(COLEYST200) focus to focos / skyline gear box
#2441
I was talking to a friend who does a lot of fabricated parts and he said you could offer up the mt75 to a piece of white acrylic and scribe or draw round it, then do the same with the skyline bell housing compare and build a blank from there to then transfer to steel.
#2442
I think the biggest issues are the clutch release bearing and operation, the starter motor position and the bearing in the back of the crank, lastly the length of the input shaft.
#2443
that's a bit blue peter ,don't forget the input shaft has to run perfect with the bearing in crank ,if your .3 mm out with some holes etc. it will put strain on bearings etc ,that's one of the reasons the bell housing is doweled
mark
#2446
Yes, a better solution would need to be found....IF there is one?
#2448
#2455
I now have a skyline r33 v spec box with r32 single pump. Just a few niggles to solve now but will mock up the tunnel this weekend. I think I will go for the ets pro controller as seems to do everything.
#2457
Not yet mate, Half my gearbox the ford 4 x 4 part is still in the UK. But i have spoke to a guy over here about doing the alloy welding for me. He did the cage on my track car. I will send him the pics you sent me and he can let me know if he can do it. I missed one for sale already done the other day a guy in the UK on here bought it. Caddyshack i have also scored a spare front half of a 4x4 skiline box as well so i can do all the mods on that, with a ford block and clutch and the empty casing then once done just change over the modified front end onto my box.
You making the bellhousings?
#2458
When you speak to the chap that's going to look at doing it for you tell him to make a bush for the input shaft to go into that fits the mt75 4x4 input shaft then when he has made the jig off the cosworth box then remove the bush and make it fit the skyline input shaft as the skyline is bigger not by much but it is . And as said any help I can give just ask
#2461
I paid 700 for a v spec box, modded bell housing, paddle clutch to suit brand new, flywheel, ap clutch cover, ap bolts, prop shaft and pump.
#2462
Many Thanks, a picture says a thousand words!
I am going to slice the tunnel this weekend so I can put the box in and out to mock up the props etc.
Thanks for all your help
#2465
#2468
Coley, did your input shaft on the skyline gearbox slot straight in to the bush on the Cosworth crank? Mine seems to only go in a few mm which means the bell housing is about half inch away from the block.
I have a feeling that my box is not 100% lined up yet though, I just need to cut about 10mm at the rear of the tunnel.
#2469
Hi mate have you had a new bush made to fit the skyline input shaft as you will need one making first or remove the cosworth input shaft bearing so you can no your test fitting of the gearbox . I have just tryed to ring you on the phone number you sent me
#2470
Thanks
Toby
#2472
#2474
I ordered the ets pro today as discussed in this thread, Ł471 inc delivery from the states, it has full auto control with a gain knob so you can tune his aggressive the 2 to 4 split is. It also has Manual 2wd to 4 wd split and the auto mode is mappable if you want to. Many of the skyline boys upgrade to this to take advantage of the control based on newer technology.
#2475
Mark
#2476
Never mind, it will be back to you for a rebuild and more power before long.
#2479
