flange and weld the Ford flange so it will match the ford propshaft or (2) get hold of a BMW M3 E36 prop shaft, dismantle from the cross than dismantle the Ford Prop shaft from the cross, than use the BMW part to fit the diff and the Ford part to go into the gear box. To make it fit into the Ford beam a jig was made and some pieces were welded to the diff to fit into the original ford beam.... here are some pics http://s799.photobucket.com/albums/yy272/marko3star/
Corky67 (20-09-2015)
thanks mark
http://youtu.be/gkrWH4bs56s
beef....it's a 8.5 inch unit and can handle up to 800bhp, if you compare to the ford unit it's about 1.5cm wider but then the BMW is more bulky, the one I have has a 40% lock lsd and cwp is heat treated as well,
I think a saw a thread a while ago saying that the thikness of the pinion of the 9" is the same as the 7.5" thats were I got it that they are the same... any way they break as the guy who made it here in Malta broke two ( using it on the strip) and now he have the bmw with no prob...I think even in the touring car they used to break and than switched to jag diff...This I read from a Ford magazine when they made a story about Zoo motorsport...always if my memory serves me right ( it doesn't a lot )
competant bodger
where they M3 E36???? if you see the diff from inside you will notice that the pop shafts and crown wheel and pinion are much stronger, I forgot to take measurements but sure you can find on the web....A lad from Malta which runs a 600bhp+ on an RS500 has one of these and he didn't break it and he broke about 9 ford diffs and two Ford 9inch as well. here is a link to see him on the drag strip... he manage 10.5 with 1.5 first 60 feet
ive also torn the floor around the diff on an e46 m3 lol though i believe this was quite common on e36 and e46!
You are right but in his left hand drive 1/4 mile 9sec sierra, His father's RS500 has the BMW infact I used his jig for making mine.... They look almost identical but one is lhd anf the other is rhd which has escort cossie wheels.....
Happily retired
Im sorry Rod, i forget you are all knowing.
550ft-lb's and 1710Kg.... and he actually drives it. Maybe a different model diff?
Rob.
EDIT xjr's are 1790Kg, so i guess the extra half a ton hurts diffs more than an extra 100 ft/lbs...
yes your correct as i know chris well,but his dads rs500 isnt nowhere near the power of the lhd one with the old escort engine in,but nano,s rs500 is alot stronger rear end than standard
http://youtu.be/33tZGBfptdo
Rod probably doesn't make anywhere like 666 in first gear. It'd simply spin the wheels or not put the engine under enough load. The gearbox is a torque multiplier so obviously the diff probably see's a couple of thousand lb/ft in first gear. When you in 4th etc its more like what the flywheel torque is so much less relevant.
this is a 2wd rear beam ? would it be possible to do it on a 4x4 rear beam ? and is it any difference on the e36 m3 diffs, what year is the one you used ?
my friend is using it on an Escort Cosworth 4x4, the diff is modified to fit into the Cosworth beam so It can be used on a 4x4 beam... it is an e36 M3 diff...http://cgi.ebay.co.uk/ws/eBayISAPI.d...#ht_1179wt_825
4x4 beam is different to the 2wd by 1/2inch.
you need to make a jig to fit the BMW diff on the Cosworth beam, unfurtantely I didn't take any pics of the jig as I borrowed it from a friend but it's not really a big deal...If you know to weld and handy with fabricating steel than it wouldn't be a problem for you...If you look carefully at the pics ypu will see the weld on the diff...
charliecosworth
19-08-2015 02:00 PM
155lee
14-08-2015 11:21 AM
