Jimmyc's Bonus Build - She's Alive!!!
Old 05-01-2010, 09:14 PM
Jimmyc
Jimmyc's Avatar
Default Jimmyc's Bonus Build - She's Alive!!!
Hi Guys,
Thought i'd share with you my Escort Bonus side project that i'm doing along side my black ERST.
I travelled ALL the way to Lincoln to collect it from my good friend LincolnDanny so you may recognise it!
The plan was to run the car as a standard 1.3 HCS to the ground, and then switch over to run full RST mechanicals when/if the engine went bang.
Well a couple of weeks ago it went bang, with a plume of white smoke out the back a bent rod and a hole in the block
And yes it was my fault, ran her low on oil knocking commenced and just ran her until she gave up, very naughty i know, but it's only a shitty HCS.
Here's what she looked like when i first picked her up from Danny's
Then my mate Ash very kindly gave me some free G-max springs and shocks Cheers fella
Then i picked up a cheap set of Superleggeras from the Bay
Just after this the engine went pop so i started buftying bits up for the turbo rebuild.
First item for treatment was the throttle body (ive lost my before pics so i'll add these when i find them!)
Then the metering unit
Stole this pic from Danny's thread, but mine was just as bad as this:
All of the bits i needed for the metering unit rebuild are here
And the after pics:
Inlet manifold before
And after, bolted to a fully rebuilt skimmed head, cheers to Paul 66 turbo for the Bailey breather.
Rocker cover needs either highly polishing or painting as does the breather. And yes that dump valve will be binned as soon as i can get a new top hose or a blankin plug.
I have also replaced all of the injector seals and plastic sleaves for brand new items:
Alternator
I've also bought this GRS from Scorted on here for a bargain £150
That's all for now folks, got a load of parts on order to rebuild the bottom end with, so i'll update soon!
Old 06-01-2010, 06:50 AM
jonny s2
jonny s2's Avatar
great stuff pal!
i think im needing another base model
Old 06-01-2010, 08:24 AM
leers85
leers85's Avatar
looking good mate.
Old 06-01-2010, 09:38 AM
cossiejsy
cossiejsy's Avatar
good luck on the project mate
Old 06-01-2010, 09:51 AM
Mark_
Mark_'s Avatar
i love bonus projects,
keep the updates coming
Old 06-01-2010, 11:38 AM
GranaDavey
GranaDavey's Avatar
Looks great, and love Base models.
Gonna watch this thread, gonna do the same with my Mk4 aswell
Old 06-01-2010, 11:56 AM
griffo69
griffo69's Avatar
looking sweet mate, where did you get the new injector sleaves and seals from
Old 06-01-2010, 12:37 PM
MENIS
MENIS's Avatar
nice bonus you got there mate,cant wait to see the progress pics engines looking good
Old 06-01-2010, 12:43 PM
G420 DEL
G420 DEL's Avatar
looks very good so far. keep it up mate.
wish i had a buddy that gave out free suspension lol
Old 07-01-2010, 08:13 PM
Jimmyc
Jimmyc's Avatar
Cheers for all of the great comments!
The injector sleaves were from an FAI headgasket pack for an xr3i i got from halfords for £2.50! 90% of the gaskets are the same for the CVH turbo lump, I'll try and find the part number so you can enquire if you like?
James
Old 08-01-2010, 10:05 AM
Lincolndanny
Lincolndanny's Avatar
Hoorah, finally a thread on Bert! Metering unit looks mint as! First weekend of August i believe Ford Fair is....
Old 08-01-2010, 03:11 PM
Great thread ,love a base model
Old 08-01-2010, 03:24 PM
Zetec_mk4_XR3i
Zetec_mk4_XR3i's Avatar
Bonus's rule! Keep up the good work mate, hope your keeping bonus spec bumpers etc?
Old 08-01-2010, 03:55 PM
Brian
Brian's Avatar
Brian
Old 08-01-2010, 07:08 PM
griffo69
griffo69's Avatar
James
yes please mate that would be great
cheers
Old 08-01-2010, 09:15 PM
Jimmyc
Jimmyc's Avatar
cheers
Halfords part code is 112334
and FAI code is HS191/TDJ441
Old 08-01-2010, 09:35 PM
kidsRS
"Ill check the stock"
kidsRS's Avatar
Good work there pal
what you painting the stuff up with?
Old 08-01-2010, 10:11 PM
stembo21
stembo21's Avatar
Old 09-01-2010, 04:54 PM
Jimmyc
Jimmyc's Avatar
Originally Posted by kidsRS
Good work there pal
Cheers fella.
Using Stratos silver paint, halfords high temp alluminium paint for the head, plastikote Gold and Frost restoration Detail Gray
Old 10-01-2010, 10:05 PM
Jimmyc
Jimmyc's Avatar
Cheers bud!
Thanks for sorting those parts out for me! can't find any of the other bits any cheaper, was just those rings that were a bit pricey, really appreciate it!
