PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 09-01-2010, 08:08 PM   #41
turbotoaster
turbotoaster's Avatar
Trader Score: (0)
turbotoaster is an unknown quantity at this point
Send a message via MSN to turbotoaster
ok onto the deal with power, i did some gear testing yesterday to determine what needs to be done
So i went out with my gps meter to do some gear testing.
to do 100mph(gps) i need to do 4500rpm, give or take 20rpm
so to do 200mph i need to pull 9000rpm, simple maths. this is on 255/40/17s there maybe 1mph more for tyre expansion but ill leave that out to make it easier. also a 4.1 diff
So i got out my gear calculator program i have to put the numbers in to see how i can help.
online i have found that the 5th gear results are much longer than they should be, 0.719, which must be incorrect else id be doing a massive speed.
Anyway i adjusted my 5th gear till i got 100mph at 4500rpm with tyres stated earlier.
This gave me a 5 gear ratio of 0.820 or 22.15mph per 1000rpm.
Now according to what the guy with the stock port and same turbo as me did, his max power was at 8200rpm, because of my big streetport im calculating that my max power will probably be about 8500rpm.
So to do 200mph im going to be past my max power and its gonna be trailing off, not good really at that means ill have less power where i need it most.
At my maximum power ill only be doing 188mph, so well short of the mark, so lets change the diff to an auto one to see what we can do.
now this changes the speed at max power to 198mph, which is much better, very close to the mark.
Ill have to wait to see what my final max power/rpm will be but it least im making progress on gearing.
also say for example i only make max power at 8200rpm like the other guy did i can still hit 200mph with 8250mph if i change my rear tyres to 255/45/17
hope this clears up any potential confusion people have had in the past
One thing about power is if i made 1000bhp at 6k but only 500bhp at 9k and i need 9k to hit 200mph i wouldnt do it.
But if im making 1000bhp at 6k but 640bhp at 9k i would hit 200mph.
So i can make up with tyres but i may need more than 640bhp to hit my target, hence the aim of 700bhp at around 30psi.
A completely stock engine(ie built by a guy on the mazda production line)with my turbo did 709bhp at 33psi and runs 9sec quarter miles so the power is avaliable
that way if 200mph is past my peak power slightly then it still should be above 640bhp.
this was from Rod about his old engine
'On my last engine Peak Power was below 7.5k but held on to about 7.7k. We pulled 8.2k so was well past peak Power. BUT we could not pull the longer gearing so this was the best compromise'
So at 200mph he wasnt putting out the power people think he has because hes gone past peak power
__________________
It's a basic truth of the human condition that everybody lies. The only variable is about what!
turbotoaster is offline   Reply With Quote
Old 09-01-2010, 08:08 PM   #42
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
Trader Score: (0)
vroooom ptssssh is an unknown quantity at this point
Send a message via MSN to vroooom ptssssh Send a message via Yahoo to vroooom ptssssh
Quote:
Originally Posted by dovboy View Post
dude you have him beat before he has even started!
i dont think there is a car out there that doesn't have some kind of weak spot,i'm sure trying to do 200 in any car would find those weak spots.
No I totally agree, you are right in what you say...however holding a car down a runway flat out for that long is a big thing to ask from it...Chap reckons if it dets at all, it will blow the engine...whereas a piston engine wont be so 'on the edge'
I cant help but think a skyline GTR engine would be better (RB26 DETT)...
650bhp can be had for not a lot of dosh/effort.
I agree that Apexi is a very good system, I run it on my 200sx.
__________________
Passionford's realist, not to be mistaken for Pessamist!
My S1Resto
vroooom ptssssh is offline   Reply With Quote
Old 09-01-2010, 08:23 PM   #43
scoooby slayer
Trader Score: (4)
scoooby slayer is an unknown quantity at this point
good luck mate i hope you do it.
__________________
widebody doluck mkiv supra, 900 hp on a t51r spl bb 134 mph in the 1/4 mile so far
new project im building a dragster for pod http://passionford.com/forum/restora...r-is-born.html
scoooby slayer is offline   Reply With Quote
Old 09-01-2010, 08:37 PM   #44
MadRod
Happily retired
MadRod's Avatar
Trader Score: (0)
MadRod will become famous soon enough
To clear up the BMW boys fantasies the very latest e93 m5 just mustered 180 in 1.5miles at a recent VMax. Its so obvious that most dont realise just how short 1.5 miles is, the topspeed of most Production cars would be over 4miles.
