Escort Rs Turbo Rebuilt form Accident/Resto (PIC UPDATE)
Old 13-03-2010, 10:12 PM
MunkeyboyRS
Bananas!
MunkeyboyRS's Avatar
Default Escort Rs Turbo Rebuilt form Accident/Resto (PIC UPDATE)
So here my first Restoration/ rebuild on my escort Rs turbo. On new years eve, I put the car into a hedge. Deciding not to go though the insurance and take the opportunity the kill two birds with one stone, fix the damage and sort every last lil niggle out, and make very nice and clean.
Cutting out all the rust, full paint job, tidy up the underside and engine bay.
Planning on making her a semi show car and nearly every day.
Here how she looked before I bumped her
Then look like this
Had it recovered home, and found out I had to two bust wheels, ARB was bent, steering rack was bent too, LH TCA was dead and as can been seen bodykit was ripped off, front bumper broke a bit.
Changed all the parts and had it sent to be jigged, was out by 10mm across to the drivers side and the whole from end was down my 5mm, but has been all pull back and done very well.
Since then I have been super busy stripping it down, to be sent off to be welded and painted.
Here all the rust its got.
LH front wing
LH rear wing
RH rear wing
RH front wing
Lil hole in Scuttle panel
And two lil holes in my floor
All the new panel turn up the other day, full sill for each side, inner and outer rear arches, scuttle panel, fuse box tray. Already had two front wings and hoping I'll get away with patching the floor but if not I'll get to floor panels.
The engine and gearbox came out last weekend, now there is just all wiring left to do and brakes to take off and lines, and petrol tank and fuel lines, and the glass, one thing mine not looking forward to along with the wiring.
This is how she looking as of today.
I will keep thing updated, but now I'm now a bit of a slow time as the car cant go to be welded and painted till after 6th April.
Old 14-03-2010, 07:31 AM
GranaDavey
GranaDavey's Avatar
All the best for the work youre gonna do, will keep an eye on this
Old 14-03-2010, 04:33 PM
jonny s2
jonny s2's Avatar
good luck with the rebuild, bodykits always hide the nastys
looks great with the red and black colour scheme tho, what are the plans?
Old 14-03-2010, 06:51 PM
MunkeyboyRS
Bananas!
Got some more work done today between rain showers. Tank is drained (Dads now going to be running the mower on BP ultimate!), pumps for too. Brakes are all off to and hand brake. Down side to the day, discovered the donor hubs I put on while I refurbish the other, well the LH hub bearing fell to bits, so without the brakes on the wheel, disc and half the hub are free to fall off when ever they fancy it.
Jonny S2: The plans are to get the bodywork, inside, bakes and suspension and underside tip-top. Run it for the summer with the engine and gbox as they are part from a service, then do a full engine and gbox rebuild next winter.
Going to lifting the car up a lil be form in what ever hight it is on -40mm cut spring ( the ex owner) to proberly 35mm drip on, adding full new bushes, Adjustable TCAs, upgraded steering arms, front and rear strut braces.
There is also a lot of thing getting painted all the under side parts are getting powered coated or painted gloss black and a lots if engine bay parts painting to, eg intercooler and header tank.
Old 14-03-2010, 06:55 PM
jonny s2
jonny s2's Avatar
sounds great,should keep you busy
keep the updates coming
Old 19-03-2010, 02:22 AM
tommytxr
why o why do i do it!!!!!
tommytxr's Avatar
looks good m8 will pop over when i get chance
Old 19-03-2010, 08:56 PM
I love my fords but they dont half rust.
Old 19-03-2010, 10:03 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
Keep up the work mate, you WILL wonder why the hell you bothered when its in bits with panels cut off, i've been there! but just keep plodding on, you'll soon see the light at the end of the tunnel
Old 19-03-2010, 10:10 PM
Puss2
Formerly know as Puss
Puss2's Avatar
Now thats what i call a project good luck
Old 20-03-2010, 08:58 PM
MunkeyboyRS
Bananas!
Yeah give us a txt when you know.
Old 20-03-2010, 09:01 PM
MunkeyboyRS
Bananas!
Yeah I know, I can wait to to drive it once its done, but I've still got a long way to go, and the thing that makes it even harder the rs is my only car! luckly work is only 2miles from home, and I'm proberly quicker on the push bike!
Old 29-03-2010, 06:02 PM
TOMMY_RS
SHITE!
TOMMY_RS's Avatar
any more updates on this?
Old 29-03-2010, 07:23 PM
Good to see it being saved
Old 29-03-2010, 07:29 PM
Rsmat
300+
Rsmat's Avatar
+1..
Old 29-03-2010, 08:49 PM
MunkeyboyRS
Bananas!
There a few updates but not many. nearly everything is off the car now, just got wiring, not really looking forward to getting this out.
But many doing a lot of getting fucked off with nuts and bolts that haven't been undone in 20years!
Been doing a lot of wire brushing of parts ready for painting.
Old 02-04-2010, 11:07 PM
MunkeyboyRS
Bananas!
Default Fuel tank
Well I did it today, use scotch bright pads and petrol to scrub about 90% of it off and then Toluene** mix with Isopropnole** alcohol came up really well, but I got smack off my tits in the garage on it, and I was wear a big filter spraying mask!lol
/\ All that's left here is some surface rust.
Should be able to shot some colour tomorrow, Think its going gloss back as kinda brought gloss black before I completely made my mind up, also thinking about the "strap" to paint red.
