3dr
Old 02-09-2014, 06:43 PM
  #241
siscossie
3-door moonstone
siscossie's Avatar
Most of the bottom end done now new clutch cable with heat sleeving, started on the inlet trumpet section
Inlets going to be a week or so at the polishers so will make a start on the head
Old 04-09-2014, 05:29 PM
  #242
siscossie
3-door moonstone
siscossie's Avatar
Made a start on the head tonight manifolds on and thermostat housing
Ordered new cap rotor and plugs and a new crank sensor the wires where frayed
Old 05-09-2014, 06:49 PM
  #243
siscossie
3-door moonstone
siscossie's Avatar
Got little more done tonight turbo bolted on
Old 06-09-2014, 04:08 PM
  #244
siscossie
3-door moonstone
siscossie's Avatar
Got the head refitted today
Gave the cam cover a polish before refitting
Refitted
Old 07-09-2014, 03:04 PM
  #245
The cam cover looks really bling.
Old 07-09-2014, 05:04 PM
  #246
siscossie
3-door moonstone
siscossie's Avatar
Had a few setbacks today first of all the crank sensor wire fell off as I removed it luckily I had bought a new one anyway
Then fitting the cambelt the stud for the tensioner stripped it's thread, not a good morning I retapped it nut wasn't happy with it so got a helicoil kit and sorted that out. Alls good now belt on and timed up
Need to get a gasket for the turbo oil return pipe then that can go back on, need to get the plenum back from the polishers then can get that sorted out
Old 07-09-2014, 07:09 PM
  #247
pauloopnorth
pauloopnorth's Avatar
An amazing read Simon ,No stone left unturned on this one mate well done it's an awesome car that just keeps getting better
Old 07-09-2014, 07:26 PM
  #248
siscossie
3-door moonstone
siscossie's Avatar
Cheers bud
Old 07-09-2014, 08:23 PM
  #249
mk2cossy
mk2cossy's Avatar
Getting there now mate.
Old 07-09-2014, 09:12 PM
  #250
siscossie
3-door moonstone
siscossie's Avatar
Nearly there bud
Old 09-09-2014, 06:17 PM
  #251
siscossie
3-door moonstone
siscossie's Avatar
Got the intercooler back in today
And polished the radiator ready to go back in
Old 13-09-2014, 05:35 PM
  #252
siscossie
3-door moonstone
siscossie's Avatar
Finally got the inlet back from the polishers think they've done ok
Made sure all the threads are good just to be safe
Then mocked it all up to see how it fits
Really close at the back to the brake pipes out of the abs block but might just get away with it, just the pipe work to sort out then.
Old 14-09-2014, 11:18 AM
  #253
Nice bit of kit that matey.
Old 14-09-2014, 12:08 PM
  #254
costina
Live long and prosper!!
costina's Avatar
Shit me... where is my sunglasses
U will need shares in metal polish Si.
Paul
Old 14-09-2014, 01:36 PM
  #255
siscossie
3-door moonstone
siscossie's Avatar
Paul
Good job I don't mind cleaning it ha ha
Old 14-09-2014, 01:37 PM
  #256
siscossie
3-door moonstone
siscossie's Avatar
Cheers bud hopefully should squeeze a few more bhp out of it, looks the part too
Old 14-09-2014, 04:05 PM
  #257
pauloopnorth
Looks lovely mate
Old 16-09-2014, 06:26 PM
  #258
siscossie
3-door moonstone
siscossie's Avatar
Started on the radiator fan surround today the brackets where rusty and some broke
So found someone who makes new ones in stainless, just a matter of drilling the old pot rivets out and new ones on and new pot rivets
Not too bad certainly better than the old ones
Old 16-09-2014, 08:39 PM
  #259
costina
costina's Avatar
Si do you have a link for those brackets. saves a lot of messing about
Old 16-09-2014, 09:09 PM
  #260
siscossie
3-door moonstone
siscossie's Avatar
171461602487 item number fela
Old 16-09-2014, 09:10 PM
  #261
mpilk
mpilk's Avatar
i need some as well
Old 16-09-2014, 10:13 PM
  #262
Cragrat
sit boo boo sit
Cragrat's Avatar
Looking sweet cheif
good find on the brackets...
Old 17-09-2014, 05:50 PM
  #263
siscossie
3-door moonstone
siscossie's Avatar
Originally Posted by Cragrat
Looking sweet cheif
There not too bad fela should do the job
Old 21-09-2014, 08:37 PM
  #264
siscossie
3-door moonstone
siscossie's Avatar
Started to sort the pipework out, the vac pipes have been rerouted
And have to sort the cooler pipe out aswell
Old 26-09-2014, 10:47 AM
  #265
siscossie
3-door moonstone
siscossie's Avatar
Now I've run the loom under the inlet the iscv was a bit short so rather that cut it made an extension piece with the proper plugs on
Decided I wanted to keep the throttle cable at the front so got a bracket but that's caused new problems too close to powersteering pipe now
Got the oil breather fitted with the pipes routed a bit better now
Old 27-09-2014, 05:41 PM
  #266
siscossie
3-door moonstone
siscossie's Avatar
Got a bit more done today sorted power steering pipe out and got all the water plumbed in, just the belt cover and exhaust to sort out
Old 27-09-2014, 10:20 PM
  #267
That engine looks smart as fook.
Old 28-09-2014, 07:37 AM
  #268
DavebST170
DavebST170's Avatar
that engine looks amazing
Old 28-09-2014, 10:13 AM
  #269
siscossie
3-door moonstone
siscossie's Avatar
Cheers fela gonna be a bugger to keep clean ha ha
  #270
siscossie
3-door moonstone
siscossie's Avatar
Cheers bud it's getting there now
Old 16-10-2014, 05:07 PM
  #271
siscossie
3-door moonstone
siscossie's Avatar
Haven't done much for a while but got the strut brace and heat shield back on tonight
Old 16-10-2014, 08:45 PM
  #272
gjh
gjh's Avatar
Looks brilliant!
Old 17-10-2014, 03:00 PM
  #273
siscossie
3-door moonstone
siscossie's Avatar
Originally Posted by gjh
Looks brilliant!
Cheers fela nearly there now
Old 17-10-2014, 11:49 PM
  #274
COLEYST200
COLEYST200's Avatar
It's looking very nice mate
Old 18-10-2014, 08:39 AM
  #275
Have you had it running yet.
Old 18-10-2014, 08:44 AM
  #276
siscossie
3-door moonstone
siscossie's Avatar
Not yet bud hopefully Sunday will be firing it up
Old 19-10-2014, 05:38 PM
  #277
siscossie
3-door moonstone
siscossie's Avatar
Finally got it running today started first turn of the key caught me by suprise
Ran it up all looks ok the the battery light came on, after a bit of searching and head scratching traced it to the alternator wires badly perished and hanging out of the plug
Peeled it back to find this
So cutting all that out and replacing it and braiding it then wrapping in heat proof sleeping, that's my job for tomorrow
The main cable seems too big to solder any one done this before
Old 19-10-2014, 06:34 PM
  #278
cozzy jeff
cozzy jeff's Avatar
Just run a new cable back to the battery
Old 19-10-2014, 07:15 PM
  #279
siscossie
3-door moonstone
siscossie's Avatar
Does it go straight to the battery, not traced it back yet?
Old 20-10-2014, 05:05 PM
  #280
siscossie
3-door moonstone
siscossie's Avatar
Sorted the wires to the alternator but the light on the dash is still on and only putting 12.2volts in battery when running
Put a mates old alternator on and lights gone off but only 12.6volts
So think it's defo time for a new alternator
Quick Reply: 3dr
