| Register | Photos | KBase | Gold & Trader Accounts | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendors |
| Restorations, Rebuilds & Projects. Restoring her to Concourse? Just getting her running again? Or got a mad project? This is your room. |
| Welcome to Passion Ford! |
Welcome to Passion Ford.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Passion Ford today! |
Thread Tools | Search this Thread | Display Modes |
#121 | ||||
__________________
My carbon clad s2 |
#122 |
#123 |
wow what a nice looking car, i love mk3s, well i love fiestas fulse stop having had 4 (stil got 2) but this one is very nice, wish i could afford all the new shiny bits, top effort mate, keeping it clean and going for the power as well, very nice
__________________
![]() ![]() My old 96 Cobra 4.6 32V 13.99@103mph standard, sold and now living in holland!!! My mk3 84 1.1 escort to 2 litre sleeper http://passionford.com/forum/restora...ml#post5260325 |
#124 |
thanks for the compliments
should have some good updates this week
__________________
#125 |
in the engine bay i've decided to move the ecu and its wiring
so the factory hole is useless ![]() so it was welded up, grinded back, then a some filler over the top also had the last few holes welded up which hold the factory fuel filter and abs on other models of this car aswell ![]() after being sanded back ![]() and in primer ![]() inside of the arch was smoothed aswell ![]() to reseal the car back up i've been using a fords sealant, ![]() from inside the shell, under the bulkhead you can see the plate welded over the location for the factory ecu aswell as the sealant i've been putting in the panel gaps ![]() i've sealed up the same places as done originally, except i've not putting it on so thickly just making sure it's pushed into the gap and looks neat
__________________
#126 |
Looking good mate
![]() Thats what i need to do in a few weeks on my Mk2 Fiesta got a few bits to sort out first. Brian
__________________
#127 |
well next up was more sealant,
just applied a different way, the mk3 fiesta was known for water leaks mainly on the front bulkhead, so with this in mind i'm making sure cover all the seams well as i dont want a leak when its all built up the choice of sealant, ![]() how i'm going to apply it with an airline ![]() a test section on some cardboard using masking tape for edges ![]() test section with the masking tape removed, happy days!! ![]() the important bits were masked around the bulkhead and sprayed with sealant ![]() ![]() a close up after the masking tape was taken off ![]() how it looks now, much better coverage of sealant without looking messy
__________________
#128 |
awesome stuff mate
#129 |
well the sideskirts that were fitted previously catched the bottom of the doors and rubbed the paint off
so that being done 3/4 years ago i have a little surface rust starting so that needed to be sorted stripped both doors down completely ![]() while i was there, i had to see the how bad the rust was, thankfully with a small d/a it showed clean metal behind, so that was a big relief ! ! ![]() next was a test fit of the panels, any adjustments made before the car is ready for paint so doors were fitted first to line up from the quarters, while i'm catching up i'll show a picture from weeks ago, i did'nt post up because it would show my newest idea, but while the front chassis was bare, it was the perfect time to get some paint on before the wings go on as you dont get much access when the wings are on ![]() it seems the last it was at the other bodyshop washers were used and parts of the hinge grinded away to allow the door to sit higher so rather than replacing the hinges which seemed fine apart from the washers, we used new washers and welded them on, so would look a better job ![]() then with the belt sander the welding was tidied up ![]() so with the doors on properly, the wings and bonnet were test fitted ![]() ![]() so with the wings in the perfect place, the metal was prepped for spot welding
__________________
#130 |
then spot welded on by a pro, its a lump of a machine
![]() heres the wing after spot welding ![]() then where the front valance meets the wing was welded ![]() while we were test fitting, the skirts and arches were trimmed to fit nicely aswell as being trimmed for my big wheels ![]() also the wings were trimmed back to make more room for the 8"wide cossie wheels aswell
__________________
#131 |
__________________
My carbon clad s2 |
#132 |
had some more parts back from the powder coaters
front hubs, another front engine mount and the back plates for the rs2000 rear disc/drum setup ![]() recently tried cleaning up the brake bar which runs along the rear of the engine bay, after lots of scrubbing it was'nt getting any better, so it was a choice of having it recoated, or a new one so bought a new one along with new bushes and springs ![]() some bump stops for the bonnet, screws for the bonnet hinges and bonnet also nuts for the front and rear bumpers ![]() new upper and lower steering cowl's ![]() new plugs for the floor ![]() new seal which holds the rear glass in the tailgate ![]() new washer bottle ![]() two new door seals and tailgate seal
__________________
#133 |
nice matey , are you planning on using this as a track car , if you are then i would fit top mounts and plates to the turret towers before you decide to paint it. i think it maybe a worth while mod.