First week of August you say? i know i'm slow but i'm not that bad
Old 10-01-2010, 10:35 PM
tarmac terriost
tarmac terriost's Avatar
nice project that is m8 idea for a nice stealth weapon
Old 10-01-2010, 11:22 PM
749steve
749steve's Avatar
i still have a few bits kicking about if you need any turbo or bonus parts
Old 10-01-2010, 11:31 PM
stuboy
stuboy's Avatar
coming on well
Old 22-01-2010, 05:20 PM
Jimmyc
Jimmyc's Avatar
Cheers mate, what bits do you have kicking around?
Old 22-01-2010, 05:43 PM
Jimmyc
Jimmyc's Avatar
Well i've been collecting some new parts for the Bonus, just need to get them fitted now!
New Bosch Fuel pump:
Brand new Genuine Ford headgasket and locating dowels
New turbo oil hose
Gen ford sump gasket and oil cooler seal
Most of the bits i need to rebuild the bottom end with
Mk6 Escort clutch pedal, quadrant and rubber
NOS genuine Ford Gearbox mount bushes
Exhaust clamps
New Ford Flywheel bolts
Temp sensor
Collins actuator
And NOS throttle cable for a tenner
The few parts i need now are:
0.5O/S pistons & block boring to suit
Piston Rings to suit
AP clutch
New T3 turbo
Then i'm done!
Another update on Sunday hopefully!
James
Old 22-01-2010, 06:25 PM
jonny s2
jonny s2's Avatar
will be loadsa fun when its running pal
Old 23-01-2010, 01:30 PM
Zetec_mk4_XR3i
good stuff mate, would be ace to get a bonus feature in one of the mags eh!
Lookin forward to gettin them altogether at Ford Fair
Old 23-01-2010, 03:20 PM
749steve
749steve's Avatar
ive got loads of bits left like, rst early spoiler in grey, ecu brackets, loads of plastic trims,etc plus loads i cant think of at the minute
Old 23-01-2010, 04:51 PM
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
got to love a bonus !!!!
beef
Old 23-01-2010, 07:13 PM
Old 07-03-2010, 06:58 PM
Jimmyc
Jimmyc's Avatar
So it's a Sunday and time for an update.
Been a busy week or two and had a big push on the Bonus this weekend to get her a step closer to being done.
Last weekend i popped over to Derby to pick up a new bottom end up from Mart RS as mine needs boring out (which means new pistons) and also has over sized Main journals which means i need funny sized bearings that are a royal pain to get hold of so a new bottom end was the easy option plus this is an EFI block with a CPS hole so if i ever want to go EFI theres less messing about.
Anyway I eventually got to Marts and the engine looked good and turned over smoothly and was told there was no knocks smoking or bangs when it was on the road so gave Mart the monies and got it home.
Soon as i got in i stripped her down which revealed 1.0 mm O/S pistons and 4 bent conrods, gutted
Spoke to Mart and he said he would sort me out a replacement set of rods - cheers Mart, top bloke even met us at the train station when i got mega lost
Luckily however there's no wear on the bores or the piston skirts
So onto this weekend:
First up got my rad painted:
Took the exhaust and head off the Bonus:
Would of got the bottom end out too but this happened to my ball joint separator, bloody cheapo Laser gear
So gave that in as a bad job and continued buftying,
Finished off painting my gearbox
Honed & degreased the block, and painted it up
Painted my cam cover & breather and quickly fitted my Dizzy.
Finished refurbing my fuel lines from the metering unit to the head:
Finished the weekend off by starting to paint my exhaust manifold
And i've also stripped the clutch/brake pedal assembly down for the mk6 pedal conversion, which i just need to rebuild so i'll update with pics as soon as i've done that (after me Tea!)
James
Old 07-03-2010, 08:03 PM
jonny s2
jonny s2's Avatar
great work so far jimmy!
shame about the rods MARTS, normally ok guy really helpfull chap
Old 07-03-2010, 08:15 PM
m4tt274
m4tt274's Avatar
lookks good :P the gearbox came up a treat.
Old 07-03-2010, 08:27 PM
MrCapriScort
Old Fords Never Die
MrCapriScort's Avatar
Great progress
Old 17-04-2010, 10:27 AM
Lincolndanny
Looking Spanking mate :thumb:
Old 17-04-2010, 10:47 AM
focusjames
life is good
focusjames's Avatar
great mate good project
Old 17-04-2010, 11:27 AM
jonny s2
jonny s2's Avatar
did you get the rods sorted??
if not i got a decent set you can have
Old 02-05-2010, 04:22 PM
Lincolndanny
Come on mate we need some more updates! Got a set of rods here if you need them!!! Wiring loom is al done too!!!!
3 Months till Ford Fair......
Old 02-05-2010, 04:42 PM
Wow this is gonna be mint when its done.
Old 02-05-2010, 05:10 PM
marky_g
Fleet Manager
marky_g's Avatar
looking very good mate
Quick Reply: Jimmyc's Bonus Build - She's Alive!!!
