mk2 escort estate RWD turbo,
Old 31-05-2011, 03:32 PM
  #161
mk1turboestate
mk1turboestate's Avatar
Originally Posted by XRT_si
Looking good mate, it's making decent progress. For the remotr ISCV look for the housing off an early XR2i
Mine started at the weekend by the way
glad to hear you got it started, did it all go smoothly?
im hoping to atleast start it up in the next month or so,
am i rite in thinking a use the takeoff on the inlet manifold just behind the throttle body, and then a takoff on the crossover pipe needs making for the ISCV?
cheers for ur help
Old 31-05-2011, 04:35 PM
  #162
XRT_si
XRT_si's Avatar
Yes, I'm sure that's how you plumb it up but haven't seen/done one in ages.
Mine leaked fuel everywhere and took about 3 hours to work out why/stop it. The map's crap too, but other than that it's alright!
Old 31-05-2011, 05:16 PM
  #163
andy escos
andy escos's Avatar
or you could get this billet housing on ebay
http://cgi.ebay.co.uk/ws/eBayISAPI.d...T#ht_500wt_949
Old 31-05-2011, 07:27 PM
  #164
mk1turboestate
few pics of the water pipes
all the water pipes are done now, inc heater matrix, just need to get some jubilee clips,
Old 31-05-2011, 09:24 PM
  #165
mk1turboestate
couple more pics, return to the engine with a take off for the header tank,
heater is plumbed in now but i forgot to take a picture, you can see where is going tho
return on the rad with the heater/ inlet manifold return going back to the water pump
just need to get a header tank now, the turbo cooler is also plumbed in now aswell, feel like im getting there now
Old 31-05-2011, 09:46 PM
  #166
XRT_si
XRT_si's Avatar
Look much better in black. Nice progress.
Old 31-05-2011, 10:03 PM
  #167
mk1turboestate
cheers, i thought black would be best, im keeping the blue to under the car, want the bay to look neat, its getting more full by the min though, i didnt appreciate how much work goes into a custom system, and thats pretty bad considering a fit central heating for a living,
the wiring is a bit of a pain aswell, by rs bible has a brake down of the wire colours so i will spend a couple of hours getting my head round it,
fuel lines i will do in 10mm copper for now with an rs turbo pump i think so im really hoping to get it running before to long
Old 09-06-2011, 07:26 PM
  #168
mk1turboestate
iv been sorting out some of the fuelling, got the petrol tank in and the hard fuel pipes fitted
just need to fit the flex between the tank and lines and the inlet,
im getting there now but i need some of the connectors that go on the rs turbo fuel pump and cant seem to find any??
Old 09-06-2011, 07:47 PM
  #169
XRT_si
XRT_si's Avatar
For the fuel pump connectros I just adapted some spade connectors.
What axle are you using?
Old 09-06-2011, 07:50 PM
  #170
mk1turboestate
i will try that then, maybe put some heatshrink over it all,
the axle is a capri 280s with lsd fitted, already shortened and brand new brakes,
absolute bargin aswell
Old 12-06-2011, 12:16 PM
  #171
mk1turboestate
bit of an update, all the fuel lines are finished, piped up to tank and inlet manifold, fuel pump is in as a temp fix untill i sort a decent bracket for it out,
iv finally got the oil in the engine and had it turning over on the starter with 15 psi at the dial,
im going to do a temp wire up of the fuel pump this afternoon and may put fuel in and test the flow and return lines are working ok,
pretty happy with the progress now, i need to sort out some ht leads for it if anyone knows of the best type without costing to much
i could also do with a decent t3 turbo downpipe that i can cut up if anyone has one
Old 12-06-2011, 02:12 PM
  #172
mk1turboestate
the fuel pump is temp wired now and iv had it working, had a stight leak on the powerboost valve but iv sorted that now, had it running for a while with no problems, the tank feeds and swirl pot i fitted in the tank must be working ok hopefully if i can figure the loom i can start it as long as all the second had part work ok
Old 13-06-2011, 08:45 PM
  #173
mk1turboestate
small update, just spent about an hour doing some wiring, made up the fuel pump and fuel injection relays and fitted them up to the car, plugged in all the connectors and put a battery to it,
got my one second pulse on the fuel pump and all the fuel injectors seemed to click, since the starter turns i just need to sort the ht leads and it mite fire
should it fire without the turbo connecting so i dont need to make an inlet for now or not??
Old 14-06-2011, 05:37 PM
  #174
mk1turboestate
Default engine has started
sorted out some ht leads today and she fired up first try so i am verry happy considering its on efi now and not mechanical, and everything on it was used,
i need to sort the wiring out properly now and tidy it all up inc sorting the wiring to the rest of the car
Old 19-06-2011, 11:56 AM
  #175
mk1turboestate
iv ran out of cash to spend on the car now so iv started sorting some other bits out that need doing today,
stripping the doors, tailgate, bonnet, antidive kit and a few other bits ready for repairs and then bead blasting so i can hopefully get the whole car in primer next month
Old 29-06-2011, 07:46 PM
  #176
mk1turboestate
iv just got back from picking up the doors, tailgate, bonnet, roll bar, and a few other bits from the sand blaster,
they have all come up pretty well, the bonnet is mint, tailgate needs a small repair behind where the numberplate goes, one door needs a couple of small repairs on the bottom edge, the other need the entire virtually replacing but there are no major dints on anything,
i will get some pics up soon,
i will get it all sprayed in red oxide asap and start on the repairs next week hopefully,
i want to get everything fitted up as soon as i can so i can get the whole car in primer,
im really happy how its going so far, ideally i would like to get it sat on all four wheels but cant justify buying all the front end steering parts when i need so many other things
Old 29-06-2011, 08:31 PM
  #177
retro d
retro d's Avatar
Looking good Bud.
