Project Sierra RS Cosworth from Switzerland
Old 02-01-2011, 04:42 PM
Cosworthfreak
Cosworthfreak's Avatar
Default Project Sierra RS Cosworth from Switzerland
Hello
Here some pics I hope you enjoy them.
Old 02-01-2011, 04:44 PM
whizzisat114
whizzisat114's Avatar
Looks a nice project
What are your plans for the car?
track car? road car?
rally car?
Bhp/Spec?
Old 02-01-2011, 04:46 PM
Cosworthfreak
Cosworth
Old 02-01-2011, 04:48 PM
Cosworthfreak
i will built a track car. engine specs about 300 - 400 bhp GT35 turbo
Old 02-01-2011, 04:53 PM
whizzisat114
Look forward to watching the build
Good luck
Old 02-01-2011, 07:07 PM
Cosworthfreak
Here more pictures
Old 02-01-2011, 07:35 PM
Cosworthfreak
And here some pics from my saph
Old 02-01-2011, 08:04 PM
Cosworthfreak
Here some specs:
3 Bar map sensor
Uprated fuel pump
Bosch 403 revised grey injectors
Fitting kit for fit injectors Bosch
Uprated actuator -34
Multilayer head gasket
ARP Connecting rod bolts
ARP Main bolts
GpA long studs bolts
Spark plugs Denso Iridium
Group A coil
GT35 Turbo / ball bearing
Camshaft type BD14
WRC Pistons with pockets
Cosworth high pressure oil pump
Trimetallic main - big ends
200 Block machining for gpA-wrc long studs
RS 500 style Intercooler
Uprated alloy water radiator
AP Racing 6 padle clutch kit
sparkless Ignition
Sidepipe
Oil separator kit
Boost rasised to 2.0 bar
Big inlet manifold
Old 02-01-2011, 08:24 PM
Cosworthfreak
more pics come soon
Old 03-01-2011, 09:06 AM
Im love your cossies.I love the look of that intercooler too.
Old 03-01-2011, 10:39 AM
Cosworthfreak
The intercooler is 18cm thick ^^ this weekend i wil fit the coolers
intercooler, watercooler, turbocooler, gearboxcooler, diffcooler and oilcooler
Busy weekend
Old 03-01-2011, 06:07 PM
Cosworthfreak
i can remove the frontwings with 14
Old 03-01-2011, 07:17 PM
Very nice ,what part of switzerland you from im off to grindlewald in march
Old 03-01-2011, 07:26 PM
MARCOSWORTH
MARCOSWORTH's Avatar
Love the Saff, great build and good idea about the wings
Looking forward to see it ready
Old 03-01-2011, 07:47 PM
damien roe
damien roe's Avatar
nice looking motor's mate
Old 03-01-2011, 08:32 PM
Cosworthfreak
it's 3 hours from grindlewald
Old 03-01-2011, 08:33 PM
Cosworthfreak
thx
Old 03-01-2011, 09:39 PM
ital_cossie
ital_cossie's Avatar
very nice build!!
what make is the rollcage? you don't have door bars?
Old 03-01-2011, 09:44 PM
Cosworthfreak
Originally Posted by ital_cossie
very nice build!!
The cage is from omp racing.
I have doorbars.
I make this saturday new pics
Old 03-01-2011, 09:51 PM
siscossie
3-door moonstone
siscossie's Avatar
very nice, coming along nicely!!
Old 04-01-2011, 10:21 AM
Brian
Brian's Avatar
Very nice
Brian
Old 05-01-2011, 11:03 AM
m.ohlsson
m.ohlsson's Avatar
very nice! look forward to see more pics
micke
Old 09-01-2011, 06:48 PM
Cosworthfreak
some new pics
Old 09-01-2011, 07:05 PM
Cosworthfreak
sry i deleted the old photos
so here some old
Old 09-01-2011, 07:51 PM
Dan_RS500
Dan_RS500's Avatar
Very nice shell, look forward to seeing it take shape
Old 09-01-2011, 08:21 PM
Yogi.