Turbotoaster knows whats involved & the maths of how to do it, hard bit is getting the car to follow the maths .
I will help anyone that is prepared to give it a go & i will be there on the day & maybe running with him, yes ive been asked, we shall see.
Cheers Rod
MadRod is offline   Reply With Quote
Old 09-01-2010, 08:49 PM   #45
turbotoaster
Trader Score: (0)
That would be true if it was tuned the same way as a piston engine, i can take out timing and not loose much power, the engine should produce 700bhp, if i maxed everything out(boost and timing) i could hit 750bhp, but there is no need and the risks are to involved, maybe one dyno run just for pub figures but in the real world im not to fussed.
the limit of a stock rb26 bottom end is around 600bhp, id need to custom fit the engine, gearbox, custom made prop shaft, theres an awful lot of work involved in that mate, then id need 6 injectors, big turbo, cams, pistons etc
Ask how much scooby slayers engine came to and thats with no fabrication work!
__________________
Old 09-01-2010, 08:58 PM   #46
scoooby slayer
Trader Score: (4)
drive in drive out was £5600 and that was a good price £3600 parts £2000 labour for engine in and out and rebuild, head porting / cams already done, jun oil pump reused. turbos already there.
car stands me in at £11k and wouldnt do 200 mph but is built to be up to 700 bhp and as reliable as possible.
i think hes doing right i think a standard rb26dett at 650 bhp is a recipe for disaster. and dont forget this car hasnt got to do 10k + miles its just gotta do the run.
__________________
Old 09-01-2010, 09:20 PM   #47
jammerrs
Trader Score: (0)
jammerrs is on a distinguished road
best off look mate, keep us updated
any idea when its going to be doing this run? or is it a do it when its finished?
are you doing anything to the body to do these speeds, areo dynamis aids, just taping the front end up etc?
jammerrs is offline   Reply With Quote
Old 09-01-2010, 09:39 PM   #48
turbotoaster
Trader Score: (0)
So to basically build the engine its 5600, you would then need to buy turbos, head port, cams etc easily be 10k to get a standard engine to your spec?
if you maxed your turbos out at say 680bhp you could easily crack 200mph, just not within the confines of brunters.
well if someone lends me £3500 i could do it by february lol
i dont earn a massive amount and ive refused to use credit cards or anything like that, so having no debt means it will take time.
the timeline will go
ecu
intercooler/rad
injectors/fuel pump
turbo/manifold
water injection
brunters
We are looking at probably autumn time before i do the run for a couple of reasons, one finance, and another the cooler air will help keep performance up
there will be no aero aids apart from taping up a few seams and removing the wing mirrors, also the car will run lower to the floor than normal use
for reference a company called scoot in japan went over to new zealand to do a top speed run.
On what can only be described as a 2mile stretch of B road they did 204.6mph with 680bhp with a very drag heavy setup, but when your doing that speed down a tight road its to be expected you will need stability
that gives you an idea of how tight the road was
__________________
Old 09-01-2010, 09:51 PM   #49
dovboy
dovboy's Avatar
Trader Score: (0)
dovboy is on a distinguished road
the car in the vid has the rear wheel covers i mentioned,they must help a fair bit.
dovboy is offline   Reply With Quote
Old 09-01-2010, 10:06 PM   #50
jammerrs
Trader Score: (0)
not much room for error along that road, never mind at that sort of speed
sounds a good plan, again best of look i hope you can make it
Old 09-01-2010, 10:39 PM   #51
CoupeUK
Trader Score: (0)
CoupeUK has a spectacular aura aboutCoupeUK has a spectacular aura about
Is there a 200+mph rated tyre out there?
General question....
CoupeUK is offline   Reply With Quote
Old 09-01-2010, 10:53 PM   #52
andy escos
Capt Chaos
andy escos's Avatar
Trader Score: (1)
andy escos is on a distinguished road
good luck with the project
__________________
500+BHP 4X4 ZAKSPEED ESCORT GROUP 5 FULL RESTO, SOON TO LOOK LIKE THIS,,
TAKE A LOOK AT MY GROUP 5 ZAKSPEED ESCORT REPLICA RESTORATION
Clicky
andy escos is offline   Reply With Quote
Old 09-01-2010, 11:28 PM   #53
scoooby slayer
Trader Score: (4)
ecu
intercooler/rad
injectors/fuel pump
turbo/manifold
water injection
brunters
my car should technically do 193 mph on the limiter if it would pull there.
