PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 28-03-2010, 07:41 PM   #81
RS_Rob
Trader Score: (0)
RS_Rob is an unknown quantity at this point
well its been a busy week just gone for me,
heres a few updates
taken the rear arch kit off which was bonded on previously
the sealer still left on the rear quarter
brand new wings arrived
as the shell is going to be seam welded mainly in the front,
the decision was made for it to be taken for a proper shotblasting session as the small kit i'd bought was'nt strong enough to get the sealer out properly to avoid
weld spitting when seam welding
so on the back of the truck the night before
the missus decided to take a picture
the next early morning ready to go for a trip to be blasted
__________________
RS_Rob is offline   Reply With Quote
Old 28-03-2010, 07:52 PM   #82
fezzajsy
Trader Score: (9)
fezzajsy is an unknown quantity at this point
Send a message via MSN to fezzajsy Send a message via Yahoo to fezzajsy
nice one matey
fezzajsy is offline   Reply With Quote
Old 28-03-2010, 07:53 PM   #83
andy130
andy130's Avatar
Trader Score: (2)
andy130 is on a distinguished road
looking good mate, much are the wings?
must reply to your pm!
andy130 is offline   Reply With Quote
Old 28-03-2010, 07:53 PM   #84
RS_Rob
Trader Score: (0)
so the car was back later the same day,
only problem being the weather was'nt on my side and was raining nicely
this made the journey back very interesting especially when the car cover kept blowing off the back letting the car get wet.
so some time with the airline and new cloth sorted that out!
the next night my fabricator decided to crack on now it was clean
so starting with the plasma cutter he cut out the problem areas of rust
heres some freshly cut holes
this is under the passenger side of the front bulkhead
this is the passenger rear turret
the nasty bits
the side showingno major signs of rust
also the start of the seam welding
__________________
Old 28-03-2010, 08:10 PM   #85
RS_Rob
Trader Score: (0)
inside the shell is'nt being left out either
the top of the bulkhead
the floor
decided to weld up where the plastic plugs normally go aswell
the main support on the floor, even welded a washer to support the seat bolt points which normally fracture
how the engine bay is looking from underneath
close up of the drivers front arch
heres a clear picture showing the supports used while welding the front end,
as we did'nt want that much heat going into the shell while being held up by the front and rear of the shell
you can see from the seams we intend to seam weld as their back to bare metal
also had the sealer cut off the rear quarters, so the rest can be removed by the fudge wheel
__________________
Old 28-03-2010, 08:18 PM   #86
fezzajsy
Trader Score: (9)
mate its really looking good,well done
Old 28-03-2010, 08:34 PM   #87
rs turbo j
virgin
rs turbo j's Avatar
Trader Score: (0)
rs turbo j is on a distinguished road
Hat off to you mate wish i took the time to prep my shell like that now.
