Mondeo 4x4
Mondeo 4x4
I think its about time I started documenting the work I am doing on my Mondeo.
so far I have striped the interior.
moved the battery to the boot.
fitted a nice steering wheel.
bought the seats (Forza 2000) with Luke harnesses.
fitted the induction kit.
ported and polished MAS and throttle body.
slowly fitting all the switches back together where the dash will be.
out working on the car today. managed to kind of fit the drivers seat, it will do for the MOT but ill wield it in properly over xmas. I have also ordered the blanking plugs for the EGR. door cards should have been on but my Ł6 rivet gun gave up.
full day tomorrow more updates then.
half pulled off the egr and picked up the blanking plugs to do the rest when I get some time in the light. spoken to a friend who is breaking his frst so thats the inlet sorted.
read it some where, its the HO one so makes sense, as the old plastic one had all the tags and burrs in it. and the new one is ported and polished. is it not better flow then?
I know its a bodge but it will have to do for now. I had some trouble getting the throttle to open properly but I got there in the end, ran it up to full temperature and all was good, ideals fine.
I bought a new rivet gun so i could put the door cards on.
and I fitted the harness.
the way you have mounted them harnesses is dangerous, the load is not going to be spread where it attaches to the seat belt wire and in an accident it could or would slice through it, you must mount it through the floor with backing plates underneath to spread the load.
steve
steve
the way you have mounted them harnesses is dangerous, the load is not going to be stpead where it attaches to the seat belt wire and in an accident it could or would slice through it, you must mount it through the floor with backing plates underneath to spread the load.
steve
steve
ill see what the MOT man says. I was thinking about cutting a seatbelt and threading the harness through, if you get what I mean.
the harness mount is bad, i would change that.
in the p100 i drilled two 10mm holes in the floor and welded 15/20cm 1/4 inch plates underneath with captive nuts and mounted them.
the seat mount looks abit basic aswell.. if thats the word to use :')
if you cant afford the proper mounts just adapt the standard ones, that way the seat still moves.
ive done this in both the p100 and the mk1 in the same way, just two large adaptor plates that bolt to the seat mount where the standard seat would and holes to allow the bucket to be fitted.
had a good crack at it today tidying up the wiring and mounting the fuse board and a couple of other bits.
it didn't even look that foggy until i took these photos.
