omulis: Ford Scorpio RS
Hello everyone!
I wanted to show in his Ford.
I got this system in 2005. Then it was a pretty sad sight! Gradually I began to arrange and lead a little fascinated: D
A little more about the car:
1992 Ford Scorpio 2.0 DOHC
From the Extras: electric front windows, mirrors. Lots of rust and visual defects.
Today, in 2010 year it looks like this.
Tell you more about the process of reconstruction!
Dokomentus straightened.
Washed, cleaned.
I bought a donor for leather seats and all the electronics.
Confusing the interior out to see the floor. There were a couple of holes in the floors and thresholds were welded seams. As well as arches. Rust was also on the rear trunk lid, door bottom, above the windscreen, had to work on bumpers. Certainly have been the case to be made to the bodywork. Just can not remember: D
The rest of the rust'm not shooting. At that time, the time was a shame: D
Washed, cleaned.
I started out confused donors. I took out the necessary wires for electric seats, electric sunroof, electric windows, lighting and other little things.
All necessary cables are removed!
Rear electric window regulators.
Treated floor.
I started the preparation work before painting.
Painted.
Also made a different front grille.
While the dye house was a spare moment .. Cleaned the headlights.
I started to put the car together. Paco car door and the floor.
Treated floor.
Painted.
Turbocharging Technician
Tell further than the Ford.
Luke was, but it did not work. The donor was working in a hatch, then one of two folded.
Ford was the central key, but could not break the console. Therefore, installed alarm system.
I bought the best fog lamps, and they changed the.
I had also installed the illumination under the doors. As well as in the cabin under your feet!
ILike and better speakers in front. The back was good.
Luc original of speakers because it sounds very good!
Changed the casing around the gear lever.
Ta when the car was now ready technically and visually, then changed the springs from below.
The lowest I could get for him was-30mm: (
It therefore had polled ..
Unfortunately, there are very few pictures of the writing, marry, because there was no time shots! Screw lock: D
Next, I started to look for better discs.
A couple of options and I went to watch and measure.
The problem was the fact that more wide discs do not work in front of the suspension prevented.
Was too small et. : (
These were the R17 8J ET38
When lawful seats from the donor, then interior lacked the full panel and the front door facings. This long-sought and found!
Was to replace, as was the old blue and new black!
Finally found my dream wheels for this car
BBS RS R16 8J ET11
The court very poor condition. Toas the performance should weld, straight and restore.
they fit )))
In winter they are taken apart and restored.
Shelving, polished, chrome bolts
BBS RS R16 8J ET11
they fit )))