rs turbo j is offline   Reply With Quote
Old 10-04-2010, 08:32 AM   #88
RS_Rob
Trader Score: (0)
ok time to catch up with a few updates
bought some 1.2mm thick steel which i had bent to my spec
then shaped it to meet the floor and sill inside the shell
which will reinforce greatly
here it is seam welded in postition
on the inside of the engine bay we used it to reinforce between the chassis leg and bulkhead
and sort the hole made by plasma cutting the grot out
will look like this
on the otherside of the bulkhead its look like this,
ignore the dodgy looking colour its from the gas used for welding
it comes off and will all be sorted before its first coat of etch primer
had my bigger master cylinder painted panther black aswell
so will build that back up soon
mmm metallic flake
__________________
Old 11-04-2010, 11:00 AM   #89
RS_Rob
Trader Score: (0)
the seam welding has gone back to the rear floor
tidied the welds up a little and buzzed over them with the scotch wheel
the windscreen brackets were looking a rusty, so taken them off aswell
quickly machined the small scabs of rust around the sunroof to see the full extend of the tin worm
more welds cleaned up with the scotch wheel
__________________
Old 11-04-2010, 11:12 AM   #90
RS_Rob
Trader Score: (0)
back on its side now for more welding underneath
the welds which have penetrated through when welding inside have been cleaned up
patches replaced where the metal has perforated after shot blasting
the inner fuel cap area was cleaned up but thin in a few places also
so that was cut out with the plasma cutter
the piece cut out
rear suspension turret where we cut out the rot has now had a new peice welded back on
this hole is where the bracket for the spare wheel carrier goes into the boot,
as i've taken all the other bracket off, i want this sealed up
so removed this extra support fords had over the top of it
__________________
Old 11-04-2010, 11:15 AM   #91
RS_Rob
Trader Score: (0)
machined the sills back removing any chips in the previous paint etc
part of the front chassis welded up
the master cylinder back together
picked up some parts from the powdercoaters
rear beam, coilpack bracket and front mount
close up of the clean rear beam
now that its back, going to have the old man make up some spacers to make up for the width lost
when converting the rear brakes from drum to disc setup as the wheels sit further in the arch
__________________
Old 11-04-2010, 04:51 PM   #92
GaryHurn
Trader Score: (1)
GaryHurn is an unknown quantity at this point
Send a message via MSN to GaryHurn
awesome rob really is
GaryHurn is offline   Reply With Quote
Old 11-04-2010, 07:31 PM   #93
marky_g
Fleet Manager
Trader Score: (0)
marky_g is an unknown quantity at this point
Send a message via MSN to marky_g
blimey goin to town on this nice work
__________________
Click to see my RS Turbo project
http://passionford.com/forum/showthr..._g#post3406438
marky_g is offline   Reply With Quote
Old 11-04-2010, 07:48 PM   #94
robp-tt
ZETEC TURBO
robp-tt's Avatar
Trader Score: (1)
robp-tt is an unknown quantity at this point
if your using a zetec s rear beam and focus rear discs it pushes the wheels 20mm out, i done the conversion on my fiesta and need to trim the arch trims to stop them hitting the wheels, also if your using racing puma handbrake cables you will need to make brackets for the cables to go in to as the fiesta ones are in the wrong place
__________________
www.area-six.co.uk www.xrtwo.com
mk3.5 zetec turbo project
robp-tt is offline   Reply With Quote
Old 11-04-2010, 08:55 PM   #95
BigJim19
COS i'm WORTH it
BigJim19's Avatar
Trader Score: (0)
BigJim19 is on a distinguished road
inspirational build pal, making me rather embarrassed that i've left my FRST sitting waiting for the good weather
looking forward to further updates
__________________
RSOC 42927 www.facebook.com/CarpeDiemTattooMacc
BigJim19 is offline   Reply With Quote
Old 11-04-2010, 10:30 PM   #96
RS_Rob
Trader Score: (0)
thanks for the nice comments guys really feels like its getting somewhere now!
