PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 05-09-2010, 12:05 PM   #201
RS_Rob
Trader Score: (0)
RS_Rob is an unknown quantity at this point
thanks mate,
i had my doubts with the red at first
but i think i made the right choice now
__________________
RS_Rob is offline   Reply With Quote
Old 05-09-2010, 12:09 PM   #202
RS_Rob
Trader Score: (0)
something i done a week or two ago,
basically as my car originally had power steering and i've chosen to take it off for many reasons
i've come accross the following differences
- steering rack (obviously)
- steering column
- lower arms (but wont apply to me as mine are adjustable)
- the bulkhead grommet
- the bulkhead hole is different aswell
heres a picture of the manual steering rack, with manual steering column
but with the power steering bulkhead grommet, so you can see the problem i had
so using the power steering grommet i made a template of the hole and cut some steel to shape,
then made a hole to the size of the new non power steering grommet ordered from work,
used this hole punch for a neat edge
the result
with the new grommet in
the only problem was that the grommet did'nt fit to good around the steering column
as the grommet ment for the steering rack was'nt available anymore from fords
so ordered the newer version thinking / hoping there would'nt be much difference
so the old man machined a piece of delrin to fit snuggly around the column and to fit inside the grommet
job done
__________________
Old 05-09-2010, 12:34 PM   #203
RS_Rob
Trader Score: (0)
when test fitted the plate to the car i put the steering wheel back on aswell,
which caused another problem
the steering wheel pulled the column further towards the wheel than i'd thought which changed the angle
that the steering column goes through the bulkhead
so made another bulkhead plate, knowing the angle was right this time
i gave it a few coats of satin black aswell
i'll get some pics of it fitted later
bought these bits a while ago
to stop the clicky clutch pedal by converting it from the self adjusting to manual
hopefully should be more up to the job of the 4 paddle clutch
all fitted
except when the outer bracket goes on, it fouls the self adjust bar and does'nt let the pedal go down
after going over the old ford tsb for this upgrade i realised there was a different bracket for the job,
no longer available, but after a few phone calls i got hold of one
a comparison shot, new bracket on the left
all fitted and much better
was an extra spring i got hold of aswell, so thats the pedal box all ready to go
as it has the manual clutch rachet, new bushes etc
__________________
Old 05-09-2010, 01:54 PM   #204
fezzajsy
Trader Score: (9)
fezzajsy is an unknown quantity at this point
Send a message via MSN to fezzajsy Send a message via Yahoo to fezzajsy
looking good mate
fezzajsy is offline   Reply With Quote
Old 15-09-2010, 11:57 PM   #205
RS_Rob
Trader Score: (0)
heres how the steering grommet turned out
if you look lower to the floor you can see the white delrin i had machined,
but not too bothered, it serves a purpose and the engine will be in the way of that view
centre vent all blocked up to make way for the gauges in the dash
put the front wheels on, first time on all fours for some time
__________________
Old 16-09-2010, 12:08 AM   #206
RS_Rob
Trader Score: (0)
more new parts
as most people in work know about this project,
one mate had this from years ago and offered it to the cause haha
cigarette lighter kit,
(thought its one more brand new thing)
new arch liners
got a set of fiesta turbo dials, as they show 150mph rather than 140mph
also my original dials has a dodgy tripometer
and off with the white dials within five mins
__________________
Old 16-09-2010, 02:07 PM   #207
xr2john
xr2john's Avatar
Trader Score: (0)
xr2john is on a distinguished road
That is going to be absolutely stunning mate. Keep up the excellent work
__________________
JUST CANT STAY AWAY FROM MY MK2S
[url="http://s667.photobucket.com/albums/vv39/xr2john/?action=view&current=bf66162b.jpg"][IMG]
xr2john is offline   Reply With Quote
Old 16-09-2010, 07:14 PM   #208
RS_Rob
Trader Score: (0)
thanks mate,
comments like that keep you going, when enthusiasm is running low!!
