Wrc escort hafsengen replica
#961
Centrally heated! Nice
Are you doing your own panel fab, like your radiator boot recesses, or is someone doing those to your spec? They look nicely worked items.
Iain
Iain
#967
cossiedevil (06-07-2015)
#977
Fantastic to see you back at it, mines at the pre roll-cage stage, those rear turrets are a nightmare lol, thanks again for the help with the rear arches they went pretty well. That said did you really take the underside back off again :-/ glutton for punishment, looking great though, will be keeping tabs
#986
#987
I had to make my own carbon fibre radiator surround similar to hafsengen on the outside as i was in contact with company's over none wanted to make it for me so i had to read up and have a go at something i know nothing about,
What i want it to look like,
resin coat,
first layer of carbon,
more layers
taking out of mould
resin coat,
more layers
taking out of mould
#991
Thanks Guys,
Dave the housing will be bolted down to the floor And a rubber seal around the edge lip to seal air from getting into the car at the bootlid
cossiedevil (21-07-2015)
#1000
Amazing work mate what did you decide to do with the cross brace to the front turrets? did you put a bend or leave it straight over the inlet manifold or are you still figuring that out? Look forward to the updates and the carbon fibre surround for the rad came out really nice, was it easier than you thought and did you heat it to dry or leave it to harden?
