Quick CVH bearing size question.. Help appreciated
Hi guys,
just a quicky, my CVH Turbo had 0.4 O/S Main Bearings from new ,.. Im looking at getting a Steel Crank for it and was wondering if it would be easier to source a Standard size block to start with as ive heard Ford put the oversize bearings in too compensate for crappy line boring from new?
I did see a thread on here some time ago with a similar theme but cant find it anymore.
Sorry to ask the same again!
Cheers , Pete
Cheers , Pete
Hello mate post this in the RS turbo section not the project section and you will get a few reply's.
For now i think burtons stock the weird sizes ford used to make up for shoddy blocks???? but if you want a steel crank i assume you have loads of money to waste and want good power.... so you will be going efi as well?
If thats true you may as well source a fiesta efi block with the cps hole and sort two problems in one.
Good luck
Rob,
Good luck
Rob,
Hi mate - I posted a while back about the same thing in my resto thread for my xr3i - dunno if that was the one you saw.., mine too had 0.4 o/s mains and rust me they are almost impossible to find ! as I wanted to keep my engine standard. You are correct that they put these in to compensate for overboring ... let me know if you find anyone who has em !!
Graceland
31-07-2015 10:34 AM