__________________
Old 16-09-2010, 07:44 PM   #209
Brian
Trader Score: (2)
Brian is an unknown quantity at this point
Looking good mate can't wait to see it finished
Brian
__________________
Brian is offline   Reply With Quote
Old 16-09-2010, 07:57 PM   #210
jamie rst
jamie rst's Avatar
Trader Score: (1)
jamie rst is on a distinguished road
stunning mate just stunning
__________________
www.oddkiddcreations.co.uk
jamie rst is offline   Reply With Quote
Old 17-09-2010, 08:13 AM   #211
WongRS
Trader Score: (11)
WongRS is an unknown quantity at this point
danwong83
Send a message via MSN to WongRS Send a message via Yahoo to WongRS
Quote:
Originally Posted by RS_Rob View Post
thanks mate,
No, find some more, i cant wait to see this car finnished, its going to be something else!
__________________
Dan.
M.A.Developments 500 spec engine, GT30, Autronic, 1000cc injectors, ST Inlet ETC.....
WongRS is offline   Reply With Quote
Old 18-09-2010, 06:37 PM   #212
RS_Rob
Trader Score: (0)
Quote:
Brian
Quote:
Quote:
thanks very much, hope to have a good day on it tomorrow (sunday)
__________________
Old 15-10-2010, 12:19 AM   #213
cosmo V6
Trader Score: (0)
cosmo V6 is an unknown quantity at this point
Looking well sexy Roberta
cosmo V6 is offline   Reply With Quote
Old 04-11-2010, 09:52 PM   #214
RS_Rob
Trader Score: (0)
well some small news,
the engine was been taken to harvey gibb's yesterday,
so when they can fit it in, it will be connected to his engine dyno to be 'run in'
then map it the on the pectel T2 management,
also i've got another gearbox but will explain more on that with another update later
but did a little research on the ratio's which will be in the gearbox,
came up with the following
should be interesting
bought a brand new fuel filler neck pipe as mine just would'nt clean up
and would of stood out like a sore thumb with everything else on the shell being to a good standard
quick iphone picture for now
__________________
Old 04-11-2010, 10:00 PM   #215
12_Second_rst
12_Second_rst's Avatar
Trader Score: (1)
12_Second_rst is on a distinguished road
looking good cant wait to see the next update
12_Second_rst is offline   Reply With Quote
Old 19-11-2010, 10:57 PM   #216
RS_Rob
Trader Score: (0)
well this week my engine was with well known Harvey Gibbs @ scs on the engine dyno
with all connections made such as exhaust, air, water etc etc
then they built the oil pressure up before starting for the first time since the full rebuild
and was run in properly
also i've gone for air injectors for boost control supplied by harvey
today was mapping time
had some figures at different times of the day during the mapping
220bhp @ 3k revs
310bhp @ 4.5k
the escort series 2 exhaust manifold was the first restriction which got the temps up
when it made 365-370
so it was turned down, and map was trimmed for smoothness
so an upgrade exhaust manifold may be sourced at a later date if the power is'nt enough
but i'll deal with what i've got first
final peak power result was
358bhp and 357ft lb of torque boosting at 26psi at the crank
a massive thanks to ian howell who spec'd and built the engine
and harvey gibbs that run the engine in and mapped the pectel t2 ecu
the results show ian is a superb engineer and knows what works, flow rates, cam profiles etc
still shocked how early the t38 made power
will have a power graph soon when i collect the engine
__________________
Old 19-11-2010, 11:17 PM   #217
12_Second_rst
Trader Score: (1)
whats the full engine spec mate
__________________
Homemade 2.1 Zetec turbo, forged pistons, steel rods, t34.63 tubular manifold,
omex 600, siemens 80lb injectors, Bosch 044 and a focus rs mtx75
Old 20-11-2010, 07:06 PM   #218
frsjon
Trader Score: (0)
frsjon is an unknown quantity at this point
well done to all involved rob,cant wait to see this one finished
__________________
frsjon is offline   Reply With Quote
Old 28-11-2010, 07:21 PM   #219
RS_Rob
Trader Score: (0)
well the results i given for the engine over the phone were only slightly out,
358bhp and 365ftlb torque
thought i'd show some images of my lump on the engine dyno @ scs
big thanks to jimbo for taking pictures for me
some pictures of the vehicles there when i went to collect the engine
__________________
Old 28-11-2010, 08:34 PM   #220
frsjon
Trader Score: (0)
looks lovely rob,i know the moonstone 3dr in the pick at harvey's,good friend of mines
__________________
Old 28-11-2010, 08:56 PM   #221
Mike Kerbey
Mike Kerbey's Avatar
Trader Score: (1)
Mike Kerbey is an unknown quantity at this point
Thats impressive, congrats mate!
