mk4 sills and rear wheel arch help (fitting)
hi does anyone want to share there knowledge got new full sills and rear wheel arches and i'am wondering if anyone has a step by step guide (idiots guide) to fitting them have all the tools needed for the job just don't know where to start.. any help out there
Hi mate the only thing I'd say is to do your resurch, look at how the cars constructed, ask in a bodyshop, not your local garage!! I've seen some very poor weld repairs done by garages that only want to get it welded for the mot!!. Over welding in an area can put excessive amounts of heat between the joints and not only possibly burn up your car, but also make it rust faster than it already is!!! ...but anyway good luck I wish you all the best with your project
cheers for that mate but get ur point about garages and mot work the sills were welded about 12 months ago as was passenger floor pan and true to what you said rough as shit lol they patched from underside and didnt even take carpet up and you can see that they must have wet it whilst doing the job wasnt in my hands then but is now
cheers for the advise
If you place the repair panel over the top of the original panel, then cut through both at the same time ,That will give you as close a fit as any . then cut a 30mm strip off one of the off cut's and tack that under neath the original panel with 15mm sticking out so that when you weld the new panel on ,you have something to weld to.
that's how we used to do it in the body shop's , Gives a strong joint and better than just butt welding
track.focus'd
12-08-2015 05:53 PM
paceo
12
04-08-2015 08:50 PM