looking really good |
#134 |
new door hinge bolts and clips
one of the new door strikers aswell ![]() got hold of an RS accessory part i've not seen before, its a light dimmer relay basically rather than the on/off switch ![]() also another accessory, the credit card style spare key ![]() the panels under the rear lights which were lead filled, have been finished off with a skim of filler before ![]() after sanding
__________________
#135 | |
Quote:
wont be taking this on track, might do the occasional 1/4 mile tho
__________________
#136 |
wat colour you painting it mate great work so far please dont say red or if it is is there a good reason for it white or imperial blue all the way
#137 |
just read the lot stunning build keep up the good work
__________________
![]() check my mrk3 escort thread http://passionford.com/forum/showthr...45#post3636445 |
#138 |
the progress is happening thick and fast
really taking shape now the car was masked up and taken into the spray booth where the underneath had a nice layer of 3M stonechip ![]() ![]() then the car had the complete outside masked off ![]() ![]() the inside had its final prep including wipe down with tack rag's
__________________
#139 |
here she is after some paint in her new colour
ferrari rosso corsa red ![]() ![]() ![]() ![]() as the car is still on the spit, the car was also painted underneath on top of the stone chip ![]() ![]() one or two more of the inside, its awesome to finally see it some colour really makes all the prep work worth it ![]() ![]()
__________________
#140 |
mr wolz pressed my new bearings and hubs into the freshly powder coated knuckles
big thanks again ![]() i'm proper chuffed with the outcome ![]() also my new coilovers arrived from GAZ the difference of these compared to the avo's i had before is massive, the welds are really neat, two adjusters plates to lock the springs in place rather than one with a plastic screw
__________________
#141 |
good work rob, i take it your boss is taking the labour involved out of your weekly wage????
looks excellent mate |
#142 |
Apart from the filler, painting and welding
it's been me gary, so late nights after work and early mornings so saved loads on labour
__________________
#143 |
Colour looks fantastic
__________________
My carbon clad s2 |
#144 |
wow! just flicked through this, awesome work!
This is going to be stunning.
__________________
Dan. ![]() M.A.Developments 500 spec engine, GT30, Autronic, 1000cc injectors, ST Inlet ETC..... |
#145 |
stunning car! cant wit to see the end result!
#146 |
Trader Score: (1)
Rep Power: 33 ![]() |
Wow thats looking mint fella,Top work.When it finished you will be scared to use it lol.
__________________
![]() NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details. |
#147 |
looking great mate doing a realy good job
__________________
#148 |
love your work as usual rob !
__________________
#149 |
Looks stunning mate
Where you buy the plugs for the floor? do Fords still sell them? Brian
__________________
#150 |
cracking job fella, just hope it doesnt end the same way as the previous two!
#151 |
yes the plugs are still available from fords mate,
as for this one ending up like the last two, i really hope not aswell,
__________________
#152 |
well after the shell was painted inside,
the next morning i covered it over with paper, to stop general bodyshop dust getting on top of it ![]() ![]() a picture of the underneath all finished ![]() new rear 1/4 glass seals, so now have all new seals for the car ![]() the engine bay has had a quick prep and all seams which need sealing up have had a guide coat of green spot primer before the final prep can happen ![]() holes drilled for the front strut brace ![]() to make sure theres plenty of room for the intercooler and rad setup there was a small lip on the front panel support (highlighted with the red arrow) so grinded this off and made it smooth to touch
__________________
#153 |
Has a large member
Wow havnt seen your thread for ages on ft glad youve moved it onto here too, this is gonna be awsome
__________________
![]() 2012 white Merc C250 CDI Sport E46 M3 vert Mk2 Lotus Cortina 2.0 zetec |
#154 |
Awesome thread. Please dont put the bad boy bonnet back on!
__________________
Looking for a 2nd RS |
#155 | |
Quote:
i know theres alot of photo's lol but further back in the project i've got a brand new FRST bonnet to go on
__________________
#156 |
perfect work!
BHP? |
#157 |
__________________
#158 |
ok been buying more parts
after sourcing a rear bumper only when i got it home i realised it had been trimmed far too much so i got hold of a new one old one on the left, new on the right ![]() i better look of the new one ![]() brand new tailgate ![]() the engine bay sealing is more or less done, its alot more important to do a good job in the engine bay, as i'd rather avoid any future waterleaks ![]() even sealed non important bits, with paint over the top it will all look much better and easier to keep clean ![]() ![]() around the hinges all sealed up ![]() under the scuttle panel has been done aswell
__________________
#159 |
ford whore
cracking work, i remember reading about your fiesta si on fiesta-si.com and that was great work. keep it up
__________________
Ford . . . . feel the difference |
#160 |
__________________
| Display Modes | |