but mine has been built as a fast road car with track and drag potential if i want to do it. to make a reliable road car with big power on your budget i think its impossible but for what your aiming for it hasnt gotta do 10k + miles so i think you stand a good chance after all it hasnt got to hold together for long mate. rx7s weigh in at 1310 kg which is pretty good.
good aero shell. ive driven a tuned rx7 and it was an awesome machine and ive known of 2 others but reliability was an issue with all of them, they all had failed rotors, one on a rebuild but only did 1500 mls hard use and was fooked again
for your aim i think youve picked the perfect car though
i wish you all the best mate and will be following this thread.
ive wanted a brunters run for a couple of years now, ive phoned them twice in the past but it hasnt been possible due to cars stored there iirc.
maybe i could pay and run my skyline there when your there pal ?
__________________
Old 09-01-2010, 11:54 PM   #54
turbotoaster
Trader Score: (0)
what is your limiter set at, i notice you make max power at around 7700rpm
if you were running full boost at 680bhp, if you changed your tyres you wouldnt be massively far away at brunters.
but at the horsepower you are now theres a chance you might be able to crack 200mph with a 4-5mile run at it
by the way rx7s fully equiped weight 1260kg, mines currently at 1220kg but id like to get it to 1200kg when its fully done. Sounds like 1500mile one hasnt been tuned properly as 1000 of those miles will have been running in below 4krpm.
When ive done it, ill turn the boost down to around 1.2bar and be happy with 550bhp as thats alot for its weight.
I suppose it depends on if the mags will alloy it, Rod mentioned doing it at woodbridge as theres no noise limits there, so might see about that place first, if they allow other people to run then the more the merrier i suppose
__________________
Old 09-01-2010, 11:59 PM   #55
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Trader Score: (1)
Charlie Chalk is on a distinguished road
Send a message via MSN to Charlie Chalk
Well theres cars produced that do 200+ , so I'm guessing yes?!
Good luck mate.
__________________
GE - 1D - T
Charlie Chalk is offline   Reply With Quote
Old 10-01-2010, 12:03 AM   #56
scoooby slayer
Trader Score: (4)
im making power right to limiter now with more boost about 580 bhp 470 lbft. this thread made me think so just been on gtroc id need 8200 rpm limit to physically achieve 200 mph and a good bit of road shes no lightweight at 1410 kgs.
id 100 % be there though if i could run, and try 170 mph id be happy
put in a good word for me pal
__________________
Old 10-01-2010, 12:13 AM   #57
MadRod
Happily retired
MadRod's Avatar
Trader Score: (0)
Continental make a tyre rated to 200mph but they are not in normal sizes.
The Top tyre rating is 186mph but remember thats continuious running with max load so its not really a problem.
Old 10-01-2010, 12:32 AM   #58
simon170
Trader Score: (0)
simon170 is an unknown quantity at this point
I'd recommend Woodbridge, much better service I think.
__________________
Car - ST170 Turbo
Nemesis - Big Will
simon170 is offline   Reply With Quote
Old 10-01-2010, 12:59 AM   #59
Kverna
Virgin-popper
Kverna's Avatar
Trader Score: (1)
Kverna is an unknown quantity at this point
Send a message via MSN to Kverna
What about the heat thoughout the system ? Will it actually BE 6/700bhp at the end of a run, ~200mph ?
__________________
Kverna is offline   Reply With Quote
Old 10-01-2010, 03:41 AM   #60
vroooom ptssssh
It Wasnt Me!
Trader Score: (0)
A mate of mines RB26dett was making 575whp and it got abused with no issues.
Standard bottom end.
Well whatever you choose good luck
__________________
My S1Resto
Old 10-01-2010, 11:53 AM   #61
Lloyd
escort mk4 cossy 4x4
Lloyd's Avatar
Trader Score: (0)
Lloyd is an unknown quantity at this point
the last company i worked for made the cold side impellars for borg warner turbos,and the 475 was used in a race series in the usa.
there was a lot of problems with them,carbon deposits in the back face,and blade tip porosity.ok if you get a good one.lol
__________________
Lloyd is offline   Reply With Quote
Old 10-01-2010, 12:18 PM   #62
turbotoaster
Trader Score: (0)
so theres a larger risk by running a pre-turbo water injection then, if the blades are porous and im deliberately throwing water at them, is there anyway of checking them at all?
