Escort MK6 Van, Zetec turbo on MS..
Here's my MK6 Escort van, originally 1.8D, bought this to use for work, soon got tired of diesel and this is result..
It's fully "home built" and wicked fun..
First was 2.0 ZT with GT30...
..using Skyline Nismo pump,
..new headlining, seats, carpet and some audio..
..then came custom Gaz coilovers and some wheels..
..Then had issue with oil pump and engine was Scrap!
Decided to build new 2.1 ZT with some more umphhh..
..and this is it now!
Curently running stg3 T4, external wastegate...and 18psi
and in everyday use!
was thinking of doing this to one of our work vans when diesel engine goes but turn it round and bolt a 2wd cossie box to it as easy to make tunnel in van as rear deck is high enough anyway and as the rear floor is flat should be easy to make mounting points up for box
here's little update..
..GT30 on order, just waiting for that to turn up and then new down pipe and external wastegate set up to make..
van be going to paint in 2 weeks..nothing special, just respray in diamond white with black roof..
Mate, I love this car. Its something someone would see and say "Oh, its just a caddy!" - ha, how wrong you are.
May I ask if you have a 0-60? Also, doesn't torque steer snap your thumbs off?
4th gear wheel spin at 100mph - ha, that would scare me first time it happened
ib5 seems o.k..Alcon 6 paddle, no slipping
Tourque steer isn't too bad with grippier Yoko Parada rubber..you get use to it
some more pics,
rear discs,
new GT30 and new downpipe and wastegate set up,
some more pics,
rear discs,
yeah, know that..then you need to add LSD..mtx ratios are better as well? and would it ude 2.0 zetec flywheel? can i run FRS box with zetec 2.0 flywheel or would i need FRS one?
Turbocharging Technician
yeah, 2.0 litre zetec fly, or FRS fly, and a FRS clutch all 240 mm, frs box has quaife atb, or you can buy an atb from the states for around 400 quid and fit it very easily yourself.
550cc Toyota Celica GT4
Doing It Better
What problems did You have?
2nd that!
never had similar problem. I just adjusted pot manually..I've done few MS set up's now, with OEM trigger wheels or 36-1 trigger wheels..never had proplems. I think MS is very under rated! I like the whole "diy" attitude..