Old 07-07-2011, 07:59 PM
  #178
mk1turboestate
iv started work on the passenger door now and found the bottom was rotton, i have welded up the inside and need to sort out the bottom of the skin now,
i pulled it out of the garage and had it running for about 5 mins and the sump gasket is pissing out, not happy so im leaving it for abit and im going to get the body sorted,
Old 07-07-2011, 08:00 PM
  #179
XRT_si
XRT_si's Avatar
Was wondering how this was coming along!
Old 07-07-2011, 08:15 PM
  #180
mk1turboestate
its going ok, bit pissed off with the oil leak, its been sealed and everythin, never mind im leaving it for a while now and will get on with the bodywork, i also need to sort a prop for it,
if i can get it in primer over the next month or so i should have it finished for some shows next year all going well
Old 10-07-2011, 02:33 PM
  #181
mk1turboestate
couple of bad quality pictures of one of the door bottoms part way through repair
Old 14-07-2011, 08:53 PM
  #182
mk1turboestate
iv been doing some work on both doors now, i got the ns door in primer but forgot to take a picture, they were both solid but had a few dents that needed filling
i should get the os door in primer tomorrow and the holes welded up where the chrome trim went around the windows
Old 17-07-2011, 08:31 PM
  #183
mk1turboestate
iv got one door in primer now and one in red oxide, i will get some pics tomorrow, they still need a good wet flat but since its not ready for paint im not aiming for perfect yet. just glad its begining to come together
Old 19-07-2011, 10:23 PM
  #184
mk1turboestate
forgot to up load my pics, i have one door painted to have a look how straight it is before final paint and the other ready for a wet flat and probably re prime
Old 19-07-2011, 10:35 PM
  #185
mk1turboestate
as i have said its just to see how they look and they were painted outside, i dont think im a painter but it looks ok, not had a machine polish yet, what do you think?
Old 26-07-2011, 08:01 PM
  #186
mk1turboestate
started painted the insides of the doors and tailgate
made a start on the anti dive kit heater vent and bonnet aswell
i then decided i wanted to mount the coilpack neatly, thought about boxing it into the heater bubble but in the end came up with this
it still needs some filling but im happy with it and should look a bit better in the bay
Old 26-07-2011, 09:01 PM
  #187
mk1turboestate
tailgate pic
Old 27-07-2011, 08:07 AM
  #188
XRT_si
XRT_si's Avatar
Love the coil mount, I wanted to do something similar with my heater bowl but a previous owner had butchered it beyond repair. Looks lush that.
Old 27-07-2011, 08:47 PM
  #189
mk1turboestate
done abit more on it today, what do you think??
anti dive kit painted
quick fill and test fit
painted a few more bits
i really like the look of it now, the oil filler will be moved to the front with a sierra rocker cover i have so wont be in the way when its fitted
Old 28-07-2011, 09:36 AM
  #190
mk1turboestate
iv made a bit of a start on the wiring iv taken all the tape off so i can re loom it, need to find some standard injectors for now aswell,
i need to sort out what managment to use and could do with some advice, i really want it rite first time
im thinking megasquirt but dont no anybody who will map it for me, body isnt far off now so needs sorting
Old 14-08-2011, 03:25 PM
  #191
mk2mania
mk2mania's Avatar
certainly looks like its gettin there,, keep it up,,not be long b4 your on the black stuff,, cheers rick
http://www.youtube.com/watch?v=zgrzwySTFKw
Old 17-08-2011, 08:07 PM
  #192
mk1turboestate
done a bit on the car tonight, re fitting some of the parts that i painted up, bit more space in the garage now, and its starting to look like a car again
Old 18-08-2011, 09:03 AM
  #193
XRT_si
XRT_si's Avatar
Good to hear! All game for sunday?
Old 18-08-2011, 11:15 AM
  #194
mk1turboestate
Just got to scrape 12 months of crap off and fit the doors and I will be ready, I put my f o r d grill on last nite for the first time and looks quality!
Should have it ready Saturday,
Still can't find wheels yet, think I'm going for banded steels now but need to decide on a style??
Old 18-08-2011, 11:32 AM
  #195
XRT_si
XRT_si's Avatar
Ha! Sounds like it's given you some inspiration then!
Has Chris got in contact with you and arranged it yet?
Banded steels are very cool
Old 18-08-2011, 03:32 PM
  #196
mk1turboestate
yeah its a bit of a push to get a bit more done, only stuff thats been hanging round in the way and needed doing, im hoping to get the doors hung tonight and sort the garage so there is a bit of space,
chris has called and is coming sunday afternoon, seems a sound lad and will hopefully make the car look good for me,
when are you looking at getting it in for?
Old 18-08-2011, 03:42 PM
  #197
russ rs
russ rs's Avatar
good luck mate
Old 18-08-2011, 03:49 PM
  #198
XRT_si
XRT_si's Avatar
He's a really good lad and takes a stunning picture; have a look at some previous issues for his work.
It will be going in for next month
Old 18-08-2011, 04:21 PM
  #199
mk1turboestate
quick couple of pics taken with the iphone
its started raining now and i need to pull it out the garage to fit the passenger door so it will have to wait
Old 18-08-2011, 09:07 PM
  #200
mk1turboestate
got a fair bit done tonight, sierra rocker cover fitted car half cleaned, couldnt fit the ns door because it didnt start raining, will be done tomorrow
Quick Reply: mk2 escort estate RWD turbo,