__________________
Old 10-01-2010, 12:44 PM   #63
m4tt274
m4tt274's Avatar
Trader Score: (2)
m4tt274 is on a distinguished road
Send a message via MSN to m4tt274 Send a message via Yahoo to m4tt274
a skyline GTR engine would cost 3times the wonga to get to this power, as u need cams, pistons, rods, block modifications, sump etc etc. all u need to do with rotary is port it. then its fuel rail, ECU, turbo :P
__________________
mk1 fiesta restoration! - http://passionford.com/forum/restora...-now-on-d.html
m4tt274 is offline   Reply With Quote
Old 10-01-2010, 12:44 PM   #64
Lloyd
Lloyd's Avatar
Trader Score: (0)
blade tip porosity is an effect of the heat treatment process.it discolours the edges of the blades and makes them brittle.water injection will not affect it.on some you can see a bubbling of the alloy
__________________
Old 10-01-2010, 12:56 PM   #65
scoooby slayer
Trader Score: (4)
now this is an rx7
bit over budget though
http://pistonheads.com/sales/1270615.htm
__________________
Old 10-01-2010, 01:02 PM   #66
CRAIG HAYTER
Trader Score: (0)
CRAIG HAYTER is an unknown quantity at this point
Send a message via MSN to CRAIG HAYTER
Quote:
Originally Posted by m4tt274 View Post
do u know anything about the engine.
the engines are more reliable than the YB.
they just need servicing regularly and warming up is essential. if u do that they never go wrong.
my cousin bought one type r a sensor went and it melted the engine cost ££££s and had to get another engine from MAZDAas you can imagine it wasnt cheap to get done and not alot of mechanics know how they work(properly)they are nice cars but shite enginealso theyneed rebuilt ALOT
good luck in the search for 200mph
CRAIG HAYTER is offline   Reply With Quote
Old 10-01-2010, 05:43 PM   #67
turbotoaster
Trader Score: (0)
there is alot of people on here shout out how there mates had problems and they broke, well just look around this webiste, how many people on here have had to rebuild there cossie/cvh engines because they have blown up.
Yes alot of people dont know about them but that doesnt make them rubbish, can you think of another standard engine thats under 3ltr that can hold 700bhp, i cant think of many.
People say theres a chance of bending conrods on a evo engines when going over 350ft/lb but you dont hear people saying they are a rubbish engine.
I do seem to get that from everywhere that its a crap engine but if you tune it well they are very good.
I got this from my renault turbo aswell, people just assume you can turn the boost up without doing anything else and wonder why it blows up, i ran over double the stock horsepower on standard internals on that and it was fine and i know some that are running nearly 4 times the stock horsepower on them, its all in the tune!
__________________
Old 16-01-2010, 10:27 PM   #68
turbotoaster
Trader Score: (0)
ordered a apexi power fc from japan, got it through a mate on the mazda forums for £450 which is a bit of a bargain
The Commander can display up to 10 parameters of data in real time. Monitor Mode can display:
Engine RPM
Ignition Timing
Vehicle Speed
Air Flow Voltage (Pressure Sensor Voltage)
Injector Duty Cycle
Boost
Knocking Level
Battery Voltage
Intake Air Temp
Water Temp
ill hook it up sometime in the week, then start saving for the rad/intercooler
__________________
Old 16-01-2010, 11:21 PM   #69
English
English's Avatar
Trader Score: (0)
English is on a distinguished road
I live in New Zealand. Where was this stretch of road - in case a hypothetical top speed run was in order heh heh
English is offline   Reply With Quote
Old 17-01-2010, 12:06 AM   #70
scoooby slayer
Trader Score: (4)
Engine RPM
Ignition Timing
Vehicle Speed
Injector Duty Cycle
Boost
Knocking Level
Battery Voltage
Intake Air Temp
Water Temp
looking good mate i got one in my skyline there awesome.
will give you a warning aswell if injectors, afms or knock pass your preset limit
__________________
Old 17-01-2010, 12:55 AM   #71
turbotoaster
Trader Score: (0)
ah thats good, i know i can adjust the knock sensor so when it reaches a certain value it will make my heat light flash on my dash, that will be useful for when im giving it beans.
