ESC ignition system. is it just the module i need??
Right guys need a little help, i am running CFI atm and want to convert to ESC so i can run carbs. is it just the little module that is bolted to the bulk head i need or do i need all the rest of the loom that connects to ecu and stuff? can someone please shed little light on this as i am little confused. the esc is guna be on an 8v so no need for megajolt yet
any help would be great, thanks
You need the esc unit and the loom which connects to the coil pack,cps and a few others, think it has about 5 connections but you only need the coilpack and cps bits
I just thought, am i right in saying that my current ignition system works off the throttle position sensor for ignition advance and retard? aka if i get bike carbs with a throttle position sensor on it could i not just wire this up to work then i wouldnt have to change the ig system?
Dr. Ickxs
15-09-2015 10:15 PM