Quote:
thanks for that i appreciate your info
its the original rear beam with a plate stitch welded over the hollow section, with rs2000 disc/drum setup which is why the rear wheels have gone in the arch further
uses the rs2000 cable aswell with adapter to take up the slack
__________________
Old 16-04-2010, 07:43 AM   #97
RS_Rob
Trader Score: (0)
so the boot floor plugs and spare wheel carrier bracket hole have been welded up
the otherside of the welded rear turret passenger side
the rear drivers side turret welded, which i cut quite alot out of
inside view of the same rear turret as above
seam welded along the rear inner panel i trimmed to ensure no strength was lost
you'll notice the hole in the rear chassis leg, its where the rear towing eye was
my fault kept belt sanding to get it dead flat ....... opps (got a new chassis leg on way to sort it)
and the same panel otherside of the car
the fuel filler kneck panel replaced aswell
__________________
Old 16-04-2010, 07:46 AM   #98
RS_Rob
Trader Score: (0)
onto the engine bay
i've circled the holes i want welded up with black pen
also seam welded along the top of the bulkhead panel
heres the otherside of that panel, after belt sanding and then running over it with a 180grit on the DA
also welded the holes left from the self tappers used to hold the bodykit on previously
after tidying them up and running the DA over them, they blend in nicely
__________________
Old 24-04-2010, 01:57 PM   #99
RS_Rob
Trader Score: (0)
had a delivery in the week,
solder paste and 3 large solder sticks
as some things that need smoothing are going to be lead filled,
as it wont crack or sink like filler
got the car in the booth for two coats of etch primer aswell as 2k primer after that in some places
very happy how the floor is looking now
rear turrets looking much better
this is the turret which had a fair sized piece cut out
underneath has had some etch primer and 2k primer over the top
heres the front suspension turret in the engine bay, with holes welded up and smoothed
then primered
__________________
Old 24-04-2010, 02:12 PM   #100
RS_Rob
Trader Score: (0)
well after messing the rear chassis leg
got hold of a no longer available genuine ford repair panel for the chassis leg
drilled the spot welds and cut the old piece off
here it is after being covered in primer, much better
got myself a new fords alternator cable aswell
also a new servo pipe, brake line securing clips and non power steering rack bolts
new brackets which hold the sunroof
new tailgate hinges next to the old ones,
the old ones hold in what ever position you put them, compared to the new ones which are completely smooth
__________________
Old 25-04-2010, 08:45 PM   #101
n13los
Trader Score: (0)
n13los is on a distinguished road
great work, looks like she will be an animal when finished.
you seem to be a bit of an expert at sourcing no longer serviced items, i've been trying to find a pair of van blanking panels for my mk3 project.
i used to work in the parts dept @ evans halshaw in cardiff, rod there has tried all the usually sources (daventry, Quicks, Perrys) but nothing available, any ideas??? i have the finis codes somewhere.
cheeRS Neil
n13los is offline   Reply With Quote
Old 26-04-2010, 01:38 PM   #102
RS_Rob
Trader Score: (0)
cheeRS Neil
pm me the part numbers your after,
i work in bridgend ford parts (small world)
__________________
Old 26-04-2010, 05:45 PM   #103
fezzajsy
Trader Score: (9)
man thats gonna be a stunner
Old 26-04-2010, 06:45 PM   #104
RS_Rob
Trader Score: (0)
thanks mate, its really starting to take shape now
__________________
Old 28-04-2010, 07:40 AM   #105
BigJim19
COS i'm WORTH it
BigJim19's Avatar
Trader Score: (0)
where did you get hold on the zoo lower arms fella??
cheeRS
__________________
Old 28-04-2010, 08:09 AM   #106
njietro
retr0<3
njietro's Avatar
Trader Score: (0)
njietro is on a distinguished road
awesome
njietro is offline   Reply With Quote
Old 28-04-2010, 10:02 AM   #107
slammedorion
Orion ZT coming soon
slammedorion's Avatar
Trader Score: (0)
slammedorion is an unknown quantity at this point
Nice work
__________________
slammedorion is offline   Reply With Quote
Old 28-04-2010, 10:33 PM   #108
Brian
Trader Score: (2)
Brian is an unknown quantity at this point
Coming along really well mate
Brian
__________________
Brian is offline   Reply With Quote
Old 28-04-2010, 11:44 PM   #109
Red16
Trader Score: (0)
Red16 will become famous soon enough
Send a message via MSN to Red16
Fantastic work, seam welding and strengthening plates look great
__________________
Mac Motorsports Worx ZX10r turbo engined kit car... build thread in the restorations, rebuild & projects section
PS3 username - SausageArm ....... My DSLR photo's - http://www.flickr.com/photos/30990332@N02/
Red16 is offline   Reply With Quote
Old 29-04-2010, 12:19 AM   #110
Tazz88
Summer time Fezzy RST :D
Tazz88's Avatar
Trader Score: (0)
Tazz88 is on a distinguished road
Looking super mate top job on that Cant wait till i get my 1st RST get my hands dirty
__________________
Check out the Link
Summer time i will hopefully own my 1st FRST.
