THE TURB new lease of life need ecu!
ZETEC TURBO
Had this fiesta turbo since April 09 bought off a mate for £400 was off the road at the time for few years due to blowing engines an turbos and smokin like a good'en :'-( so snapped it up quick!!! After many wash's it came up not to bad
After a full service valve stem oil seals and a bit of use it ran fine went straight through the mot and has done since av owned it will post more up soon as I can get to my computer as am on my phone at the mo
ZETEC TURBO
Having few spare bits kickin round was handy as I got rid of them shit lights!!! An replaced the ring sticker that was on it with this lol
After aweek of abuse on the road the clutch was showing signs of slipping so I chucked a 4paddle init
ZETEC TURBO
after bit more power so got gary (crazycage) to knock one of his inlets up am made up with it!!!!!!
also got a std front bumper for it an headights
it's alternators i seem to do in my starters normally last around 2 years and there only second hand ones i use anyway last one thats just died came of the blue mk5 daveysaff had a couple of years back
ZETEC TURBO
urs is faceing the othe way alternator is gettin the heat av just had to bump start the feckin thing again :'(
cheeRS bud
ZETEC TURBO
Will be keeping the bottom half of the manifold an just make sure every think matches up like Dave said, should make half decent power with the correct mods with it
A gasket match will do nothing to help air flow.
The factory inlet port cross sectional area is very small limiting airflow.
Eliminating the top part helps- true enough, but far more gains could be had.
I also assume the cylinder head is well modified by a competent shop?
(one sees so many so called "stage 3" home "ported" jobs - no flow bench numbers to verify
any flow gains)
Zee Germans are coming
ZETEC TURBO
Get that inlet on a flow bench.
any flow gains)
any flow gains)
Sounds good 2 me mate will give you a pm over the weekend!!
ZETEC TURBO
Managed to pick up an engine just had the bottom end rebuilt an the head looks to have been lightly played with, just need to get the adaptor for the inlet as the head is mfi so will get that this week will post some pics soon
ZETEC TURBO
got the engine all built back up in some spare time i had in work
an the adaptor plate landed aswell
pic of the exhaust ports
an had a trial fit of the inlet manifold to see what it would look like
won a tubular exhaust manifold on ebay so will have that mid nxt week !!
ZETEC TURBO
ZETEC TURBO
ZETEC TURBO
ZETEC TURBO