The only other gauge im gonna get is an innovative motorsports afr reader so i can keep an eye on everything and also so i can map the cruise sections myself
__________________
Old 17-01-2010, 01:32 AM   #72
scoooby slayer
Trader Score: (4)
yes mate its my cat overheat light that warns it has saved my engine already
get some pics of the car / engine up mate
__________________
Old 17-01-2010, 01:39 AM   #73
turbotoaster
Trader Score: (0)
i would stick some up but the car is looking pretty standard at the moment, the turbo, cooler etc havent been bought for it yet
here you go anyway
thats the state it is in at the moment.
ill need about 3 months before my next big update with all my intercooler and rad setup but it will basically look like this below
__________________
Old 17-01-2010, 01:43 AM   #74
scoooby slayer
Trader Score: (4)
looks good ive always like the look of the 7s.
has the engine gotta come apart or is it just bolt ons now ?
__________________
Old 17-01-2010, 02:06 AM   #75
turbotoaster
Trader Score: (0)
the engine is fully built, ive got all the pics of it here
http://passionford.com/forum/restora...rbo-build.html
they are about halfway down, 700bhp can be done on a standard engine but my water seal failed so i rebuilt it anyway, had the ports enlarged (like porting a head and fitting cams) so 700bhp should be hit with slightly less boost.
Will be fun to have a play with rod as we are gonna be running the same turbo but i can a larger rear end, seen a datalog of someones engine with this turbo
makes 15psi at 4k and 25psi at 5k, will rev it to around 8.7k so should give a nice power band, a guy in sweden running 22psi on E85 already made just under 600whp which is about 690bhp.
now not sure how acurate his dyno is so im gonna be running about 28psi so i know im over 700bhp to make it easier on the day.
its almost as big as the engine lol 1000bhp turbo for £400 brand new, cant complain!!
__________________
Old 17-01-2010, 02:14 AM   #76
vroooom ptssssh
It Wasnt Me!
Trader Score: (0)
bullshit.
__________________
My S1Resto
Old 17-01-2010, 02:33 AM   #77
turbotoaster
Trader Score: (0)
which bit is bullshit, he is correct about the rotary, are you on about the skyline part.
to be fair you could make 700bhp on a stock rb26 but then you are putting alot of load on standard rods, of course you would run this number on racegas so you wouldnt have to worry about det.
the standard head and cams would hold you back but thats only like not porting a rotary, you just need to run more boost.
id say if he took my turbo and bolted it on he would make the power for not a massive amount more than me.
only things more he would have to pay for is 6 injectors, more expensive manifold.
obviously its a big risk on a rb26 engine, but ive seen a drag car put 1300bhp down on a stock bottom end so its not impossible
__________________
Old 17-01-2010, 03:26 AM   #78
vroooom ptssssh
It Wasnt Me!
Trader Score: (0)
bullshit about having to change all that for 600bhp on an RB26. I've already said I've watched a more or less std RB26 on the rollers was making around 630fly horsepower on standard internals...(it had cams) std manifolds, uprated HKS turbos, apexi, 4" exhaust, uprated head gasket, oil pump and injectors...1.6bar boost.
__________________
My S1Resto
Old 17-01-2010, 03:39 AM   #79
turbotoaster
Trader Score: (0)
well true, but your mentioned head gasket and cams, hence the engine has to partially come apart to achieve that. plus how much are cams, they wont be cheap
If i was going for 700bhp on a budget i wouldnt bother with that, uprated oil pumps on rb26 i hear are very expensive.
and remember we are talking about 700bhp, not 600bhp
Id just bang a big single with alot of boost and hope the rods stay together.
But remember thats in a skyline, if i had to put that engine in my car thats an awful lot of fab work.
if i was trying to do it in a skyline id probably need about 850bhp due to weight and aero, now that would be an achievement to hold together for 30secs flat out
if you could build an engine that needs to produce around 720bhp for 6k including buying a stock engine to work on then id be well interested in how you would do it.
Not trying to sound like your wrong but im genuinely interested in the name of educating
__________________
Old 17-01-2010, 11:25 AM   #80
scoooby slayer
Trader Score: (4)
a decent oil pump is around £800 but standard rods are ok ive got them in mine still, tweenie asked me will i ever want to go above 800 bhp and 8500 rpm on my bottom end and when i said no he said dont waste money on rods then, just tomei big end bolts.
i think your car is the only realistic contender for the budget mate.
the easiest and most reliable would be a supra 2jz gte base car but the budget would have to double at a guess.
as said youve got a rebuilt engine for £6k all in
__________________
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