Tazz88 is offline   Reply With Quote
Old 22-05-2010, 10:02 AM   #111
RS_Rob
Trader Score: (0)
Quote:
cheeRS
zoo motorsport when he was trading years ago
__________________
Old 22-05-2010, 10:04 AM   #112
RS_Rob
Trader Score: (0)
thanks for the comments not updated this for a while lol
__________________
Old 22-05-2010, 10:05 AM   #113
RS_Rob
Trader Score: (0)
Well its time for a catch up
things have been a bit slow lately due to loosing my enthusiam
but starting to get it back again
after selling quite alot of parts recently to get my funds level back up
mainly things that are no good to me which my change of plans
as basically this car wont look the same as before,
more factory looking with subtle touches
firstly my new black samco hoses for the mk3 fiesta with zetec engine
(the kits only been released a few months ago after all these years)
spark lead clip, new washer jets, clips to hold the wiring in the boot, and tailgate grommet
brand new hubs to go with the knuckles i have'nt picked up from the powder coaters yet
new rear license plate lamp on the left, compared to the old yellow on the right
the metal shim that goes between the block and gearbox, no longer available new
so straightened mine up, sanded back to bare metal as it was a little scabby
etch primer and few coats of satin black, JOB DONE
also the panel gap below the rear light i've had lead filled, so basically its slightly flexable and wont crack
heres how the shell is looking
basically seam sealer is being put on only where its needed and nowhere near as thick as it comes from factory
recently while in the london area, i went to see chris todd @ torque of the devil
about mapping, wiring and management
very happy to leave the car with them in the near future
__________________
Old 22-05-2010, 11:30 AM   #114
GaryHurn
Trader Score: (1)
great progress rob, how ever i would consider taking the fiesta some where else!!! after seeing the mess of a friends corsa after they had mapped it, it melted a piston after 200 miles, used a 20 year old wiring loom and bodged it to fit the omex plug
id recommend dave young @ mech motorsport he loves using omex (there are also near his workshop) he is based in cheltnham, he has mapped about 4-5 of my friends cars including the nova all on various systems mbe, omex 600, emerald k3, megasquirt, dta etc etc
best of luck anyways cant wait to see it
i was always told that lead filling will corrode the metal??? hence why it is not done that much any more??
Old 29-05-2010, 06:24 PM   #115
cosmo V6
Trader Score: (0)
cosmo V6 is an unknown quantity at this point
Thumbs up
Very impresive Bridgend boy
Awesome job
You must be a better customer there for bits than me
cosmo V6 is offline   Reply With Quote
Old 29-05-2010, 06:42 PM   #116
RS_Rob
Trader Score: (0)
hey paul, thanks mate
i spend far too much money in work haha
__________________
Old 29-05-2010, 06:44 PM   #117
RS_Rob
Trader Score: (0)
you've put a doubt in my mind gary,
so after speaking to ian H
i've got some new idea's will post up more soon after a few phone calls
__________________
Old 29-05-2010, 06:54 PM   #118
Glenn.
Glenn.'s Avatar
Trader Score: (1)
Glenn. is on a distinguished road
Wow top work there fella.Its gonna be a strong shell.
__________________
NORTHEAST/NORTH YORKSHIRE ALL FORD MEET ORGANISER pm for details.
Glenn. is offline   Reply With Quote
Old 29-05-2010, 07:14 PM   #119
cosmo V6
Trader Score: (0)
And time Rob
Old 29-05-2010, 07:50 PM   #120
creator
Trader Score: (0)
creator is on a distinguished road
this will be amazing once finished great progress mate
creator is online now   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
