My Saph thread, MAD 500 spec engine + other goodies
#162
Gary Krishna
Have you got the right cradle for the gearbox mount to fit the 4x4 shell?
6177696 is the Finis code from Fords.
From memory it wasn't too expensive to buy, about Ł17+ VAT I think.
You may find that it won't line up at first when you offer it up as mine certainly didn't but all I did with mine was drill 2 holes inline with the centre mounting bolt hole and it slotted straight in!
You may have to cut/drill a section out to allow the speedo cable to pass through as it gets in the way. It did on mine anyway!
#174
#178
Its an apexi AVC-r boost controller, its on SM2, not SM4, and i have been advised that the boost control facility on the sm2 is a little dated/not up too much, so that should help, i can also limit the boost in 1st, 2nd and 3rd to help it grip with it.
Mark's map is already on the ecu .
#186
cossie fan (unluckerly)
#187
Just popped up to the car to deliver some bits, did a few little jobs when i was there.
Tried the apexi in its new home
The new ProSport gauges in, haven't attempted the wiring yet
And got my swirl pot from cossiedrift today, it had been in my position all of an hour before it got deBlinged! Mucked about with my old 4x4 hoses to get that fitted
Should have a good weekend on it this weekend, with any luck.
#190
cheers Kevin.
shame its frigging silver, thats homo.
I dont know what to do with that other gauge pod, the one thats ontop of the dash in the pic, it likes a right cock there, but don't know where else to have it?!
Suggestions? I don't do pillar pods btw.
#191
Had a busy day today, done a fair few bits.
Good old Brom got the box in while i took a pinto to Camarthen yesterday..........
In New Ford cradle (thinks to Kitchen Devil for the finis code on that ) with flo flex mount.
Bosch sensor for the AEM gauge is in
And the gauge is mounted
Cooling system is near enough finished now
Bailey tank, of course, black!
Massive job, alloy pulley on PAS pump is on
Downpipe is wrapped and on, happy to report the 4x4 one fit with no issues
Redundant lamda sensor still in there
Plumbed the apexi control valve in
Also ripped the standard loom out and wired the gauges up to the sensors and stuff, Coming along slowly.
#194
Little bit more done tonight, wasn't really in the mood as i feel rough as a bears arse.
Did the thermostat housing ti heater matrix hose, god knows how this is supposed to go on a 2wd, but mine now has this.
Also got the spec R DV fitted, massive job, i know.
And my oil is here, thanks to B13 Jus off here
Fitted the new starter
And i wired the ProSports and AEM gauges up, so had to have a quick test to see what they are like, as said, i am ill, so ignore my darth vader like breathing.
Obviously the one flashing red and making a racket is oil pressure, as its not running, it thinks there isn't any, so is showing the alarm.
Click for the vid
Click for the vid
#195
Postman brought me some more goodies today.....
didn;t want to do aeroquip, because i don't like the red and blue fittings, but the fuel rail on the new engine is adapted to aeroquip, i was going to change the rail, but then discovered Torques do the stealth black stuff, win.
so had a quick test fit,
Started to run it down the car so i could cut it to length, then got to the pump end and realized it made a miss judgment, i got all the fittings to fit into the 044, forgot the line comes out of the filter, D'OH!!
Oh well, sure i can find a way round it, also made another fuck up, order oil hose to do the breather, i measured that i wanted 14mm, all that was available is 13 or 15mm, i decided id rather it a little tight, so bought 13mm, will it go on............nope, not a chance :'(, fooking car is going to be on fire if it pisses me off any more.
#196
Looking very well Dan.
I had heard that on the grape vine!
How cheap?
LOL,how can you be getting pissed off with it when Mikes doing all the work!!!?!?!?!?!
How cheap?
#197
Thanks
How cheap?
I dont know, make me an offer!
He's doing most of the work, i was in a shitty mood and all sorts of things where doing my head in the other night, mainly fuel lines and the oil hose that won't fit.
Had a mass spending spree now though, new oil hose is here, clutch cable ordered, and an airtec 70mm cooler, amongst other things i cant remember.
Thanks
How cheap?
#200
hi mate love the car looking good! did you sort your speed sensor out? just spotted your going to be runing autronic, thought id mention you can link the speed pulse to the ecu for the launch control so when if sees you going over a certain speed it switches it off