Old 15-04-2010, 07:10 PM
Big-Dan
Big-Dan's Avatar
Good progress so far mate, I remember how gutted you were when you pranged it.
Really pleased that you've stuck to it though, can't wait to get mine back on the road, think I might do abit of underside work on it this winter too.
Big-Dan.
Old 15-04-2010, 07:51 PM
strawhead_rst
strawhead_rst's Avatar
cool project im in the same boat mate mine is on stripped aswell.
i know what your going through
Old 09-05-2010, 09:15 PM
TOMMY_RS
SHITE!
TOMMY_RS's Avatar
any more updates on this mate?
Old 18-05-2010, 07:19 PM
MunkeyboyRS
Bananas!
Been a while since iv posted on his mainly cause most off the stuff Ive done has been boring and now with my new job that eats nearly 60 odd hours, so things will get slow on the car, now I'm going to be time poor, but cash rich rather then, time rich but cash poor!lol
but the car is with some now being welded and paint was pick up last week, while I was away with work and I think it will be home before I am lol.
Old 01-06-2010, 09:33 AM
MunkeyboyRS
Bananas!
Small update, the car should be home this week from the paint shop, not that I'll see it for a while as I'm away with work.
Old 01-06-2010, 07:47 PM
2wd saff cos @ stage 3
2wd saff cos @ stage 3's Avatar
silly question but how did u end up in a bush??
Old 19-06-2010, 08:46 PM
MunkeyboyRS
Bananas!
Well she is finally home and on the drive, looking proper spanking and nice, time to start building when i get time off work. I shall put up some picks tomorrow whe i get time to take some, well I did take some on the iphone but they look really really orange on that.
Old 05-07-2010, 03:37 PM
Rob_DOHC
Rob_DOHC's Avatar
come on mate, more pics
Old 05-07-2010, 04:02 PM
MunkeyboyRS
Bananas!
there coming rob, jut been having probs with storage on my laptop, now ive got a external hard drive so i can get them off the camera.
Old 05-07-2010, 04:05 PM
Rob_DOHC
Rob_DOHC's Avatar
Job done, looking forward to it fella.
Rob,
Old 05-07-2010, 04:40 PM
vroooom ptssssh
It Wasnt Me!
Get the pics up
Old 06-07-2010, 09:31 PM
MunkeyboyRS
Bananas!
COMING THURSDAY
TO COMPUTER NEAR YOU
My up to date resto pic
(subject to my boss not taking my day off away from me again!)
Old 11-07-2010, 04:11 PM
MunkeyboyRS
Bananas!
Default Oks a lil late! But here they are.
Here the picture of of the car since coming back home, I am waiting loads of picture from the painter od all the work he did.
But these are the ones I've taken.
The paint does look a lil dull but its not been polished since its come home, only plain water to claen bird shit off.
Now here is some more parts the I have got ready for the car, well the ones that I have photo-ed
Cheers all.
Old 11-07-2010, 04:15 PM
gavt123
gavt123's Avatar
very nice mate looks spot on,
i love red s2's
Old 11-07-2010, 04:16 PM
jonny s2
jonny s2's Avatar
really does look stunning mate!
get it built up asap, i love it. are you keeping the black s2 rims on or changing
Old 11-07-2010, 04:22 PM
MunkeyboyRS
Bananas!
Black rims dude, but maybe 16"gti/Mondeo rims?
Only thing is time is now my enemy, dont get many days off, had my Thursday taken off me, but had this weekend only cause I got and eye injury i got friday, so Ive not managed to do any work to it, as Ive had to sit in a dark room all weekend.
Old 26-09-2010, 04:19 PM
MunkeyboyRS
Bananas!
Default Updates 26-09-10
Well its been a while but here are some more pics.
Not been a super amount of work been done, but not had much time for a while, but fingers crossed Ill have more time this winter and hoping to have everything done to the car and ready for the road, all except engine and gearbox, before Xmas. then it will be time to start the engine and gearbox rebuild.
Fitted my freshly painted petrol tank and filler neck.
Then mover on to fitting the rear suspension and brakes and few other bits.
All parts had been cleaned and painted in the garage, new -35mm spax spring brought.
Rear hubs rebuild and painted.
Now the back end is back on its wheels and the front end is now up in the air wait for me to start on it. Getting all the parts ready in the garage at the mo.
Old 26-09-2010, 04:45 PM
Looking good
Old 26-09-2010, 05:16 PM
RS_CHAZ
RS_CHAZ's Avatar
Looking good mate, like twins said earlier, nice to see another being saved
Old 26-09-2010, 11:33 PM
tommytxr
tommytxr's Avatar
you got any more done yet mate i leave work on the 8th of oct to start up with my bro will try n pop round
Old 27-09-2010, 12:34 AM
scottyrs
DURHAM RSOC
scottyrs's Avatar
looking good mate
Old 27-09-2010, 02:37 AM
jonny s2
jonny s2's Avatar
woah looking good there fella keep it up, wanna see it finished
Old 27-09-2010, 07:28 AM
billybigspuds
billybigspuds's Avatar
good effort mate looks good
Old 27-09-2010, 10:50 AM
turbo_king69
boost junkie.....
turbo_king69's Avatar
Nice resto matey.... Keep up the good work! How did u manage to crash it btw?
Quick Reply: Escort Rs Turbo Rebuilt form Accident/Resto (PIC UPDATE)