Yogi.'s Avatar
hi, das auto hast aus ebay oder? hatte damals auch überlegt dort zu zuschlagen der teile wegen...
und die selbe zelle von omp hab ich auch. hat die bei dir auch überhaupt nicht ohne änderungen gepaßt?
grüße
yogi
Old 10-01-2011, 08:32 PM
Sandro
Sandro's Avatar
Very nice!! good work!! Parle français ou Allemand? Moi les deux...fait moi signe si ça te dis..pourrai se rencontrer!!
Old 11-01-2011, 09:14 PM
Cosworthfreak
grüße
yogi
Servus
Ja das Auto ist von e-bay. Hatte sehr viel Rost....
vordere Kotflügel,.. hintere Holmen,.. vordere Dome
aber bald rostfrei
Die Zelle passt. Wo hats bei dir nicht gepasst?
Old 11-01-2011, 09:15 PM
Cosworthfreak
Ich spreche deutsch. Je ne parle pas francais
Old 12-01-2011, 08:06 AM
Sandro
Sandro's Avatar
Ok, ich rede nicht perfect deutsch.. ich habe gesagt wenn du lust hast konnen wir uns treffen, sehr schone arbeit auf deine 3dr!!! kompliment!!
Old 12-01-2011, 09:17 PM
Yogi.
Yogi.'s Avatar
bei mir waren die grundplatten von der hinteren radhausabstützung schon von werk aus angeschweißt, problem war das das linke rohr zu lang war, was noch garnicht soo schlimm war weil mann ja die grundplatte abtrennen und das rohr kürzen konnte. schlimmer war dann das das rechte rohr gut 20 - 30 mm zu kurz abgeschnitten war.. omp hat mir dann ein neues hinteres teil der zelle geschickt wo wie bei dir die grundplatten zum selbst aufschweißen dabei wahren.. das schlimmste ist eigentlich das mann die "schraubzelle" wegen den türstreben ja garnicht mehr raus schrauben kann.. so schauts jetzt bei mir aus..
Old 13-01-2011, 11:01 AM
Cosworthfreak
bei mir waren beide zulang hat dein bügel bei beiden A-Säulen den gleichen Abstand?
Hast du das Dach ersetzt? (kein Dachfenster mehr)
MfG
Old 13-01-2011, 08:32 PM
Yogi.
Yogi.'s Avatar
hi, ich hab einfach die kassette raus getrennt und die aussenhaut eines stahlschiebedachs vom bmw e36 passen eingepunktet. das hat zu 99% die selbe wölbung wie das restliche dach.
der vordere hauptbügel ist an beiden a-säulen gleich eng anliegend, war nur mit nem dicken kunststoffhammer möglich den in position zu bringen.
da ich das auto ja für eine rennserie aufbaue und ich sehr unzufrieden bin, denke ich das ich die zelle vielleicht irgendwann nochmal rausschmeisse und das auto zu nem richtigen zellenbauer geben werde.
Old 04-02-2011, 09:46 AM
Cosworthfreak
Here some pics from my sapph.
before restoration:
Old 04-02-2011, 09:59 AM
adam151082
adam151082's Avatar
Nice work, looking forward to the build up
Beau travail, impatient de l'accumulation
Old 04-02-2011, 11:31 AM
Cosworthfreak
Here some new pics.
windows removef
Old 04-02-2011, 02:09 PM
cozzy jeff
cozzy jeff's Avatar
where did you source your panels?im after a slam panel and n/s wing.
Old 04-02-2011, 02:29 PM
Cosworthfreak
i bought enough wings and panels 2 years ago from Ford.
Old 04-02-2011, 03:00 PM
adam151082
adam151082's Avatar
Did you damage the rear 1/4 window trim removing it? Or do you have new parts to go in?
Old 07-02-2011, 08:56 PM
Cosworthfreak
i don't damaged it but i also have new ones
Quick Reply: Project Sierra RS Cosworth from Switzerland
