Rs Turbo filler cap
Old 14-05-2010, 01:40 PM
TomrsT
TomrsT's Avatar
Question Rs Turbo filler cap
Whats the Best way of fixing this rusty bit without taking the side pnls off?
Just cut away the fillercap so i can access the inner wing?
Old 23-05-2010, 08:08 PM
TomrsT
TomrsT's Avatar
Old 23-05-2010, 08:09 PM
TomrsT
TomrsT's Avatar
who knows where i can find this bit ? Its to far gone to refurbish
Old 23-05-2010, 08:14 PM
whizzisat114
whizzisat114's Avatar
Id see if you could get a part from the scrap yard, failing that id make it in sections and weld it together
Old 24-05-2010, 12:28 PM
markc
markc's Avatar
get on to ford parts uk, you can still get them new for around 20-30 quid.
Old 24-05-2010, 01:50 PM
rs combi
rs combi's Avatar
i cut mine out from the back and replaced it with bits i cut out of my combi
havent got a pic from the underside but it was part of the combi origonal inner arch about 2" bigger than the cup
tacket the cup in and seam welded the plate back over
Old 24-05-2010, 03:16 PM
TomrsT
TomrsT's Avatar
Ok i'm going to take a look @ the breakyard to look for my needs.
I allready know a place where there r a couple of old fords...bin there allready
here r some pic's :
not bad this one! Sierra 2.3D GL
this is going to be the donor
Old 29-05-2010, 06:54 PM
TomrsT
TomrsT's Avatar
I've had a good look around the breakyard and this was the best of all..
Not good as you can see, the paint is blistering because of the rust behind it.
So i have made it myself, with some nice hard wood and a 'woodmill'?
cut the back out end put my pl8 in
Only need to weld it fully end finish it now
Old 29-05-2010, 07:02 PM
Good work
bigryrs
28-03-2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
21-01-2016 09:54 PM
Matt Baxter
16-09-2015 08:30 PM
63np
22
06-09-2015 01:45 PM
Escortdriver1
13-08-2015 05:55 PM
Quick Reply: Rs Turbo filler cap
