Mk1 Escort Bubble Arch Cosworth Project 1971
05-02-2011, 03:26 PM
Hi, as of today i am the proud new owner of a MK1 Escort Steel Bubble arched Escort
. The plan is to Install a Cosworth Engine.
I am New to this so any advise will be greatfully received!!!
My first job is to sort the inner rear arches as somebody has not cut away the old inner arch.
I know i need to install a larger front tunnel and im going to install a larger diff tunnel.
1st of many questions.
I have already got anti Tramp bars so do i need a four link kit or panhard?
05-02-2011, 03:35 PM
having a mid life crisis
have a look or turbosport as sure many of their owners have done this conversion,or tyry the old skool section on here
05-02-2011, 03:39 PM
05-02-2011, 03:41 PM
05-02-2011, 03:42 PM
if your going for a decent power then go atlas axle,4/6 link with either panard rod or watts linkage back end.you can use an rs2000 propshaft depending on axle location.t5 gearbox with modded tunnel.you may also have to chop the rear of a world cup x-mamber to clear the sump,also worth getting a big wing sump or at least a baffle plate and gates installed in a standard cossie one if your doing trackdays
hth
05-02-2011, 03:55 PM
05-02-2011, 03:59 PM
05-02-2011, 04:21 PM
very nice! will be a good thread cant wait to see your work!
05-02-2011, 04:30 PM
Smokin'
Nice shell, subscribed
05-02-2011, 04:33 PM
as pig says above, but its not cheap mate but dont skimp if you are going for decent power get as much strength in the shell as you can seam welding/corner gussets etc pays off in the end,plenty of peeps on here thats built mk1s and 2s if you get stuck mate.
05-02-2011, 06:03 PM
The original Rouge Trader
Looks like a good base to start with, keep them pics coming!!
07-02-2011, 04:34 PM
pm melspec1 he will probably have everything you need
07-02-2011, 04:49 PM
09-02-2011, 07:32 PM
Got Engine and box sorted, picking it up on Sunday
09-02-2011, 07:40 PM
competant bodger
fook me that is the tidiest mk1 shell i have ever seen! im looking forward to seeing this progress
09-02-2011, 09:38 PM
Good luck with the build M8
Great shell to start with
09-02-2011, 09:39 PM
09-02-2011, 09:45 PM
looks a good basis to start with
11-02-2011, 05:26 PM
11-02-2011, 06:13 PM
Coming along nicely bud, seems a very solid shell.
Keep it up
11-02-2011, 06:29 PM
Great progress
look's like you have the skills to make a nice job of it aswell
11-02-2011, 07:01 PM
Cheers Wizz, first time ive tried to weld since i was 18!! The roll over spit made the job alot easier.
Diff tunnel tomorrow!!
11-02-2011, 07:44 PM
if you get stuck give me a shout i mite be of some help ?
11-02-2011, 07:48 PM
welcome to passion ford mate.
oh god i love mk1 escorts.
this is gonna be sweeeet
always manted a bubble arched mk1.
good luck fella
11-02-2011, 08:53 PM
Any advise for my rear suspension setup?
do i need rear turretts or will leaf spring be ok?
12-02-2011, 09:41 AM
my first one woz a bugdet build it ran leaf springs with uprite shocks and anti tramp bars with lsd its ran stage three set up and woz ok, they spin the wheels up before it will break your shafts its how deep your pockets are really
12-02-2011, 03:00 PM
RS nutta
Nice shell what colour you painting her .
12-02-2011, 04:24 PM
Diff Tunnel Today, also welded up unwanted holes in the engine bay and did some shell strenthening in the engine bay.
IMG_0679.jpg?t=1297531318
12-02-2011, 05:12 PM
its all good
awesome mate i love these
12-02-2011, 09:14 PM
Quote:
Originally Posted by
nuttynil
Not sure yet, maybe white with Castrol graphics.
12-02-2011, 09:24 PM
andym
Yeah i was a nit rusty when i started my project but it soon comes back to you
Roll over jig's definatly make the job hell of a lot easier
Keep up the good work
12-02-2011, 09:34 PM
I like it mate keep it . And to top it your a brummie
12-02-2011, 09:48 PM
that is a mint shell, will be awsome when its done. i want one.
12-02-2011, 09:50 PM
Has a large member
Nice mate. not enough classic stuff here on pf so refreshing to see
13-02-2011, 03:44 PM
Comming along very nicely and certainly a nice clean shell
14-02-2011, 08:43 PM
edited
14-02-2011, 10:06 PM
edited
14-02-2011, 10:58 PM
Yeah id go rear turrets i had them on my Mk2 rally car and they made a big difference over standard shocks
Diff tunnel look's good
Keep up the great work
14-02-2011, 11:02 PM
edited
16-02-2011, 07:05 PM