Loving the LU5H plate on the 3 door!
Mike Kerbey is offline   Reply With Quote
Old 28-11-2010, 10:01 PM   #222
Zetecfiesta
Trader Score: (0)
Zetecfiesta is an unknown quantity at this point
Send a message via MSN to Zetecfiesta
awsome stuff mate! looking foward to seeing more build up!!
Zetecfiesta is offline   Reply With Quote
Old 29-11-2010, 07:38 PM   #223
robp-tt
ZETEC TURBO
robp-tt's Avatar
Trader Score: (1)
robp-tt is an unknown quantity at this point
Nice work with the grommet didn't ford have any of the proper ones left to convert it from
Pas to non pas? As I bought one a couple of months ago to convert my mk3.5 to non pas,
__________________
www.area-six.co.uk www.xrtwo.com
mk3.5 zetec turbo project
robp-tt is offline   Reply With Quote
Old 07-12-2010, 09:56 PM   #224
RS_Rob
Trader Score: (0)
none available when i looked,
were'nt expensive and would of been alot less hassle but hey ho
__________________
Old 07-12-2010, 09:59 PM   #225
RS_Rob
Trader Score: (0)
my power sheet from the engine dyno
__________________
Old 07-12-2010, 10:09 PM   #226
RS_Rob
Trader Score: (0)
something i've been meaning to do for a while is wax the shell,
so the wax of choice was the 3M stuff used in my fords bodyshop
using this gun on the airline
quick picture of the shell
__________________
Old 08-12-2010, 10:16 AM   #227
harveyrst
Trader Score: (0)
harveyrst is an unknown quantity at this point
looks well smart so far will be mint when its done
harveyrst is offline   Reply With Quote
Old 17-12-2010, 09:27 PM   #228
RS_Rob
Trader Score: (0)
about a year or two ago i bought a CTS stage 2 + gearbox for the car,
which is a BC' box but with larger ib5 bearings, shot+peened gearset and a quaife ATB diff
but after finding out recently that the bc' box suffers with case flex, which could lead to allowing the bearings to move
and basically kill the box,
the ib5 gearbox is a development of the bc' box design
stronger casing, bigger bearings, better syncro's, starter motor at the back of the engine instead of the front etc
also because the gear stick centralising spring is inside the gearbox
this allows me to upgrade to a puma / mk5 fiesta gear stick selector
as the old bc box has the centralising spring in the selector itself,
so with a gearbox package sorted from a good mate on fiestaturbo.com
the plan was to swap the internals and diff over from one box to the other,
so that i'd have a ib5 with shot peened gears and quaife diff with all the advantages of the ib5
but due to lots of bearing size differences, it was decided to simply just swap the diff over to the ib5
which works out better in the end because i've kept the better syncro's
so a roadtrip was needed to collect the gearbox so that i could have the internals swapped over by two good mates in work,
i then borrowed the other halfs car and the company of a good mate mr wolze for the 450mile trip
it got a little dirty on the way with all the salt/grit and snow about
here's a picture of the two gearbox internal swapping legends, without them i'd be buggered
mr Wolze on the left, mr Potter on the right
heres the two box's ready to have their insides swapped
got new ford gaskets, bolts and 5th gear cover plate ready
the two box's mid operation
the quaife atb on the left, the standard ib5 diff on the right
with the swap over complete it was time to clean the ib5 up
with the help of another mate kenny and mr wolze, we got bungs for where the driveshafts go
