Wrc escort hafsengen replica
Old 24-07-2015, 12:13 PM
  #1001
chodjinn
chodjinn's Avatar
I don't often post on this forum as I'm not a ford owner, but I have followed this for a while. The rear rad work is brilliant and your work on the carbon cover is amazing for a first timer, so much so you've convinced me to have a go eventually!
cossiedevil (26-07-2015)
Old 28-07-2015, 09:13 PM
  #1002
cossiedevil
cossiedevil's Avatar
Originally Posted by COSSIEGAZ
Amazing work mate what did you decide to do with the cross brace to the front turrets? did you put a bend or leave it straight over the inlet manifold or are you still figuring that out? Look forward to the updates and the carbon fibre surround for the rad came out really nice, was it easier than you thought and did you heat it to dry or leave it to harden?
The cross bar is able to stay as is ,the carbon was a bit easier than i thought as i expected to at least have to do it a few times but came out very well for my first time and i had my shed at 20 degrees that was the only heat but have to say that the laminated epoxy resin when mixed to the spec sheet, what was left over in the pot you would think it was going on fire with the heat and smoke leaving it when going off scary sh*t
Old 28-07-2015, 09:57 PM
  #1003
cossiedevil
Some wee jobs done,Someone did post way back to what was i going to do with the o.e shock gussets as the wrc cars had different ones welded in so i made these myself,
Old 28-07-2015, 10:10 PM
  #1004
james kiely
james kiely's Avatar
It's going to be epic David
Old 29-07-2015, 09:47 AM
  #1005
cossiedevil
Thanks James
Old 29-07-2015, 06:59 PM
  #1006
cossiedevil
welding up all the holes in the front wheel arch's,
Old 04-08-2015, 06:35 PM
  #1007
reese646
reese646's Avatar
Looking Great David, Really need to get some more done on mine, its looking sad as its been sat for nearly a year since I last touched it.
Now your back on it if your interested I happened to get access to one of the last Ford works built WRC cars and have around 100 pictures of the bare shell inside and out and the underside, let me know if you fancy them as theres quite a few little bits that you wouldn't see otherwise.
Looking great and good progress mate, the carbon work looks fab, did you make your own engine mounts by the way or order them as I fancy making my own, catch you soon and let me know on the pics
cossiedevil (06-08-2015)
Old 06-08-2015, 07:26 PM
  #1008
cossiedevil
Thanks fella,these cars can eat up time i have been on and off it and nearly two years sitting till late,as other things needed my time and got the car in may 2011,thanks for the offer on the pics progress is going very well in fact better than i had thought maybe it paid off to be away from it for awhile engine mounts are genuine gordon vincent made that i got from dewitts
Old 07-08-2015, 08:30 AM
  #1009
cossiedevil
Made up strap's to hold the fuel cell in place to match in with hafsengen style,
Old 07-08-2015, 09:46 AM
  #1010
whizzisat114
whizzisat114's Avatar
Going to be one hell of a car when it's finished
The attention to detail is off the scale
Old 07-08-2015, 12:28 PM
  #1011
COSSIEGAZ
COSSIEGAZ's Avatar
When you had two pieces of carbon over lapping was there much of a ridge cause of thickness of material? Did you sand it flush or when you rolled it to get rid of air bubbles did it flatten it?
Old 07-08-2015, 12:45 PM
  #1012
cossiedevil
Thanks fella
the way i did it was Clear laminated coat first left 3 hours to go tacky then lay down first layer of carbon pushed down by hand and then paddle rolled,and then half hour between each layer put on after each paddle rolled total layers used 6 left over night and pulled out from the mould next day
Old 07-08-2015, 01:16 PM
  #1013
COSSIEGAZ
COSSIEGAZ's Avatar
Your doing an amazing job mate and look forward to one day seeing it in the flesh. Would you recommend people to have a go at carbon fibre now you have tried it? How much more body prep do you think you have before you paint it again?
Old 07-08-2015, 01:52 PM
  #1014
cossiedevil
Thanks ,as for the carbon fiber I have work with fiberglass so had a wee heads up but I would say if your able and watch a few vidz you can do it for me mine was a very big area and its not 100% but will have to do but in saying that I have also bought carbon parts and they where not 100% air bubbles in the clear coat etc so I reckon it take a good man or company setup to do it right,as for the shell all that is left is to weld in my mounting nuts for the six point harness and paint then
Old 07-08-2015, 07:47 PM
  #1015
frayz
Boost Junkie
frayz's Avatar
I love checking back in on this. Stians car was and still is the greatest escort dossier ever built IMO. Superb that you're attempting to recreate it in such detail. Really makes its special. Look forward to seeing more.
cossiedevil (07-08-2015)
Old 07-08-2015, 09:27 PM
  #1016
cossiedevil
well guys Shell work is nearly finished its took soon time alot of cutting and welding and totally more than i thought i was able to do but the shell is nearly to full wrc spec ,
alot has changed to what is was when i got it,
Old 08-08-2015, 04:58 PM
  #1017
reese646
reese646's Avatar
Very impressive mate, been worth the wait. I bet like me you'll be happy to finally stop telling people "when the shells done its just bolt it together" lol it just takes forever to get the shell done
How much of the bolt on stuff are you missing, I think your probably not far off.
Old 08-08-2015, 05:04 PM
  #1018
reese646
reese646's Avatar
Meant to ask are you going for the big front diff with it been right hand drive, as I have actually seen a group A car that had the large diff and was right hand drive, he had a knuckle setup that transferred the steering across to the passenger side, so it is possible.
