V8 Chevy Sierra Track Car
Hi and welcome to my thread, im going to be logging the modifications to my five door Sierra as i continue to prepare it for trackdays.
Brief Spec so far is -
*5.7 Small Block Chevy V8 sourced from an old V8 Euro Car
*Rebuilt Richmond racing four speed gearbox
*Tilton racing flywheel and racing basket clutch kit
*Home made tunel & bulkhead moving engine 12 inches
*Summit Racing 3inch x-pipe exhaust
*Hedman Corvette exhaust headers
*Rebuilt 7.5inch 2wd Cosworth Diff with 909 Crown wheel and Pinion
*330mm Pro Comp discs on alloy bells and four pot calipers upfront
*Escort Cosworth rear calipers and and groved discs
*Leda tarmac rally spec front coilovers and Bilstien rear shocks & springs
*Five Gallon Alloy foam filled fuel cell
*Modified rear axel mounting points, polybushed & alloy beam mounts
*Motor Drive carbon composite bucket seats
*Autometer Recall rev counter and oil / water clocks
*Vauxhall corsa electric power steering with adjustable resistance control
*Quick rack steering kit
*Canton Racing Sump and Morosso Oil pressure Accumulator
*Wilwood floor mounted brake bias pedal box
*Holley Red type electric fuel pump with built in regulator
*Black Diamond braided brake hose kit
*11mm Braided fuel hose
*Adjustable top strut mounts
*Compression strut kit
*3 Door Cosworth grill, front bumper and rear spoiler
*3 inch Racing alloy radiator
*Mallory Racing Distributor and ignition coil kit
*Quick fuel Technology 750cfm Racing Carb Kit
Will add recent pictures shortly, to see progress so far check out my garage
Last edited by Shaggy's Auto Store; 30-11-2010 at 03:59 PM. Reason: http://passionford.com/forum/garage/1988-Ford-Sierra-17-ShaggysAutoStore.html
track.focus'd
12-08-2015 05:53 PM