and gave the whole box a scrub with parafin then blasted it off
heres a pic showing the bungs
__________________
Old 17-12-2010, 09:32 PM   #229
RS_Rob
Trader Score: (0)
now the box was clean from grease etc
it was time to scotch pad the casing box
you can see the difference it made alone with only the top half done
heres the box covered in a nice coat of etch primer on the freshly scotched box,
heres the box after its first coat of satin matt black
i choose black as its easier to keep clean than silver, also goes with the black engine block
then with the 5th gear cover/plate and bolts after it had dried
__________________
Old 18-12-2010, 01:35 AM   #230
tezmanian devil
Trader Score: (8)
tezmanian devil is an unknown quantity at this point
Send a message via MSN to tezmanian devil
awesome build dude, it's only taken me since 10:30 to get through it all lol
keep it up bud, deffinatly going the be a stunner!!
__________________
my 300+bhp mk5 escort zetec turbo project http://passionford.com/forum/restora...engine-in.html
tezmanian devil is offline   Reply With Quote
Old 18-12-2010, 08:23 AM   #231
Trader Score: (14)
Twins is an unknown quantity at this point
__________________
My carbon clad s2
Twins is offline   Reply With Quote
Old 18-12-2010, 08:49 AM   #232
frsjon
Trader Score: (0)
nice one rob looking good
__________________
Old 18-12-2010, 09:03 AM   #233
packman
Trader Score: (0)
packman is an unknown quantity at this point
Great build and much time and money has gone into it but i feel you get to a point were its just to nice to use on our shitty pot holed roads. And yes Harvey is the man he mapped my zetec that did 272 hp and 315 ft @ 3k with 18 psi.
packman is offline   Reply With Quote
Old 18-12-2010, 10:17 AM   #234
COLEYST200
COLEYST200's Avatar
Trader Score: (3)
COLEYST200 is an unknown quantity at this point
ian cole
some very nice work going on with this car well done mate and keep it up
__________________
Birmingham group
Click here to take a look at my three door project.
COLEYST200 is offline   Reply With Quote
Old 18-12-2010, 10:36 AM   #235
wide ka
Trader Score: (0)
wide ka is on a distinguished road
great thread, some awesome work going into it!
wide ka is online now   Reply With Quote
Old 18-12-2010, 05:55 PM   #236
RS_Rob
Trader Score: (0)
cheers for the great comments
it'll be used for shows and local drives around the welsh coastal roads
interested in what times i can get down at santapod aswell
__________________
Old 19-12-2010, 01:26 PM   #237
jon_ross
jon_ross's Avatar
Trader Score: (0)
jon_ross is on a distinguished road
fooking awsome mate. i only hope i can build mine as good as yours different colour and spec though. but what a car, well done
jon_ross is offline   Reply With Quote
Old 24-12-2010, 01:58 PM   #238
RS_Rob
Trader Score: (0)
thanks jon, got a project thread up on here??
__________________
Old 24-12-2010, 01:59 PM   #239
RS_Rob
Trader Score: (0)
bought a new alternator
this is the second one i've ordered, the first one did'nt fitted on my mount
so double checked this one fitted
painted the wiper motor cover satin matt black, new bolts etc
should help keep everything looking fresh in the bay
__________________
Old 24-12-2010, 05:08 PM   #240
GaryHurn
Trader Score: (1)
GaryHurn is an unknown quantity at this point
Send a message via MSN to GaryHurn
great work rob as always
GaryHurn is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
