My mk2 Fiesta Zetec Turbo. 12/04/2014 new exhaust manifold
#162
YES I KNOW I CANT SPELL
small update
got some new armes
should help with traction
also got some of this to soak my slicks in
also i found a video of my first run with the new gearbox if you watch you see at the start when i was doing a burn out i thought the clutch was slipping hence i stoped
then half way down the strip the coil pac dies on the day i thought it was the throttle pump within the ecu set to high lol.
then as i cross the line i punch the stearing wheel in anger what a dick!!
got some new armes
#166
got my back mount fitted
out with the old
and in with the new
i was thinking to my self i better use the lube they supply as it mite be some sort of special stuff........
looks alot like copper grease
had to chop it about a bit to get it in
not very happy with the way it looks
but by god it works well no more clonking lol
out with the old
and in with the new
#168
Ben
Absolute animal
#170
all ready for santapod
also went a picked up my new turbo my deal fell through with the gtx had to settle for a gt30.71 still should go well
WHO wants to buy my t34.63? i also have a .48 housing as well
#177
right finally putting some time into the fiesta got the workshop between x-mass and new year so she has a ramp for the week hears how ive been getting on.
started off picking my apprentices fiesta up as it started playing up lol
good to have him around for the week as hes there when a hand is needed thanks Jamie
started by striping my gearbox out
gear box striped down and the gearkit removed
i snapped a syncro tooth off also the 3-4 syncro was locked up solid!
so i built this
its my focus rs/transit connect hybrid gearbox lol nice long ratios
the difference in bell housings
my ATB diff with the old gearkit
treated it to a new clutch an AP paddle
and put it back in the hole lol
then wile looking around underneath i looked up at my top mount and noticed something did not look right
hmmmm striped it out just to be sure!
not only has it destroyed the rubber mount its bent the holder
next to a non bent one lol
so i bent it back and made this badboy!! lol
that should hold it lol
fitted my new turbo
and my new 3" down pipe just got to make the rest of the system
thats it for today what do ya think??
so i built this
fitted my new turbo
#193
Its a gt30.71 so should go past 400hp with ease
#197
done some more work today
got all the rad back in ect
turbos fitted
had to move the rad forward a bit lol
then i made a new exhaust
what do you think?
turbos fitted
what do you think?