Old 08-08-2015, 06:43 PM
  #1019
frayz
Boost Junkie
frayz's Avatar
Proper shells take ages. Mines been in prep since the start of February.
Cossie shells looking amazing.
Old 08-08-2015, 07:23 PM
  #1020
cossie martin
cossie martin's Avatar
Awesome Project!!
Old 08-08-2015, 07:45 PM
  #1021
Focosmitch's Avatar
Awesome! Looking forward to seeing it in paint!!
Old 08-08-2015, 07:48 PM
  #1022
fezzajsy
fezzajsy's Avatar
Looking good
Old 08-08-2015, 08:01 PM
  #1023
Adam-M
Adam-M's Avatar
You still messing with imprezas and hankering for a cossie or have you made the switch Yet mate? Followed your build thread on scooby bet I could well tell your were dying to get back into a cossie lol
Old 09-08-2015, 09:50 PM
  #1024
cossiedevil
Thanks fella glad to see it nearly all done and not bad as all done with no help at all missing very little bolt on parts just cant wait to get to that stage,Also diff will i hope be mainly issue free,
Thanks fella long time coming,Also you scooby is savage and not a cheap job been done to the shell
Originally Posted by cossie martin
Awesome Project!!
Thanks
Originally Posted by fezzajsy
Looking good
Thanks
Old 10-08-2015, 09:20 AM
  #1025
cossiedevil
Some more new goodies freshly made supplied by dewitts was worth the wait,So just have to build the uprights up,
Old 10-08-2015, 11:19 AM
  #1026
frayz
Boost Junkie
frayz's Avatar
Still got it, and yes its in a million pieces again.
No there still wasnt anything wrong with it, and yes im an idiot! lol
Old 10-08-2015, 07:30 PM
  #1027
zetaboostboy522bhp
zetaboostboy522bhp's Avatar
Nice work and iam so glad to seeing it built up.
Can I ask how much the drive flanges , bolts and sleeves are pm me if you like
Cheers paul
Old 10-08-2015, 08:05 PM
  #1028
cossiedevil
Cheers paul
Thanks Paul im glad myself to see it coming along
Flanges,bolts and sleeves from dewitts where €2214,the euro to sterling is very bad but put it in at .68 comes to Ł1506 paid for these back end of February they had non in stock so had to wait on them being made only got them 2 weeks ago,
Old 11-08-2015, 10:41 AM
  #1029
cossiedevil
Upright are complete done all the press work on them,
my workmate for the job,
Old 11-08-2015, 06:00 PM
  #1030
whizzisat114
Very nice �� ��
Old 13-08-2015, 01:56 PM
  #1031
thielt1
thielt1's Avatar
I love those wheels, glad to see you working on this again!
Old 13-08-2015, 03:27 PM
  #1032
COSSIEGAZ
COSSIEGAZ's Avatar
Are the wheels 18s or 19s? I thought stian ran 19s or was it his white wheels that were 19s
Old 13-08-2015, 06:02 PM
  #1033
cossiedevil
Very nice �� ��
Thanks lads
Wheel's are 18" same wheel as what stian got with the rolling shell and used at the beginning,19" rims where speedline's 2014 sc magnesium rims the white ones, stian sold these and where on a escos in Sweden then they where for sale pm the guy but never got any further than that i was emailed about another set that where fitted on a rs200 that stian was working on but rims and car was bought by ken block,And have emailed and contacted speedline to see could i get new set's made but they where not interested,So the sparco comodora reps will have to stay and as its a pre crash first build rep of hafsengen cars these are the rims he ran on it first outing for gatebil
Old 13-08-2015, 10:10 PM
  #1034
COSSIEGAZ
COSSIEGAZ's Avatar
Cool I like these wheels think it had a more aggressive stance to it but the speedlines were nice. Are you copying his dash and control panel or slightly changing it? If it's gonna be a true rep then it would have to be the same even if all the buttons didn't work for what they were meant too? Interested what your planning to do and as always look forward to the progress. Reminds me I have the DVD of his car so will have to watch it for the 90th time lol
Old 14-08-2015, 08:41 PM
  #1035
Cossiesteve
Cossiesteve's Avatar
Being new to pf i have sat and read the entire build thread to date and i must say the car is a work of art, and to be fair I've always had a soft spot for stains car from all those years back, so seeing someone replicate an iconic car in such great detail is awesome, look forward to following this build mate
Old 14-08-2015, 09:12 PM
  #1036
Cool hubs them. Nice wheels too.
Old 15-08-2015, 06:09 PM
  #1037
cossiedevil
Thanks very much Guys
Few pics of my rear rad setup as carbon surround cut to allow heating pipes run out ,
Old 17-08-2015, 04:01 PM
  #1038
COSSIEGAZ
COSSIEGAZ's Avatar
( just asking) was there no way to get the fitting for the surround so you had a pipe from rad to surround then surround to engine? Just thinking if you could of kept it fully sealed? It's looking good thou mate.
Old 18-08-2015, 12:27 PM
  #1039
cossiedevil
it would be very hard as the rad takes screw on fittings not push,so would be alot of work to make it sealed, but it will be done the same as hafsengen where the cut out will get sealed up with heat tape,so no heat are air to get into the cab,
Old 18-08-2015, 12:35 PM
  #1040
M K
M K's Avatar
Excellent work my friend
Quick Reply: Wrc escort hafsengen replica
